Brake pad recommendations?
gregaudio
Postby gregaudio » Tue May 12, 2015 7:24 pm
Hi, my V Brakes take the 70mm rubber inserts. I've been using Koolstop Salmons because I've read that they're good in the wet and are less inclined to wear down aluminium rims. Problem is, they're getting costly to replace. I'm searching for advice on what types you all use and find works well.
My commuting setup is 700C Fulcrum Racing rims with 28mm Schwalbe Marathons.
silentbutdeadly
Re: Brake pad recommendations?
Postby silentbutdeadly » Tue May 12, 2015 7:37 pm
Spend the dollars or don't stop...in time. Your choice!
Swisstop are also an option but also not cheap.
MattyK
Postby MattyK » Tue May 12, 2015 7:42 pm
Swissstop sell sets of four pads, so value is better than it first appears.
Postby Mulger bill » Tue May 12, 2015 8:15 pm
Braking is an area where the best priced option is not always the best value.
KoolStops or Swisstops are worth the money IMO.
If you don't mind going to the effort, get a set of KS Thinlines for the good days and save the Salmons for winter/wet work.
gregaudio
Postby gregaudio » Tue May 12, 2015 9:58 pm
Why did I need convincing? It's always worth the extra for good brakes & tyres.
Money spent!
Storm Boy
Postby Storm Boy » Tue May 12, 2015 10:18 pm
Good work :-)
I just changed my Koolstop Blacks for Koolstop Salmons with the wet weather, they are both great brake pads, It will take a pretty good brake pad to convince me to change to another make :-)
Regards,
SB
rpmspinman
Postby rpmspinman » Wed Jul 29, 2015 12:24 pm
I have the Shimano BR-M561 calipers with I think standard pads on them and in need of some top quality braking. Should I go for the Swissstop FLash, Flash Pro or race pads? Alloy brake surface btw.
Shav
My Bikes:
2011 Kona Dew Plus (commuter)
2012 Focus Cayo 2.0 (road)
2015 Cervelo S5 VWD
carcharias
Postby carcharias » Wed Jul 29, 2015 5:28 pm
I got much improved braking from Tektro Oryx cantilever brakes by changing the original 72 mm for Clarks brand which were cheap also.
Early days though so don't know what wear factor is...
Users browsing this forum: Amazon [Bot]
