Recommend me a wheel truing/building stand....
Postby thecaptn » Sat Apr 18, 2015 12:59 pm
I think it's about time for me to try truing and building my own wheels, not due to necessity but purely for the fun of it. I'm under no illusion that it's an easy or straight forward process and fully expect to stuff up a fair bit and give fellow BNA members the squirts with my incessant stupid questioning.
I'm eyeballing a pair of 105 hubs to pair up with some good strong rims for a first try and as a newby would appreciate any words of wisdom from the craftsman amongst us, such as which incantations to chant for divining spoke length and which wheel building stand would you guys recommend?
Any advice would be very much appreciated thanks,
Pete
- trailgumby
Re: Recommend me a wheel truing/building stand....
Postby trailgumby » Sat Apr 18, 2015 2:24 pm
It needed a bit of work tightening some components that weren't assembled well, but with that done it works very well.
http://www.this link is broken/au/e ... prod122322" onclick="window.open(this.href);return false;
- coffeeandwine
Postby coffeeandwine » Sat Apr 18, 2015 2:28 pm
As recommended by a few on this forum, I have found Musson's e-book to be really great value. Talks you through all the technical bits in a very practical way, explains spoke measuring etc. Includes a number of useful tools (I have constructed the dishing tool and spoke length calculator) including a Truing stand (although i went and purchased the Park Tools Pro stand online).
Some sage advice fromSheldon.
there is a very useful thread on this forum.
and another interesting site...
Lots of places to source rims, spokes and hubs that i can pass on.
Some nasty weather forecast tomorrow-I might actually get my first wheel finished (it is laced and slowly bringing tension up).
Have fun.
Merida 903 from the LBS; Diesel engine
Postby thecaptn » Sat Apr 18, 2015 11:47 pm
Looks the same yes. Thanks for the link.trailgumby wrote:I've just recently bought one of these. Just a bit over half the price of the Park Tools unit it seems ot be a copy of.
Thanks for the links, been reading for the last 4 hours. Good luck wheel build tomorrow if you get to do it. Would be great if you could post some pics once you're done.coffeeandwine wrote:I too have recently taken this course Cap'n.
Have fun.
- queequeg
Postby queequeg » Sun Apr 19, 2015 11:24 am
I also bought the Park Tool Pro stand off c r c. There was no X-Tools version back then, but I also picked the park tool stand during a sale and got it for a tad over $200.
Postby macca33 » Sun Apr 19, 2015 3:43 pm
Postby thecaptn » Sun Apr 19, 2015 6:15 pm
http://www.this link is broken.au/lifeline-profe ... truing-jig" onclick="window.open(this.href);return false;
- Thoglette
Postby Thoglette » Sun Apr 19, 2015 6:33 pm
I keep planning to make an indicator plate which will mount on the canti bosses but, so far, laziness prevails.
- MattyK
Postby MattyK » Sun Apr 19, 2015 9:19 pm
- DavidS
Postby DavidS » Sun Apr 19, 2015 9:37 pm
This is the one I have:
Details Here: http://www.parktool.com/product/profess ... and-ts-2-2
DS
Postby kukamunga » Sun Apr 19, 2015 11:29 pm
http://www.cyclingdeal.com.au/buy/bikeh ... ai/YC-512N" onclick="window.open(this.href);return false;
Thinking of getting one of these in the near future:
http://pages.ebay.com/link/?nav=item.vi ... 1175115250" onclick="window.open(this.href);return false;
- Duck!
Postby Duck! » Sun Apr 19, 2015 11:46 pm
Alternately, if you have a dishing tool to check a wheel with, you can use that wheel as your centring tool.DavidS wrote:I have a tendency to break spokes so I bought the expensive shop version of the Park Tools truing stand. Much cheaper from overseas but still pricey. The only issue I have is that I need to get the attachment to center the stand as it is clearly not centered. Maybe I'll get the attachment. It is a very capable truing stand but probably overkill for what I do and possibly for you too.
DS
Also, set your stand up very slightly (1mm is enough) off-centre. If it's bang-on, you lose the audio cue of the rim touching the lateral guide to tell if your wheel is straight, whereas if you work to a very small gap on one side you can hear where the wheel is out of line when you spin it, as it pulls away from your centred side guide.
- queequeg
Postby queequeg » Mon Apr 20, 2015 12:31 am
I have the centering tool. It is just a representation of a perfectly dished wheel.DavidS wrote:I have a tendency to break spokes so I bought the expensive shop version of the Park Tools truing stand. Much cheaper from overseas but still pricey. The only issue I have is that I need to get the attachment to center the stand as it is clearly not centered. Maybe I'll get the attachment. It is a very capable truing stand but probably overkill for what I do and possibly for you too.
DS
To make the stand fit in the box, park tool ships them rather inconveniently misaligned. Mine was out by about 2cm! Perhaps this is a scam to make you buy the tool.
If you are in Sydney, you are welcome to drop by with your stand and centre it.
- DavidS
Postby DavidS » Mon Apr 20, 2015 11:05 pm
I do have the dishing tool and I may well try that.Duck! wrote:Alternately, if you have a dishing tool to check a wheel with, you can use that wheel as your centring tool.DavidS wrote:I have a tendency to break spokes so I bought the expensive shop version of the Park Tools truing stand. Much cheaper from overseas but still pricey. The only issue I have is that I need to get the attachment to center the stand as it is clearly not centered. Maybe I'll get the attachment. It is a very capable truing stand but probably overkill for what I do and possibly for you too.
DS
Thanks for the offer queequeg but I live in Melbourne.
Great wheel truing stand, do wonder if it was ever centred.
DS
- silentbutdeadly
Postby silentbutdeadly » Tue Apr 21, 2015 10:32 am
Postby Crawf » Tue Apr 21, 2015 2:31 pm
Ahh i'm not alone, spent the biccies on this and am very, very disappointed with it, so much so that I continue to use my original Tacx mobile stand which is 1/4 the price and builds me better wheels.queequeg wrote:I have the centering tool. It is just a representation of a perfectly dished wheel.DavidS wrote:I have a tendency to break spokes so I bought the expensive shop version of the Park Tools truing stand. Much cheaper from overseas but still pricey. The only issue I have is that I need to get the attachment to center the stand as it is clearly not centered. Maybe I'll get the attachment. It is a very capable truing stand but probably overkill for what I do and possibly for you too.
DS
My Park stand is completely out of alignment in all respects.
- queequeg
Postby queequeg » Tue Apr 21, 2015 2:33 pm
They ship them this was on purpose I discovered. When you open the box you can clearly see that they aligned it so it fits in the box, not so it can be used immediately. I found out the hard way when trying to build my first wheel with it!Crawf wrote:Ahh i'm not alone, spent the biccies on this and am very, very disappointed with it, so much so that I continue to use my original Tacx mobile stand which is 1/4 the price and builds me better wheels.queequeg wrote:I have the centering tool. It is just a representation of a perfectly dished wheel.DavidS wrote:I have a tendency to break spokes so I bought the expensive shop version of the Park Tools truing stand. Much cheaper from overseas but still pricey. The only issue I have is that I need to get the attachment to center the stand as it is clearly not centered. Maybe I'll get the attachment. It is a very capable truing stand but probably overkill for what I do and possibly for you too.
DS
- trailgumby
Postby trailgumby » Tue Apr 21, 2015 8:24 pm
I solved the problem by taking one of my already perfectly dished wheels (Pro-Lite Braccianos ) and used that to centre the feelers after pushing the plastic collets all the way home and tightening their pinch bolts with the torque wrench.
How do I know the Bracciano dishing was perfect? I simply flipped it over and got the same result.
- queequeg
Postby queequeg » Wed Apr 22, 2015 11:26 am
