Speedplay pedals - first hand experience for a road bike?
Postby hitch » Wed Apr 15, 2015 9:22 am
Does anyone have much experience with Speedplay pedals generally? Specifically for a roadbike would they be appropriate? Are there any pros and cons over SPD-SL or Look pedals when riding long distances or racing?
Cheers.
- rodneycc
Re: Speedplay pedals - first hand experience for a road bike
Postby rodneycc » Wed Apr 15, 2015 9:47 am
I have a couple of pairs of Sidis one with spd-sl 3 bolt and a speedplay specific 4 bolt pair. Both great and not much in it. I do like the speedplay specific sole because there is less room to bugger up the cleat placement and the lower stack height.
Postby eeksll » Wed Apr 15, 2015 9:53 am
One of the cons (for me atleast) is the pedal wears as well as the body. Meaning complete pedal/cleat replacement for me ... which is a bit disappointing as they are so pricey in comparison.
Some people believe the loose float system has help them solve knee issues/injuries, so if your mate doesnt have any knee issues then this is a non-issue at the moment.
- TMjpn
Postby TMjpn » Wed Apr 15, 2015 10:49 am
I came across from SPD-SL and I'm happy I did. Once you develop a knack for locating them off the lights they become second nature. Double sided engagement - very quick to clip in and go.
As mentioned before, the cleats do wear with use (more so than the pedal body) but they will give you a lot of k's before that happens.
They do need you to pay mind to servicing them every once in a while (re-greasing the bearings). The cleats are not very cheap at $50 a set but they last longer than the plastic/nylon SPD-SL cleats from what I've found. With the covers they do even more so.
- trailgumby
Postby trailgumby » Wed Apr 15, 2015 10:58 am
Ease of entry and exit is similar to mountain bike SPDs. They are double sided, and click into place simply by stepping down into them. While tension is not adjustable, float is. I particularly like the freedom in the float action - even better than Shimano mtb pedals. Some don't like this, it makes them feel a little insecure, but I found I adapted very quickly. Road bike SPD (SPD-SL) made my knees sore from the drag in the float action.
Normal road bike SPD-SL pedals you have to kind of hook your cleat into since they hang down. If you miss, your foot slips forward off the pedal. I found this happened a few times when cycling in traffic and was very disconcerting. Not fun when you have a taxi tailgating you in a rush to get the next red light, let alone a bus.
Speedplays usually go in first time, but if I don't quite get it right I can still spin the cranks over a couple of times to get momentum up without the shoe flying off the pedal and crashing my family jewels into the top tube.
I consider myself a beginner road bike rider, although I've been riding mountain bikes for over 8 years and racing for more than 5. I don't do group road rides very often.
However, I had a laugh to myself when I found myself inadvertently caught up in the last two Bobbin Head Classic rides. Each time, very seasoned-looking road bike riders in MWCC, LACC, and DHCC club jerseys were busy faffing about trying to get their feet into their SPD pedals for a good 100-150m after taking off from a standing start at the lights. I thought "Ah, it wasn't just me "
You can get Keep-On Koverz to protect the cleats from wear, although the metal is quite hard-wearing and the cleats will outlast several sets of plastic SPD-SL cleats. The Kovers need to be lightly glued on with Shoo Goo or you tend to lose them. Maintenance is minimal.
- rodneycc
Postby rodneycc » Wed Apr 15, 2015 11:32 am
- queequeg
Postby queequeg » Wed Apr 15, 2015 11:43 am
Postby eeksll » Wed Apr 15, 2015 12:05 pm
I think its just the cleat shims. The V2 are supposed to fit more types of shoes or they fit all shoes better. You can just buy the V2 shims from wiggle ...queequeg wrote:What is the difference between the V1 and V2 pedals? Torpedo7 has some on sale at the moment, but they are V1 pedals apparently.
- queequeg
Postby queequeg » Wed Apr 15, 2015 12:07 pm
So the actual pedals are the same? Since I need new shoes for them anyway, I can match them to the shoes. New bike time you seeeeksll wrote:I think its just the cleat shims. The V2 are supposed to fit more types of shoes or they fit all shoes better. You can just buy the V2 shims from wiggle ...queequeg wrote:What is the difference between the V1 and V2 pedals? Torpedo7 has some on sale at the moment, but they are V1 pedals apparently.
Postby Rex » Wed Apr 15, 2015 12:24 pm
But if you don't like maintaining your gear then I would consider something else.
They do need regreasing every so often which is messy but otherwise part and parcel of a fine product.
Cleats are expensive, but last me about 18 months.
- mogwaiboi
Postby mogwaiboi » Wed Apr 15, 2015 12:53 pm
I recently put some Time Xpresso pedals on my commuter and as far as single sided pedals go, they are very easy to engage. Having a wider body on the Times I do notice a bit of difference in stability but nothing major.
- mogwaiboi
Postby mogwaiboi » Wed Apr 15, 2015 12:57 pm
- Xplora
Postby Xplora » Wed Apr 15, 2015 3:09 pm
Postby eeksll » Wed Apr 15, 2015 4:50 pm
can anyone confirm that? The pictures certainly dont make it look like the outer casing would fit on a zero cleat. Maybe just the middle bit?Xplora wrote:AHHHH I didn't know the aero cover was compatible with all Zero cleats. Giddy up. I've noted that my Keep on Kovers would have to be killing me aerodynamically
My first pair of zeros have lasted 4000km + 7 more more months of riding. I don't have proper records on strava telling me how many kms I rode in those 7months. But I'd guess in the region of 1000 to 2000km. I don't walk in them, not a cafe goer usually. While the left plate is starting to see significant wear there is still life left on it. But the pedals have started rocking (probably started rocking quite a while ago, unfortunately didnt keep track, but I will with the new pair) so on with new cleats and pedals.
I did try a combination of old cleat new pedal and new pedal old cleat. Both exhibited the rocking, not huge but noticeable on the left when riding. Not so much on the right.
Postby Rex » Wed Apr 15, 2015 5:58 pm
- Xplora
Postby Xplora » Thu Apr 16, 2015 6:47 am
- queequeg
Postby queequeg » Thu Apr 16, 2015 8:02 am
Sounds like some post-ride pedal talk is in order for Saturday. I am leaning towards speedplay for new bike.Xplora wrote:People are talking about worn cleats, I have done probably 10-15k with mine and no issues. I have had keepon kovers for much of that time though. My cromoly pedal spindles are rooted though by lack of TLC. Rain riding, don't forget to grease them once a year lol
Postby Rex » Thu Apr 16, 2015 10:11 am
I have a rebuild kit but just haven't found the time to rebuild them.
- Xplora
Postby Xplora » Thu Apr 16, 2015 11:35 am
Might be able to sell you some cheeeeeep if they are going on the commuter... you use the same pedalsqueequeg wrote:Sounds like some post-ride pedal talk is in order for Saturday. I am leaning towards speedplay for new bike.Xplora wrote:People are talking about worn cleats, I have done probably 10-15k with mine and no issues. I have had keepon kovers for much of that time though. My cromoly pedal spindles are rooted though by lack of TLC. Rain riding, don't forget to grease them once a year lol
- queequeg
Postby queequeg » Thu Apr 16, 2015 12:05 pm
I commute on SPD. No cleats to ruin. Have SPD on my Road Bike right now, but looking to move to something else. Gives me an excuse to buy new shoes with new bike (and new helmet)Xplora wrote: Might be able to sell you some cheeeeeep if they are going on the commuter... you use the same pedals
- Xplora
Postby Xplora » Thu Apr 16, 2015 12:21 pm
- queequeg
Postby queequeg » Thu Apr 16, 2015 12:29 pm
I have 6 sets of lights before the M2, and 7 sets along Epping Rd before I reach the highway, then it another 16 sets to my office.Xplora wrote:The Keepon Kovers are just as good a solution as SPD tourer shoes ime. You do get better grip, on the shoes, sure, but the cleat still pokes out a tiny bit and can scratch the floor. Or catch carpet. The question is, ho often do you unclip? I actually measured 4 unclips on my Seven Hills Rhodes commute one day, 20kms. Quite incredible really, considering it was lots of windy bike path and definitely not the M2 commute.
I have had some terrible runs on the Pac Hwy, catching every single red light from Lane Cove to Nth Syd!
The clip/unclip doesn't bother me, it is the wear and tear on the cleats as a result.
- jacks1071
Postby jacks1071 » Thu Apr 16, 2015 1:08 pm
For me the decision was made because all my speedplay pedals are flogged out, the parts are too expensive for a repair to be viable.
Shimano are a lot cheaper long term. It has not been an easy transition though, once you get used to how easy speedplays are to get in and out of it takes a lot to get used to something different.
- RonK
Postby RonK » Thu Apr 16, 2015 1:14 pm
So, by this argument, expensive and high maintenance Speedplay pedals are not necessary and can't be justified.Xplora wrote:The question is, ho often do you unclip? I actually measured 4 unclips on my Seven Hills Rhodes commute one day, 20kms.
