Buying a new commuter belt drive
Postby danieljB » Mon Aug 17, 2015 9:11 pm
Avanti Inc 3 - https://www.avantiplus.com.au/products/ ... anti-inc-3
Apollo Trace 55 - http://www.apollobikes.com/bikes15/urba ... dG6GBpApSA
The Apollo is currently a little dearer but I'm led to believe it is a little better specd. Better brakes (M505 vs 405), bottom bracket (Shimano sealed vs fsa power drive), shifters (Shimano rapid fire vs not specified), tyres (Hutchinson gotham vs continental sport contact).
In people's opinions Is this worth the couple of hundred dollars more?
- MattyK
Re: Buying a new commuter belt drive
Postby MattyK » Mon Aug 17, 2015 11:37 pm
Postby Calvin27 » Tue Aug 18, 2015 9:31 am
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
- coyote
Postby symotelli » Tue Aug 18, 2015 9:39 pm
+1MattyK wrote:Much of a muchness. Shifter will be the same. Ride both, pick your favourite.
Postby danieljB » Tue Aug 18, 2015 9:58 pm
Postby Calvin27 » Tue Aug 18, 2015 10:30 pm
The geometry is subjective. I mean it's a flat bar commuter. I've compared my mates focus to my Avanti and I'll be buggered if I could tell the difference. The 8 speed thing is legitimate, but I'd say if you are just riding around flat terrain, 8 speed will do (they are more reliable too judging by internet diy-stats). On the slider dropouts, pretty much you don't want to remove a hub gear wheel off too often, it's a real pain and the drop outs are the least of your concerns. With my old bike I put super heavy duty Marathon Plus tyres on the back for this reason.danieljB wrote:Thanks for the replies guys. I did look into the focus but am led to believe they have a more aggressive geometry which I'm trying to get away from. And they only come in the 8 speed. Also with the slider dropouts doesn't that make it harder to get the wheel on and off?
but either way, if you really want 11 speed, you're back to the first 2 options.
Cushy dirt bike
No brakes bike
Ebike
Postby Espresso_ » Wed Aug 19, 2015 3:44 am
It will be - especially if you are running mudguards. But if you're trying to correctly tension a Gates belt drive, this will be the least of your worries. It's probably not a side-of-the-footpath job in either case.danieljB wrote:Also with the slider dropouts doesn't that make it harder to get the wheel on and off?
E
Postby Espresso_ » Wed Aug 19, 2015 3:47 am
E
Postby Calvin27 » Wed Aug 19, 2015 9:24 am
Yeah I meant back to the Avanti or Apollo, not the focus, unles their new range has a 11sp option.Espresso_ wrote:I thought the Avanti Inc 3 was 11spd?Calvin27 wrote:
E
Cushy dirt bike
No brakes bike
Ebike
- coyote
Postby coyote » Wed Aug 19, 2015 7:10 pm
Postby softy » Sun Aug 23, 2015 3:10 pm
I would say fit and comfort are also important, so check these out.
Postby tomness » Wed Sep 16, 2015 3:44 pm
If you have steep hills I would disagree. I have an inc 3 (11 speed) and my commute home has a solid climb that gets up to 16% gradient and I need my easiest gear. I certainly would not want to be doing that climb, on that bike, in a harder gear.coyote wrote:8 gears is more then enough, I ride around cairns and there is a couple of good hills. I allways take off in 4th gear and usually ride in 5th or 6th gear. If one is on flat road with a good tail wind one will get into 7th/8th and push 40 + kph. I see no need 11 spd.
The inc 3 is pretty heavy, especially in the rear end. I find it great for mostly flat rides of up to 15-20km. Unfortunately my commute is around 32km each way, with the aforementioned hill on the homeward leg, and to be honest I find the bike a slog over that distance. So if the weather is good I will always take my road bike. However I love that in the rain I can ride the Inc and not worry about having to clean or maintain the bike after the ride. It goes straight into the garage and I don't think about it until I need to commute in the rain again. That was the exact reason I got the bike for, and it fills that role admirably.
- mikedufty
Postby mikedufty » Wed Sep 16, 2015 4:26 pm
It actually has vertical drop outs, there is a screw adjust/sliding mechanism to move the dropouts for tension adjustment.
I have found the tension to be very finicky if you want to be able to pedal hard though, and even though the drop outs haven't moved, taking the wheel out and putting it back in often seems to require an adjustment. I expect the eccentric BB bikes have the same problem though.
I don't think I would buy one again, I have never been able to get the belt completely silent, and the hub gear can skip under heavy load. It has done 12,000km with no maintenance except tyres and brake pads and bleeding though. It's possible I'd notice the advantage more if I go back to a bike needing more maintenance.
