Fitted Wind/shower proof top
Postby AndyRevill » Mon May 25, 2015 2:16 pm
I think I'm getting soft in my old age so I've decided I need a top to keep out the Hobart chill and showers but not a full on rain jacket. I'd like something along the lines of the Castelli Gabba 2 which by all accounts is the bees knees, however it is heading towards $300. Does anyone have any direct comparison between this and say the Ground Effect Turbine, which seems to be a similar concept and got good reviews on here, it's "only" $180 and I've been impressed with other bits of their gear. Anything else I should look at?
Cheers, Andy
Trek Domane 4.5
- AUbicycles
- Site Admin
Re: Fitted Wind/shower proof top
Postby AUbicycles » Mon May 25, 2015 4:34 pm
Postby cage » Mon May 25, 2015 4:43 pm
Postby Hendo55 » Mon May 25, 2015 9:04 pm
Postby AndyRevill » Mon May 25, 2015 9:04 pm
I'd already read your nice review which sparked my interest and the vid seems to confirm it might be just what I need - if it works in Christchurch then it should work in Hobart
Cheers, Andy
Trek Domane 4.5
- AUbicycles
- Site Admin
Postby AUbicycles » Tue May 26, 2015 10:32 am
No longer on the mobile, so I can also put in the link to the review for other readers:
The Ground Effect Turbine and Frosty Boys Jackets in Review
One small update, I now have a blue (cyan) coloured turbine which I personally like more than the red (as a matter of opinion).
- RonK
Postby RonK » Tue May 26, 2015 11:07 am
Postby AndyRevill » Tue May 26, 2015 12:21 pm
Thanks, good to know.RonK wrote:I have a Jetson - the sleeveless version of the Turbine. Used it in NZ spring rain and snow showers. Highly recommended. For visibility I like the red.
I'm conflicted on colour - I like the blue as a colour but the others might be better for visibility, though I do have a very bright red flashing rear light
Cheers, Andy
Trek Domane 4.5
Postby caneye » Tue May 26, 2015 1:28 pm
http://www.groundeffect.co.nz/product/UNF/DRA" onclick="window.open(this.href);return false;
Postby AndyRevill » Tue May 26, 2015 1:53 pm
Thanks for the suggestion similar idea but It's not a fitted top so will be a bit looser - it's in their "unfashion" range, more for MTB/Urbancaneye wrote:is the GE Draft Dodger overkill?
cheers, Andy
Trek Domane 4.5
- AUbicycles
- Site Admin
Postby AUbicycles » Tue May 26, 2015 9:25 pm
- mogwaiboi
Postby mogwaiboi » Wed May 27, 2015 6:19 pm
- nickobec
Postby nickobec » Wed May 27, 2015 7:01 pm
It is not completely waterproof, 30 minutes in heavy rain, you will be wet but warm. Raced for two hours in heavy rain, lost half the field, but I was warm and comfortable (except my feet).
The downside of the yellow version is it shows the road muck. One wet day and you have grey stripe up your back, needs regular washing, but it has survived.
Is my goto jersey on wet days or days below 10C, below 8C with merino base layer and arm warmers
Postby Hillsaretheenemy » Thu May 28, 2015 10:54 am
Postby 2wheels_mond » Thu May 28, 2015 11:04 am
Have you tried out one of those little ass-saver mudguards, like these?nickobec wrote:The downside of the yellow version is it shows the road muck. One wet day and you have grey stripe up your back, needs regular washing, but it has survived.
http://www.this link is broken.au/ass-saver-ass-saver-extended/" onclick="window.open(this.href);return false;
Nothing like full mudguards of course, but it'll stop the stripe on your back and water down the back of your shorts.
Postby caneye » Thu May 28, 2015 11:08 am
I find the BEST thing about the Gabba is that .. it not only keeps you warm when cold, but it keeps you cool when warm. prevents overheating.
there was a special in Bikeexchange last year and the LS one was around $180 from a local VIC shop.
Postby AndyRevill » Wed Jun 10, 2015 8:07 pm
Cheers, Andy
Trek Domane 4.5
- Tim
Postby Tim » Wed Jun 10, 2015 8:50 pm
But.
In my opinion the Turbine is a waste of money. Expensive. About as breathable as a plastic bag. Water-resistant for around 10 minutes, then it leaks like a sieve. The sleeve zipper ventilation system is relatively ineffective, pit zippers work much better on other jackets. Even with the main front zip three quarters open I sweat like a pig around the arm pits and on the back at temperatures anywhere above 12 degrees. The stitching has pulled around the rear pockets, the material is very delicate and has torn despite the fact I am very careful with my gear.
I don't recommend it.
I have minor gripes about the quality of the hem overlocking on some of GE's other shirts too. As mentioned I am gentle with my expensive gear but several shirts have loose threading around the hems where the stitching has pulled. This doesn't happen on most of my other cycling clothes.
Sorry Andy but that has been my experience of the Turbine after two winters of irregular use. Treat the jacket with care.
I keep returning to my four year old Pearl Izumi Elite Barrier jacket for wind and shower resistance. At a quarter of the price of the Turbine I find it far more practical. It doesn't breath very well but when things heat up the jacket comes off and rolls into a rear jersey pocket with ease. If it's really wet I wear a proper eVent Showerspass rain jacket which is a brilliantly performing water and wind PROOF piece of kit.
Postby caneye » Tue Jul 07, 2015 10:06 am
AndyRevill wrote:Thought I'd give an update. I had a quick look around but there didn't seems to be any Gabbas on special and truth be known I was probably leaning towards the Turbine anyway as I've been impressed with other bits of Ground Effect gear and I like the fact they're made in NZ. So last Thursday ordered myself a Turbine in Red (toss up between Blue or Red - family was split 50:50) and it arrived on Tuesday, first ride today, temp was 11C, apparent temp 6C - perfect for the first go. Wore it with a Submerino underneath and I love it! Nice and tight fitting, probably a bit warm uphill but perfect going down - couldn't be happier
Cheers, Andy
any more updates after a few winter weeks?
Postby AndyRevill » Tue Jul 07, 2015 11:59 am
If I get a bit warm going uphill (e.g. up the mountain) I've used the front zip and arm zips to let some air in and that seems fine. The arm zips are a bit different but I've found them to be good - relatively easy to open and close while keeping one hand on the bars and air flows in and up under the jacket so you get some cooling. Can't say if pit zips would be better but I think they'd be harder to open and close while moving. The jacket does breathe, as shown by how much condensation there is on anything in the back pocket (lucky the phone is in a waterproof case) but like anything it can't be 100% breathable, hence a good base layer is important.
Only thing I haven't experienced yet is showers on my ride (should have bought it sooner ) but my impression is it will hold off light stuff but will give out to anything heavy, which is what I expected (it's not touted as waterproof) but I'll follow up when it does happen.
Everything else seems good so far - no problems with the seams, as others have said the back pockets while elasticated do seem a bit "tight" compared to a traditional jersey so I am conscious of using care when putting things in and taking them out.
Cheers, Andy
Trek Domane 4.5
