New tubes... Does brand matter?
Postby CyclingMitch » Thu Apr 09, 2015 6:12 pm
I'm looking at purchasing some new tubes as I've used the spare one supplied upon purchasing my bike.
Taking a look on eBay, there seems to be a large difference in price per tube from different manufacturers.
My question to you, ladies and gentlemen, is as follows. Is there a large difference in quality among different inner tube manufacturers?
For example, there's a pack of 10 Venzo tubes on eBay for $35. For the same price I can purchase around 3-4 of the Continental brand.
What should I look for in a tyre? Are these simply differing in brand name or quality also?
Thanks,
Mitch
- KGB
Re: New tubes... Does brand matter?
Postby KGB » Thu Apr 09, 2015 6:25 pm
For racing, i use super light butyl (eg Conti Supersonic ) or latex. Both give a better ride and weigh less than a cheapo but cost significantly more.
Others will have different opinions but that's what has worked for me over the last few years.
Postby NhiTrac » Thu Apr 09, 2015 8:44 pm
BMC Teammachine SLR01
- ldrcycles
Postby ldrcycles » Thu Apr 09, 2015 8:56 pm
- singlespeedscott
Postby singlespeedscott » Thu Apr 09, 2015 9:58 pm
- kb
Postby kb » Fri Apr 10, 2015 5:34 am
- CXCommuter
Postby CXCommuter » Fri Apr 10, 2015 7:16 am
Postby slidetaker » Fri Apr 10, 2015 1:07 pm
- Xplora
Postby Xplora » Sat Apr 11, 2015 9:45 pm
Even at 20 bucks a tube, the inconvenience of failure is intolerable to me. I pulled up during the last dash to the coffee shop and stopped 6 mates because it was the second flat for me. Worth spoiling our fun over a tube? Nope.
The flipside is the flatted tube was gold plated. That's life.
- singlespeedscott
Postby singlespeedscott » Sun Apr 12, 2015 7:18 am
- Tim
Postby Tim » Sun Apr 12, 2015 7:53 am
Which genius decided that Presta valves needed removable cores.slidetaker wrote:Non removable valve core if you are using a pump with screw-in pump head.
Has to be the one of dumbest designs ever.
Use a traditional screw-on pump hose, unscrew it, guts of the valve come off with the hose, tyre instantly deflates.
I'd not experienced these till recently. Why not put a left hand thread on the core so it doesn't undo when you unscrew the pump?
Are they are a new thing or just on the "quality" Continental tubes.
No more Conti tubes for me. Back to the cheapo's and patches.
- queequeg
Postby queequeg » Sun Apr 12, 2015 8:13 am
I had read something about the Lezyne pumps being modified to be more friendly with removable cores, but mine is a few years old.
- Tim
Postby Tim » Sun Apr 12, 2015 8:17 am
Mine is too and despite tightening the valve core with pliers they occasionally come loose if I don't remember to gently tighten the hose.queequeg wrote:I had read something about the Lezyne pumps being modified to be more friendly with removable cores, but mine is a few years old.
- Xplora
Postby Xplora » Sun Apr 12, 2015 9:42 am
Agree, puncture is usually an external issue but deflation is not just caused by puncturessinglespeedscott wrote:99% of the time the cause of the puncture has nothing to do with the tube.
- find_bruce
- Moderator
Postby find_bruce » Sun Apr 12, 2015 10:21 am
- biker jk
Postby biker jk » Sun Apr 12, 2015 10:47 am
Yes the new Lezyne pumps use ABS (air bleed system) to aid removal of the head from the valve without inadvertently unscrewing the valve core. Mine is an older model but you can purchase an ABS head for it. I haven't bothered, instead using Vittoria 42mm tubes which don't have a removable valve core.queequeg wrote:I have removable cores on my tubes. Before using them, I tighten the core up with some needle nosed pliers. That stops the core coming out when you uncrew the pump hose.
- ldrcycles
Postby ldrcycles » Sun Apr 12, 2015 12:01 pm
It would make it possible to add sealant to the tube. Not that you need sealant if you do the sensible thing and get Maxxis Refuse tyres .Tim wrote: Which genius decided that Presta valves needed removable cores.
- Tim
Postby Tim » Sun Apr 12, 2015 12:13 pm
Vittoria for me next time.
Postby eeksll » Sun Apr 12, 2015 6:03 pm
biker jk wrote:Yes the new Lezyne pumps use ABS (air bleed system) to aid removal of the head from the valve without inadvertently unscrewing the valve core. Mine is an older model but you can purchase an ABS head for it. I haven't bothered, instead using Vittoria 42mm tubes which don't have a removable valve core.queequeg wrote:I have removable cores on my tubes. Before using them, I tighten the core up with some needle nosed pliers. That stops the core coming out when you uncrew the pump hose.
I have the ABS button thingy, I still need to make sure the valve core is cinched up tight.
- RonK
Postby RonK » Sun Apr 12, 2015 7:05 pm
I tried them once. Maxxis Refuse are exactly that - refuse.ldrcycles wrote:Not that you need sealant if you do the sensible thing and get Maxxis Refuse tyres .
