Best 35mm Carbon Wheelset
- flashpixx
Postby flashpixx » Sat Apr 11, 2015 2:46 pm
In no particular order:
Bontrager Aeolus 3 D3
Campag Bora One Ultra 35mm
Zipp Firecrest 303 (45mm)
Reynolds 46 Aero
ENVE SES 3.4
Thoughts?
Go
Riding: Trek Domane SLR 7
- Duck!
Re: Best 35mm Carbon Wheelset
Postby Duck! » Sat Apr 11, 2015 7:18 pm
From workshop experience, out of your list Campag & Zipp are good, Bontrager OK, but tend to be a tad variable in reliability, Reynolds are frequent visitors (read fragile, they have a bad habit of blowing spoke nipples apart), Enve I don't have much experience with.
- flashpixx
Postby flashpixx » Sun Apr 12, 2015 4:48 pm
Thanks Duck! Any thoughts on the 88 hubs on the Zipps? Have heard various issues including relatively short life prior to rebuild. How would the C35 compare with Zipp or Campag. Leaning towards the Bora Ones but Zipp get good reviews for all round performance.Duck! wrote:Also Shimano Dura-Ace C35.
- Duck!
Postby Duck! » Sun Apr 12, 2015 6:46 pm
- flashpixx
Postby flashpixx » Sun Apr 12, 2015 7:11 pm
ThanksDuck! wrote:Only thing I've noticed with the more recent Zipp hubs is that the bearings are very sensitive to preload tension and do tend to be a bit more "rumbly" than one would expect for a premium wheel, and definitely more noticeable than older models. I don't know if it's connected to the recent (well, a few years ago now) acquisition by SRAM, but the cynic in me suggests that a decline in quality following such an event is not without precedent.
So either full carbon Campag or Carbon/Alloy C35? Plus I'll need to swap the freehub on the C35 to Campag.
- Duck!
Postby Duck! » Sun Apr 12, 2015 7:57 pm
That rules out the C35s then.... No Campag compatibility with any of Shimano's wheels.flashpixx wrote: Plus I'll need to swap the freehub on the C35 to Campag.
Postby nezumi » Sun Apr 12, 2015 8:46 pm
Not necessarily - if you can put up with the indignity of having Shimano branded wheels, you can survive having a Shimano cassette on there - and according to Zinn, all 11 speed cassettes are cross compatible with all 11 speed drivetrains.flashpixx wrote: Plus I'll need to swap the freehub on the C35 to Campag.
2015 Merida Scultura 5000
Postby Dirty32 » Mon Apr 13, 2015 2:21 pm
They seem very well regarded by many and other than lightweight's, seem to be 'the' wheel to have!
But..... Given the provenance of your bike (even if it was made somewhere in Asia!), the purists would probably tip the hat just as much to the Campags. From a purists perpective, I think they are the best choice. Apparently a fantastic wheelset!
The others are all good of course, but either of those 2 would be where I would start. Preferrably the Campags, and I am a Shimano man!
- flashpixx
Postby flashpixx » Mon Apr 13, 2015 4:16 pm
Yes the Enves... they do seems to be de-riguer at the coffee shop. Not my cup of tea however (pun intended ).Dirty32 wrote:From a pure coffee shop posing perspective, I think the Enve's would take the cake...
The Campags are the pick but at $3,800 RRP are not a value for money proposition that is easily justified (The Bora Ones (ie not "Ultra") with steel bearings are about $1k less). And I did open this thread with cost is no object.
The Zipps can be had locally for $3,300 which is still a decent investment. They do get fantastic reviews from anyone that has tried them. The hubs do raise a question however, particularly at this price point.
In the back of my mind is that carbon braking is cr@p and even worse in the wet. Although Zipp and Campag do seems to be the better performers.
Shimanos are around $2k but are Alloy plus carbon... plus the freehub issue.
Interestingly the C35 are apparently (based on my research) far and away the best alloy + carbon wheels around with Mavic the only competitor but Mavic are not in the same league even if similar in price.
Postby fat and old » Mon Apr 13, 2015 5:10 pm
Campagnolo. Hands down.
Postby Dirty32 » Mon Apr 13, 2015 6:59 pm
If its value you are wanting, with the same brand recognition and esteem from the manufacturers you mention, your likely to pick up a set of the Zipp 404 FC's for around $2k - $2.5k locally... They are obviously a deeper wheel than the 303, but because they are more widely available, they can normally be found cheaper. Thats good value and a good wheel, at that price. I have the latest version (apparently a revised hub, different rear lacing for a stronger wheel) on my Propel and absolutely no complaints... Braking has also been good.
Or... go the other way. Buy my Reynolds... Cheap (we'll find you a cheap 11sp Ultegra cassette somewhere and ill do you a special price, Gord!), and a great intro wheel. Ride the hell out of them to get a feel for carbon wheels and if you find that you want more, you've got some idea for what you want to lead toward in terms of any particular attribute that any given wheel offers.
Shameless plug, I know... But it'd narrow down any future search for me, in terms of me buying a next wheelset. What I value, what I dont... etc. If you find you that you dont know what the fuss is all about and the value isnt there, you havent spent a small fortune (and lets admit it, $3k + on bicycle wheels is a little exhorbitant) trying it out!
- flashpixx
Postby flashpixx » Mon Apr 13, 2015 7:27 pm
I'm pretty set on 35 mm based on my needs and riding ability.
Went down to Parkers to get a price on the Campags this arvo. That will give me a real cost to play with. Zipp is also a possible if the new hubs are good.
To be continued. ..
Postby moosterbounce » Tue Apr 14, 2015 2:03 am
http://intheknowcycling.com/2014/04/29/ ... ke-wheels/" onclick="window.open(this.href);return false;
- flashpixx
Postby flashpixx » Tue Apr 14, 2015 9:14 am
Thanks.. lots of reading to domoosterbounce wrote:Not sure if this is helpful, but I was bored one day and having read...
Postby snortin » Tue Apr 14, 2015 9:59 am
Flash - if you can handle tubulars, I suggest considering the 3T Mercurio. Massive discount on them through this bikeexchange shop http://www.bikeexchange.com.au/a/road-b ... /102524097flashpixx wrote:Thanks.. lots of reading to domoosterbounce wrote:Not sure if this is helpful, but I was bored one day and having read...
I have got a pair of the 60mm deep Mercurio being delivered today or tomorrow, the final piece for my dream bike build....
Bonus is they are 11 speed ready and the hub is compatible for all groupsets (hybrid campag shimano)
For $1000, VERY hard to beat in terms of value. Fairly light, aero, great price.
- MattyK
Postby MattyK » Tue Apr 14, 2015 12:55 pm
Have read that before. total joke of an article. Some guy goes online shopping, compares the specs and separate reviews of a bunch of wheels, and comes to a conclusion. A conclusion that the "best value" is a wheelset costing $1800...flashpixx wrote:Thanks.. lots of reading to domoosterbounce wrote:Not sure if this is helpful, but I was bored one day and having read...
Put an opaque curtain between the rider and the wheels and I doubt most people could pick the difference between most of them.
- Duck!
Postby Duck! » Tue Apr 14, 2015 1:00 pm
- flashpixx
Postby flashpixx » Tue Apr 14, 2015 2:06 pm
Thanks snortinsnortin wrote:Flash - if you can handle tubulars, I suggest considering the 3T Mercurio. Massive discount on them through this bikeexchange shop http://www.bikeexchange.com.au/a/road-b ... /102524097flashpixx wrote:Thanks.. lots of reading to domoosterbounce wrote:Not sure if this is helpful, but I was bored one day and having read...
keen to see pix when your build is finished.
I'm pretty set on 35mm rims, but thanks anyway
Postby nezumi » Tue Apr 14, 2015 8:14 pm
FYI, the set snortin linked is 40mmflashpixx wrote:Thanks snortinsnortin wrote:Flash - if you can handle tubulars, I suggest considering the 3T Mercurio. Massive discount on them through this bikeexchange shop http://www.bikeexchange.com.au/a/road-b ... /102524097
Postby Rex » Wed Apr 15, 2015 12:47 pm
Probably not available locally, but they're 100% made in Austria, are just about as aero as 404's and apparantly have the best brake surface in the business.
Except they're not 'wide' 24mm
- flashpixx
Postby flashpixx » Wed Apr 15, 2015 1:25 pm
so they are... didn't see thatnezumi wrote: FYI, the set snortin linked is 40mm
- flashpixx
Postby flashpixx » Wed Apr 15, 2015 1:26 pm
- MattyK
Postby MattyK » Wed Apr 15, 2015 2:14 pm
flashpixx wrote:the deed is done, placed an order for some new 35 mm x 24 mm carbon clinchers.
- flashpixx
Postby flashpixx » Thu Apr 16, 2015 3:09 pm
