Commuter tyres - which ones now?
Postby Top_Bhoy » Wed Aug 26, 2015 6:42 pm
Although I am looking for a more 'slick' tyre, the other one under consideration is the Continental Contact II Road Bike Tyre which has a more definitive tread. Does anyone have an opinion after having used either the Continental Sport Contact II City Tyre or Continental Contact II City Tyre?
Any other alternatives to consider?
The tyres will be primarily used on cycle paths or roads for my commute to work. Most definitely no off-road usage.
Re: Commuter tyres - which ones now?
Postby carcharias » Wed Aug 26, 2015 8:04 pm
have not used thinner than 28C. I think this width is a good comfort/speed balance.
I have had a good run so far with Michelin City Bike tyres 28C x 700. They are $20- $23 from this link is broken. Not so light but great wear/grip so far. Only swapped the rear to the front recently (tyre has worn flat in the middle), bought the tyres early 2014.
They are good in wet, slow wearing, no punctures yet...! Has reflective material on side-walls. Cheap too.
Other Michy's that look good:
Michelin City Road Tyre- $19 (Reflective side-walls also) These look good to me.
Michelin Word Tour- $17- $19 Last for ages....a bit agricultural, but sometimes that's exactly what you need...
Michelin Classic Road Tyre- $15.50- $17 maybe fragile this one...Note: these prices don't include freight.
May help...
Cheers.
- biker jk
Postby biker jk » Wed Aug 26, 2015 8:23 pm
Postby SuperSix » Wed Aug 26, 2015 9:04 pm
I'm running them on a 29er hard tail which is set up as my commuter.
Postby Top_Bhoy » Wed Aug 26, 2015 10:14 pm
I'm great at giving the right advice but clearly not as good at listening to myself. I thought I should have changed them a couple of weeks back or at least buy a couple of new ones in preparation.....bit of tardiness on my part. On fixing the resultant puncture this evening it seems the top layer of rubber on one of the tyres has partly worn away. This has resulted in me inserting a piece of tubing underneath between inner tube and tyre to provide additional protection. I'll check it in the morning before setting out for work but I'll be doing well too reach the weekend on these tyres. Fingers crossed though .
- rodneycc
Postby rodneycc » Wed Aug 26, 2015 10:29 pm
Postby tez001 » Thu Aug 27, 2015 9:42 am
Im still trying different tyres to see which ones I get the most bang for buck. I'll probably step up to 28mm tyres next time the rears need replacing.
My rear always wears out a lot quicker due to my weight, rack and panniers.
Postby Top_Bhoy » Thu Aug 27, 2015 6:18 pm
I'll pass on the 38c Marathons Rodney; just a little too big. I'm probably going to go for a 32c size which so far have been good compromise for speed, comfort and an ability to handle the weight of the rear pannier.rodneycc wrote:Hey Chris, got a couple of Schwalbe Marathons almost new (just the Marathon not the Plus) in a 38c from the 29er Ive packed away which might be a little too wide for you but happy to throw them up there for your consideration if you want to make me a lowball offer [WHITE SMILING FACE]
- rodneycc
Postby rodneycc » Thu Aug 27, 2015 7:27 pm
- MattyK
Postby MattyK » Thu Aug 27, 2015 10:44 pm
- queequeg
Postby queequeg » Thu Aug 27, 2015 11:14 pm
I liked the weight reduction from the Marathon Plus, but the sidewalls are paper thin and I had a piece of glass tear it apart like tissue paper. $58 tyre binned. Then 6 weeks later the other supreme delaminated and had to be binned as well. $118 if tyre and barely 1800km between them.MattyK wrote:Marathon Supremes. Expensive yes. But last for ages (still have rear tread at about 8 or 9000 km), ride well, roll fast, look good, zero punctures.
I just rotated off my rear SMP tyre after 10,000km from new. $34 a tyre and they last for ages.
Postby tez001 » Fri Aug 28, 2015 8:23 am
I want to try SMP next time my tyres need replacing, where do you get them from? I thought they were around the $50 mark?queequeg wrote: I just rotated off my rear SMP tyre after 10,000km from new. $34 a tyre and they last for ages.
- queequeg
Postby queequeg » Fri Aug 28, 2015 8:37 am
c r c is where I buy them most of the time, although the exchange rate has knocked them back up. I bought my current set last year. According to my order history I paid $37.49 each, and the RRP was $64.49.tez001 wrote:I want to try SMP next time my tyres need replacing, where do you get them from? I thought they were around the $50 mark?queequeg wrote: I just rotated off my rear SMP tyre after 10,000km from new. $34 a tyre and they last for ages.
On c r c now, the RRP has increased to $76.99 and they are selling for $51.99.
Any time I see them on special I grab them.
Btw The Marathon Supreme is now $65.99, so they are still is a smaller increase over the $58 I paid for them.
- Thoglette
Postby Thoglette » Fri Aug 28, 2015 10:58 am
I'm running Continental Ultrasport which are a little more expensive, a little stickier but which also appear to be narrower than stamped (e.g. my 32mm are actually 28mm )
