Yes, clearing customs, slowly. There is a distributor in the picture before Pushy's. There are probably taxes but they are built into the price to me the consumer, so not transparent to me.Bluejay87 wrote:Clear customs? I thought pushys was a local seller. There is no extra import tax on that is there?ft_critical wrote:correct, apologies. Now due early Nov and ....Bluejay87 wrote:Do you mean $1550?
Powertap P1 Power Meter
- ft_critical
Re: Powertap P1 Power Meter
Postby ft_critical » Wed Oct 28, 2015 1:01 pm
Postby Bluejay87 » Wed Oct 28, 2015 1:04 pm
Postby Knoxis » Wed Oct 28, 2015 2:46 pm
Postby scho047 » Thu Oct 29, 2015 11:23 am
Postby Bluejay87 » Fri Nov 06, 2015 1:10 pm
Postby Six13 » Fri Nov 06, 2015 6:42 pm
- ft_critical
Postby ft_critical » Fri Nov 20, 2015 8:55 pm
Installation - ridiculously easy. They work.
I found the pedal balance was tricky coming from SPD, the weight of the pedal with the battery meant it wasn't easy to clip in. Probably with practice I will get used to it.
Proprietary cleats are probably an issue, planning on getting cleat covers.
No issues with data on the old Garmin 500. My pedal balance is pretty good I discovered.
- Xplora
Postby Xplora » Fri Nov 20, 2015 11:57 pm
Postby Bluejay87 » Sat Nov 21, 2015 8:46 am
- ft_critical
Postby ft_critical » Sat Nov 21, 2015 10:41 am
Power newbie X. Though my plan today is to record my power on the home trainer in 0.5kmh increments to build a power to speed curve. I have four years of speed data and benchmark testing on that trainer (religiously same setup on the trainer, all measurements taken post trainer warmup period).Xplora wrote:Good to hear! What have you been using before to compare it to?
- Xplora
Postby Xplora » Sat Nov 21, 2015 6:17 pm
- ft_critical
Postby ft_critical » Sat Nov 21, 2015 11:07 pm
I was only planning on sharing my watts with someone who can give me advice, not on the forum. Also to use them to train right based on advice.Xplora wrote:as people start comparing watts
Postby Bluejay87 » Sat Nov 21, 2015 11:11 pm
I don't think he was asking you to 'share your watts' with him, but to compare the consistency between this powermeter and others.ft_critical wrote:I was only planning on sharing my watts with someone who can give me advice, not on the forum. Also to use them to train right based on advice.Xplora wrote:as people start comparing watts
Once I get mine I'll compare with the Kickr. Should be interesting as many do report that the Kickr reads high. Of course there is no way of knowing which PM is 'correct'.
- Xplora
Postby Xplora » Sat Nov 21, 2015 11:15 pm
I really gotta book a calibration with Alex Simmons though, something chronic... I think I'm reading low, and it's fun to join in the dick contest occasionally, despite the scientific risks involved
- ft_critical
Postby ft_critical » Sun Nov 29, 2015 5:10 pm
The proprietary cleats are an issue in my opinion; they are slippery and fragile. I ordered some Look cleat covers, but the other problem is that there isn't a lot of suppliers for replacements. I also don't really like the feel of them security-wise, so I dialed them up to maximum tension.
The pedals are bulky underneath, I clipped the pedal in this weekend's Crit as I knew I would. I still have trouble clipping in compared to Shimano.
When ever you start using them they do a calibration, for some reason they struggle to calibrate one of my bikes. I recommend allowing an extra 2 min before each ride for this step.
But as you can see none of these are a significant complaint and there are no other issues, that is my complete list.
Postby Bluejay87 » Sun Nov 29, 2015 8:39 pm
- nickobec
Postby nickobec » Mon Nov 30, 2015 6:32 pm
I don't find the cleats slippy and fragile(again been using Keo's for a while)
PT Cleats are Wellgo RC7, they are identical (except Wellgos have their name on them) both are marked RC7 and are $10 a pair from Torpedo7
Only ground the pedals once (and that was on a commute) done a few races, road and crits without any issues.
When I grounded the pedal, just lost a little metal.
Upgraded the firmware (that is a pain if you do not own a modern ipad or iphone)
No power spikes since firmware upgrade.
My one issue is I get an error message everytime I start my garmins (tried in on two different ones) I get "power meter software mismatch". After speaking to Saris they believe the two pedals have different versions of firmware and need to go back to them. The pedals appear to work fine, match the output on my G3 (+3% for hard rider, 5 to 7% for an easy ride), so I will get them fixed next year.
Postby Bluejay87 » Mon Nov 30, 2015 6:49 pm
I've read about this issue and it's because you need to update the firmware on each pedal separately. You shouldn't need to return it. Just repeat the iphone update process you've already done, on the other pedal.
It's weird that you are seeing the power mismatch greater as a % at higher poweroutputs. I'd expect the p1's to read a bit higher than the G3 as it's closer to the where the power is being delivered but you'd think it should be consistently different.
- nickobec
Postby nickobec » Mon Nov 30, 2015 7:33 pm
The P1 does read higher than the G3 or Elite+Bluejay87 wrote:It's weird that you are seeing the power mismatch greater as a % at higher poweroutputs. I'd expect the p1's to read a bit higher than the G3 as it's closer to the where the power is being delivered but you'd think it should be consistently different.
On a cruisy ride the P1 average is maybe 8 to 10 watts higher (5 to 7%) than the G3 or Elite+
In a race the P1 average is 6 to 8 watts (3%) higher than the G3
Looking at it as watts it is pretty similar
Thanks for the tip, will try updating both pedals independently, next time I get my hands on an iPad
- Alex Simmons/RST
Postby Alex Simmons/RST » Mon Nov 30, 2015 8:48 pm
It could also be one has an incorrect slope calibration.
Finally, drivetrain and/or freehub may not be a good as you think, worth checking.
Postby softy » Mon Nov 30, 2015 11:07 pm
Well they are an expensive bit of kit, i have a garmin 810, so the vector s would be the obvious choice + i have campag compact crank (don't know if the stages will fit). Nice to see powertap offerring a pedal competitor.
Any long term users advice of powermeters?
It is said watts, is the best indicator to develop your fitness and endurance?
What are everyones thoughts who have been using them?
Postby dalai47 » Mon Nov 30, 2015 11:57 pm
As I always say. First buy Training and Racing with a powermeter. If it makes sense and you haven't been put off by the thought of structured training then I'd say buy a PM.softy wrote:Any long term users advice of powermeters?
Otherwise it will just be an expensive bike computer...
DCRainmaker and Alex Simmons both have a good overview of the available units.
- Alex Simmons/RST
Postby Alex Simmons/RST » Tue Dec 01, 2015 7:49 am
"Powermeters are a tool, not a bolt on motor." - Chris Mayhewsofty wrote:Newbie to power meters here, okay i have heard the hype, biggest upgrade you can do to your bike!
Like all tools, they vary in quality and what you can do with them depends on the skill, knowledge and experience of the user.
- JdM
Postby JdM » Tue Dec 01, 2015 9:31 am
This.dalai47 wrote:As I always say. First buy Training and Racing with a powermeter. If it makes sense and you haven't been put off by the thought of structured training then I'd say buy a PM.
Friel's Power Meter Handbook for Cyclists and Triathletes is also a good alternative if the above title is a little dense to start with.
- Xplora
Postby Xplora » Tue Dec 01, 2015 1:28 pm
Users browsing this forum: Google [Bot], Google Adsense [Bot]
