Veloflex Record tubular - where to buy
- mikesbytes
Postby mikesbytes » Thu Jul 02, 2015 4:30 pm
Found it on Wiggle http://www.this link is broken.au/veloflex-recor ... ular-tyre/, didn't find it elsewhere
- toolonglegs
Re: Veloflex Record tubular - where to buy
Postby toolonglegs » Thu Jul 02, 2015 4:41 pm
http://www.materiel-velo.com/1359300-bo ... -noir.html" onclick="window.open(this.href);return false;
- Thoglette
Postby Thoglette » Thu Jul 02, 2015 5:53 pm
There's a lot of choice at the $150 (or even 74euro) each price point. Especially at 22mm
- mikesbytes
Postby mikesbytes » Thu Jul 02, 2015 10:23 pm
75 euro = $110 aussie. That's where I expected the price to be. Do they post to Australia? What is the postage?
- mikesbytes
Postby mikesbytes » Thu Jul 02, 2015 11:03 pm
Advantage for me with bikebug is that I live 200mtrs from the mail order distribution centre
- Thoglette
Postby Thoglette » Fri Jul 03, 2015 8:40 am
mikesbytes wrote:Because I only have one wheel that needs replacing.
Thought so. Veloflex does seem to be a little thin on the ground.
- mikesbytes
Postby mikesbytes » Fri Jul 03, 2015 8:47 am
Its for a front wheel, I use the same one for Road TT's and velodrome, including wooden tracks.
Also noticed how light the Vittoria track tyre is. 160gms for 22mm and cheaper, however could I use for TT's, I'm guessing not. http://www.probikekit.com.au/bicycle-ty ... 76985.html
And while I'm at it, what about glue? Its a carbon rim
- open roader
Postby open roader » Fri Jul 03, 2015 9:01 am
http://www.ribblecycles.co.uk/sp/road-t ... elxtuba300
I use Vittoria Mastik 1 glue over my carbon and alloy rims with no perceivable issues, that said, I prob. don't get enough heat into the carbon rims to worry about it.
- mikesbytes
Postby mikesbytes » Sun Jul 05, 2015 10:42 pm
Couldn't buy cement/glue from ribble, all the brands aren't available for overseas orders
So now I need to order the cement/glue from another site, or can I walk into a Sydney shop and buy it?
Postby dalai47 » Mon Jul 06, 2015 10:10 am
Depends if you only use a particular brand... I'd phone first!mikesbytes wrote:So now I need to order the cement/glue from another site, or can I walk into a Sydney shop and buy it?
I swear by Vittoria Mastik One - I found one not so local store that stocks it, so I buy tubes every time I go past to make sure I never run short.
- Bunged Knee
Postby Bunged Knee » Mon Jul 06, 2015 10:11 am
http://www.this link is broken/Vittoria-Ma ... e-30g-Tube
http://www.bikebug.com/tyrestubesinflat ... 0_250.html
- Thoglette
Postby Thoglette » Mon Jul 06, 2015 1:01 pm
Pushy's just spammed me a week or to ago to say they have Schwalbe tins back in stock. Moyura have Tubasti Rim Cement in stock, according to their websitemikesbytes wrote:So now I need to order the cement/glue from another site, or can I walk into a Sydney shop and buy it?
- mikesbytes
Postby mikesbytes » Mon Jul 06, 2015 1:41 pm
I've never glued one, Bundy did them for me before.
Such a small purchase, hardly worth paying for postage
I live 200mtrs from the BikeBug mail distribution point, I'll ask if I can pick it up. Otherwise I'll be driving past Cell, I'll check there shop price.
- open roader
Postby open roader » Mon Jul 06, 2015 5:31 pm
They are flamable material and thus cannot / should not be air mailed hence unavail. for OS customers.
Gluing up tubs is easy if you take your time and have the right sized brush.
- mikesbytes
Postby mikesbytes » Mon Jul 06, 2015 9:35 pm
- open roader
Postby open roader » Mon Jul 06, 2015 10:07 pm
Grab yourself some artist's brushes and acetone if the rim is brand spankers. I prefer 8mm round brushes or 10mm flat brushes. The bristles get gluggy and separate whilst applying the glue and loose a bit of dexterity/accuarcy so a smaller head brush with plenty of time to take care makes a thinner, more even layer.
- mikesbytes
Postby mikesbytes » Tue Jul 07, 2015 3:03 pm
Suppose the next task is to remove the existing single and clean off the existing glue. As this is the first time I've done it, it's a learning experience
- Thoglette
Postby Thoglette » Tue Jul 07, 2015 4:10 pm
Have fun. Take your time. Get glue to the edges.mikesbytes wrote:Suppose the next task is to remove the existing single and clean off the existing glue. As this is the first time I've done it, it's a learning experience
And ignore the American panic merchants.
Postby dalai47 » Tue Jul 07, 2015 4:52 pm
- open roader
Postby open roader » Tue Jul 07, 2015 5:47 pm
+1dalai47 wrote:Usually no need to clean off the existing glue...
I've done this just one on a pair of wheels with 11 year old glue which was visibly brittle and flaking off, I reckon 5-6+ year old well applied glue is good to re-glue straight up.
- mikesbytes
Postby mikesbytes » Wed Jul 08, 2015 9:53 pm
- open roader
Postby open roader » Wed Jul 08, 2015 9:56 pm
Yep.mikesbytes wrote:so just rip it off?
If it's a dead tyre use a blade and cut it up to get easier peel access.
Postby dalai47 » Wed Jul 08, 2015 10:03 pm
Yes but carefully. Have heard in the worst case the glue has taken away some carbon when tearing off the tyre.*mikesbytes wrote:so just rip it off?
*Never happened to me.
- open roader
Postby open roader » Wed Jul 08, 2015 10:18 pm
Yikes!dalai47 wrote:Yes but carefully. Have heard in the worst case the glue has taken away some carbon when tearing off the tyre.*mikesbytes wrote:so just rip it off?
I guess anything is possible - uber brute arm strength, super adhesive tubular glue / tubular shellack or even poor quality carbon epoxy bonding.
Yes, peel it slowly and gradually, like the the glue up - take some time over it.
- mikesbytes
Postby mikesbytes » Fri Jul 10, 2015 12:32 am
Users browsing this forum: Amazon [Bot]
