Steel Frameset
Steel Frameset
Postby lynskey_rider » Wed May 06, 2015 7:16 pm
I'm after a bit of knowledge from people that have built with steel, are builders of steel frame sets or engineers etc.
I have decided to buy myself a custom steel (CX) frame frame set, and in an attempt to make it a little "future proof", I want to build it with disc brakes and through-axles.
Anyway, the story goes that I approached a well known Aussie builder about building a steel frame set specifying disc brakes and through-axles as what I wanted, but the reply was that: "We can't build a steel frame using disc brakes, as the braking forces from the discs are too high".
Does this sound right? I find it a bit hard to believe, as I have seen many Steel CX frames out there, and never heard it mentioned before. I have done a bit of a google and can't seem to find any information confirming that this is intact the case.
Cheers.
- Duck!
Re: Steel Frameset
Postby Duck! » Wed May 06, 2015 7:57 pm
Steel Frameset
Postby Architecturra » Wed May 06, 2015 8:00 pm
I call massive BS on the advice you were given
Re: Steel Frameset
Postby Espresso_ » Wed May 06, 2015 8:47 pm
I think it's entirely possible that any _one_ given frame builder cannot (or would not) build a disc braked steel bike for you. I could name a few very reputable frame builders that would not do it.lynskey_rider wrote: Anyway, the story goes that I approached a well known Aussie builder about building a steel frame set specifying disc brakes and through-axles as what I wanted, but the reply was that: "We can't build a steel frame using disc brakes, as the braking forces from the discs are too high".
But it's certainly possible, as others have said.
The issue is mainly the fork, as discs on the rear will not generate the kinds of forces likely to bend anything (which is the main problem). It's for this same reason that many production disc-braked steel bikes use a carbon fork.
E
Re: Steel Frameset
Postby Espresso_ » Wed May 06, 2015 8:51 pm
Are there actually that many genuine MTBs with steel front forks set up for discs?Duck! wrote:Given that I've seen multiple disc-braked steel MTBs, I find that very hard to believe.....
I would have thought that most MTBs of the disc era would have a (not steel) suspension fork up front, rather than a steel fork?
I guess there are plenty of more recent rigid "off road" bikes like a Surly Krampus etc but I would not really consider them MTBs. They do have steel forks with discs up front though.
E
- Duck!
Re: Steel Frameset
Postby Duck! » Wed May 06, 2015 9:31 pm
- find_bruce
- Moderator
Re: Steel Frameset
Postby find_bruce » Wed May 06, 2015 9:43 pm
You can even get lugged steel forks if that's your thing. No weight listed but I am willing to be it is not light
Even less of an issue with a steel frame, just needs slightly stiffer seat stays. Everything from a custom cielo, Genesis (although they have had to recall some steel forks, Marin, Redline & no doubt many more
Re: Steel Frameset
Postby Espresso_ » Wed May 06, 2015 9:57 pm
Yes, that is my thing. Or at least this is.find_bruce wrote:You can even get lugged steel forks if that's your thing. No weight listed but I am willing to be it is not light.
Weight? Meh. Chances are if you're looking for a steel bike/fork you're probably considering other things over weight.
E
- Dragster1
Re: Steel Frameset
Postby Dragster1 » Thu May 07, 2015 7:30 am
- open roader
Re: Steel Frameset
Postby open roader » Thu May 07, 2015 8:17 am
http://www.winterbicycles.com/
Re: Steel Frameset
Postby Uncle Just » Thu May 07, 2015 8:11 pm
A thing of beauty, in steel, with disc fork.... IF Grand Royale.
And a recent build from Ewen Gellie for his partner....
http://www.gelliecustombikeframes.com.a ... andonneur/" onclick="window.open(this.href);return false;
- AUbicycles
- Site Admin
Re: Steel Frameset
Postby AUbicycles » Thu May 07, 2015 11:16 pm
I wouldn't read too much into it. They don't want to do it for any number of reasons. It may not suit their style or vision (compromising aesthetics or preferred materials), they may simply have no interest, it may be too expensive to design and engineer if this is new.lynskey_rider wrote:"We can't build a steel frame using disc brakes, as the braking forces from the discs are too high".
The important take-away is that who-ever builds it needs to know how discs work in terms of engineering a sound frame.
Re: Steel Frameset
Postby zero » Sun May 10, 2015 9:34 pm
Its not unreasonable to be honest. They probably do not source the right kind of tubes by default to make a disc frame at either end, nor will their bikes have nice riding qualities if such was fitted - I could understand exactly why some traditional frame builders would want to avoid disc braked steel framesets.Architecturra wrote:Go to velocipedesalon.com forums and check out the hundreds and hundreds of frames and builders there.... Including many steel framed disc brake setups.
- silentbutdeadly
Re: Steel Frameset
Postby silentbutdeadly » Tue May 12, 2015 10:30 am
http://www.paragonmachineworks.com/cgi- ... key=DS1004" onclick="window.open(this.href);return false;
My steel hardtail MTB is like this....and I could actually convert it to a drop bar gravel marathoner with 135 rear thru axle if I was that way inclined...
- RonK
Steel Frameset
Postby RonK » Tue May 12, 2015 1:00 pm
But I suspect they'll still refuse.
Re: Steel Frameset
Postby mmc22 » Tue May 12, 2015 2:30 pm
- RonK
Re: Steel Frameset
Postby RonK » Tue May 12, 2015 2:31 pm
Yup - that's the way I read it toommc22 wrote:I'd say it's all in the wording... as in "We" can't build it, not so much to say it can't be done, they seem to be saying "they" can't for whatever reason. Probably tooling and experience.
Re: Steel Frameset
Postby Mike Ayling » Tue May 12, 2015 4:02 pm
Thorn, the boutique manufacturer of steel touring bikes used to insist that the forces exerted by disc brakes were too strong for their current range of steel forks which were designed to provide a comfortable ride. They have bowed to customer pressure and offer a range of steel disc brake compatible forks but see the extract from their current brochure below:
http://www.sjscycles.com/thornpdf/thorn ... ochure.pdf" onclick="window.open(this.href);return false;
[6] Thorn Reynolds steel disc brake 700c touring fork with lo loader bosses.Fits Mercury or Club Tour Mk4
The Blades are extra heavy duty and have larger than usual diameter tips. There are no V brake bosses.
This fork must be used with a front disc brake.
We resisted designing a steel disc fork because we knew that a reliable disc
fork could never be as comfortable as our Reynolds Super Tourist V brake
fork and it’s not!
Mike
- RonK
Re: Steel Frameset
Postby RonK » Tue May 12, 2015 5:57 pm
Kinda like cutting off your nose to spite your face isn't it. I bet it was Andy Blance wrote it. But that is the kind of attitude that predominates at Thorn. Funny, Thorn was the first to come to mind when I read the original post.Mike Ayling wrote: We resisted designing a steel disc fork because we knew that a reliable disc
fork and it’s not!
- baabaa
Re: Steel Frameset
Postby baabaa » Tue May 12, 2015 9:05 pm
Ok carbon forks and not through-axles but...
http://ritcheylogic.com/frames/cross/sw ... black.html" onclick="window.open(this.href);return false;
and through-axles in the rear but you could get a through-axle fork
http://www.ninerbikes.com/rlt9steel" onclick="window.open(this.href);return false;
But yes it can be done and I have had one of these since 2008
http://salsacycles.com/bikes/archive/la_cruz/overview/" onclick="window.open(this.href);return false;
My call is that the builder is just saying no to you and that is a good thing if they don't feel comfortable doing stuff they don't want to do.
Also not through-axle but these would be up on my list http://www.shandcycles.com/bikes/stoater/" onclick="window.open(this.href);return false; and
https://www.benscycle.com/p-3902-milwau ... ilder.aspx" onclick="window.open(this.href);return false; ( 'cause my main 3 bikes are built with True Temper OX Platinum and I like it a lot)
