Ayup old vs new?
Ayup old vs new?
Postby jerrah » Wed Aug 26, 2015 8:44 am
Finding specific information on how much power my old units have is also difficult but I suspect they're in the 200 lumen range?
I emailed Ayup and asked if they had any comparison information comparing the old to new units and they were unable to provide any information or example photos.
Is there anyone on this forum who has used both the older generation lights and the newer lights and can give some impressions?
- queequeg
Re: Ayup old vs new?
Postby queequeg » Wed Aug 26, 2015 8:51 am
I could probably put together a comparison, but my old and new set have different optics so they cast a different spread of light. If you can ignore that, I'll see if I can find a suitable place to do a comparison. Personally, I am not fussed about Lumens, just about reliability.
My next commuter light will be Dynohub powered light so that I can ride beyond 6 hours without needing a spare battery.
Postby jerrah » Wed Aug 26, 2015 9:15 am
My current set (helmet narrow and bar flood) are still working great and the batteries suprisingly hold a good charge. I had the idea of upgrading the lamps if it's a significant increase in light and maybe donating them to a friend without lights.
A dynamo sounds like a good idea in theory but I grimace at the idea of pulling apart my perfectly good DT Swiss wheels to install a different hub. Maybe if I had a dedicated commuter bike, but my road bike is my everything that isn't mountain biking bike.
- cameronp
Postby cameronp » Wed Aug 26, 2015 10:41 am
I built a whole new wheel (actually a wheelset, I went overboard) to put dynamo lighting on my road bike. There's a thread on it here if you're interested. Cost was only slightly more than a set of Ay-Ups or equivalent lights from elsewhere. Subjectively, I can't notice the increased drag and weight, although I'm sure it's measurable. The lighting is fantastic - wide, bright shaped beam similar to a motorcycle headlight - as is the "just works" convenience. It's only been about a month since I fitted it, but no regrets.jerrah wrote:A dynamo sounds like a good idea in theory but I grimace at the idea of pulling apart my perfectly good DT Swiss wheels to install a different hub. Maybe if I had a dedicated commuter bike, but my road bike is my everything that isn't mountain biking bike.
- queequeg
Postby queequeg » Wed Aug 26, 2015 12:22 pm
The difference is pretty significant, and the loyalty discount you get from Ay-Up makes a new light $99 I think. I have four head units dispersed over three bikes, with my original 2008 light doing double duty as an head torch for working on the bike or going up in the roof.jerrah wrote:Thanks Queequeg, a comparison would be fantastic!
I have priced a Dynohub at $135, but have not looked at the lights yet. I have all the bits to make a new non-Dynamo front wheel, just need the check if the Dynohub PCD is the same or close enough to the hub I already have that I don't need to buy a whole new set of spokes. If it is, I will build up my new wheel as originally planned and then strip my current wheel and rebuild that as my Dynohub wheel.
I have a dedicated commuter bike, but you could just as easily build a new front wheel to use when commuting, and pull it off when you don't need the light. Of course, the light on a dedicated bike is usually also permanently attached to the front forks.
Postby Dr_Mutley » Thu Aug 27, 2015 6:33 pm
I know it's off topic, and not a old vs new comparison, but it may be time to go in a different direction?
Postby }SkOrPn--7 » Thu Aug 27, 2015 7:09 pm
Ricky
- HappyHumber
Postby HappyHumber » Thu Aug 27, 2015 7:11 pm
Even if as a back up set or hand-me-down to a family member or mate. They still have a residual quality value I think.
Postby Dr_Mutley » Thu Aug 27, 2015 8:05 pm
As skorpn7 eluded to, the $$/lumen value of ayups now is way behind the majority of others in the space. Ayups reliability / robustness however, is still up there with the other higher end brands.
- Drizt
Postby Drizt » Thu Aug 27, 2015 9:04 pm
For bar mounted lights I think it is best to look elsewhere. Some german shaped lights are better for such tasks
- queequeg
Postby queequeg » Thu Aug 27, 2015 9:53 pm
The only thing that annoys me as a commuter is the batteries, and on my road bike it is the inflexible mounting system (although with a carbon aerobar, any light is tricky to mount).
To simplify the commuter bike I will move to a Dynohub with something like an Edelux II Light and a USB charger. No more batteries!
The lumens arms race is just as silly as the old CPU clock speed wars with computers. How bright do you really need to go!
- kb
Postby kb » Fri Aug 28, 2015 7:03 am
Speaking as a shortsighted commuter who's getting on a bit, around 300 lumen.queequeg wrote: The lumens arms race is just as silly as the old CPU clock speed wars with computers. How bright do you really need to go!
Oh, I see. Rhetoric. Sorry
- cameronp
Postby cameronp » Fri Aug 28, 2015 10:51 am
I somewhat agree, although the brighter lights have more efficient LEDs in them (i.e. more light for a given amount of power), so the other advantage is longer battery life at sensible output levels.queequeg wrote:The lumens arms race is just as silly as the old CPU clock speed wars with computers. How bright do you really need to go!
- bychosis
Postby bychosis » Fri Aug 28, 2015 11:17 am
Postby jerrah » Fri Aug 28, 2015 11:51 am
One thing I have found in my online research is most of the reviews are borderline subjective and you'd really need to see them in action to make a determination.
That said when I first got my Ayup's they seemed really bright compared to what I was using previously but for one reason or the other they 'feel' less effective as time goes on. I seriously doubt they're putting out less light, maybe I'm less reckless as I'm older or better car headlights has raised my expectations?
I found and tried a current generation Ayup and whilst it is brighter than the older head unit it feels dwarfed by flood and range of the Light and Motion Urban 800 which is a self contained unit the size of a cigar... Obviously the Ayup would have a better run time and interchangable batteries but it did leave me feeling a bit disappointed that the Ayup's aren't massively competitive to what's effectively a commuter light.
Hmm, appears they have a new 850lm L&M Urban. That said it might be a bit dazzling to oncoming traffic with the round beam but I guess you could angle it down.
http://www.gizmag.com/review-light-and- ... ght/38303/
- queequeg
Postby queequeg » Fri Aug 28, 2015 1:21 pm
Ay-Up actually reduced the size of their big battery pack and gave it 3 power levels plus a flash mode. I run my commuter with the second generation batteries right now, which have hi/Lo flash. I run them on low power most of the time.cameronp wrote:I somewhat agree, although the brighter lights have more efficient LEDs in them (i.e. more light for a given amount of power), so the other advantage is longer battery life at sensible output levels.queequeg wrote:The lumens arms race is just as silly as the old CPU clock speed wars with computers. How bright do you really need to go!
