get a refund and buy a frame from somewhere else...the relationship between you and this seller is dead. Time to move on.battler2 wrote:dont know what you said before the edit, but its fine. the problem with a refund is, i've pissed away $110 on postage and i still don't have a frame. i've got a groupset, fork, headset and other parts bought for this frame. and no frame.defy1 wrote: edit : get a refund
Being REFUSED warranty on a defective Lynskey frame
Re: Being REFUSED warranty on a defective Lynskey frame
Postby defy1 » Thu Jun 25, 2015 7:13 pm
Postby battler2 » Mon Jul 06, 2015 4:25 pm
- biker jk
Postby biker jk » Mon Jul 06, 2015 5:23 pm
- Drizt
Postby Drizt » Mon Jul 06, 2015 5:26 pm
Postby battler2 » Mon Jul 06, 2015 5:31 pm
biker jk wrote:Get your string out!
WAY ahead of the BOTH of you. LOLDrizt wrote:Tape measure...
checks out
- Drizt
Postby Drizt » Mon Jul 06, 2015 5:33 pm
Postby battler2 » Mon Jul 06, 2015 5:43 pm
visually it looked like it sits in the centre nicely as well. think i will have no issues with this frame
- silentC
Postby silentC » Mon Jul 06, 2015 6:25 pm
- Me
- biker jk
Postby biker jk » Mon Jul 06, 2015 6:28 pm
The frame hasn't been built up and ridden yet so relief may prove premature.silentC wrote:halle-fricken-lujah!
- outnabike
Postby outnabike » Tue Jul 07, 2015 9:34 am
Postby defy1 » Thu Jul 09, 2015 6:55 pm
it didn't sit nicely centre in the old one? hopefully you don't wait 6 months before building it upbattler2 wrote:
Postby battler2 » Thu Jul 09, 2015 8:01 pm
Postby carcharias » Wed Jul 29, 2015 7:29 pm
I agree with this. But also your own pictures / measurements show a significantly damaged rear triangle. = super-crab Lynskey.Tim wrote:The frame is either properly aligned or it isn't.
There is no grey area, not a matter of opinion, but an issue of precise measurement. Differences in opinion are due to imprecise measurement techniques.
I'd be taking the frame to a recognised and independent frame builder, clamping the frame to a building/alignment jig and having it properly assessed with proper tools.
Would it be better to use metal straight edge? Also mount the rear wheel minus tyre + measure distance from rim to the seat-stays. Check vertical alignment of rear wheel with the seat tube...Fit front wheel also minus tyre and check this against rear wheel held in straight ahead position. Bound to spot any geometric shenanigans.
Anyway that's my 5 cents....or 10...
Postby battler2 » Wed Jul 29, 2015 8:39 pm
there was no damage to the rear triangle. i used the paper ruler at the time as it was stiff and didn't flex, but couldn't in the last measurements of the new frame i posted (using the same method) because it was left outside over the winter and became floppy. the wheel can sit in seat-stays a bit out of whack but still present little to no problems, another member on here has that problem but doesn't cause any instability for him. the last thing you suggest would only work with an accurate method of measurement ensuring fork is pointing right ahead and wheel is steady. too hard. park tool have a gauge for all this FAG-2 which was never used.carcharias wrote: I agree with this. But also your own pictures / measurements show a significantly damaged rear triangle. = super-crab Lynskey.
this has been resolved with a replacement frame, that so far has not caused me any instability issues at all. some more testing (ie. that roundabout i nearly crashed on) but a couple of downhills well over the 35km/h threshold and i haven't had that sliding side to side/slippery feeling like i'm riding on ice.
to keep it short, i still believe the frame was significantly misaligned but it was never measured properly, nor do i have evidence of it being measured properly. frame flex due to thinner gauge tubing may have also contributed, but i ruled this out as the very minor frame flex i received when climbing hard out of the saddle i believed was simpy a trait of Ti, and that i have never heard of anyone having this problem with this frame and the silver series of frames. it doesn't matter anymore as the frame was not fit for purpose and i have received a replacement.
i will specifically send a thanks to chad@lynskey soon for sorting this out for me.
