More low range at low cost?
Re: More low range at low cost?
Postby OldBloke » Mon Sep 07, 2015 3:34 pm
If I'm wrong blame Tapatalk.
- find_bruce
- Moderator
Postby find_bruce » Mon Sep 07, 2015 4:20 pm
Out of stock.am50em wrote:http://www.this link is broken/au/e ... prod106885
I was in a similar position and what I did was spend the extra $8 and went with deore m590 48 36 26 was right for my needs, but it also comes in 44 32 22.
To be honest though, as long as the crank has removable chain-rings (mine didn't) I would spend $12.50 on a 22t & see if that solved the problem, being aware of the point sharkey makes
Postby ironhanglider » Mon Sep 07, 2015 4:48 pm
I've also experienced the issues Sharkey points out, and as mentioned that issue goes away if you are not using the smallest cogs. I always try to avoid the small ring unless I need it, and if I need it I won't be using the smallest cogs.
Yes, do a test ride first, and if on the real thing you find yourself caught in too big a gear when fully loaded in traffic, there is always the option of a controlled stop and walking that bit rather than risk a dodgy change. After a couple of rides you will know where the critical points are.
Cameron
- RonK
Postby RonK » Mon Sep 07, 2015 5:55 pm
Where you're going a fairing might be better value.Espresso_ wrote:I'm moving to a (very) hilly area.
Postby am50em » Mon Sep 07, 2015 10:23 pm
- Thoglette
Postby Thoglette » Mon Sep 07, 2015 11:15 pm
True - wheel rebuild will cost some $ if you're not doing it yourself but not as much as much as a fancy new derailleurs, cassette and front crank + rings. But only an option if you get the hub cheaplyEspresso_ wrote:Sure but I'm going to be need of a wheel rebuild, shifter for that hub etc, right?
Postby Espresso_ » Mon Jan 04, 2016 2:05 pm
Off to buy an Octalink BB to suit the new crankset.
E
Postby Espresso_ » Mon Jan 04, 2016 3:35 pm
OK so I stuffed up - as per previous post I guessed I had an Octalink when I actually had a square taper (which I have now removed from the bike).Duck! wrote:[Acera is available in both square taper and Octalink splined forms, just note which one you currently have & get a new one of the same type.
Easier and cheaper to just buy an Octalink BB than to return the crankset, but there are 10,000 types of Octalink bottom brackets. I have a 68mm shell, and the M361 (8 Speed) crankset. Any tips on which Shimano Octalink BB I need?
I'm guessing an 126mm, but I guessed last time and got that wrong...
E
- Duck!
Postby Duck! » Mon Jan 04, 2016 7:14 pm
EDIT: A dig through Shimano product specs tells me that you do indeed need a 68x126mm ES-series BB.
- Bentnose
Postby Bentnose » Fri Jan 08, 2016 6:04 pm
I sized a chain a little short as it was out of spec with a 26/36/48 and an 11-36 cassette, accidently managed to change into the 48-36 gear and locked up the whole drivetrain, had to take the back wheel off to free it up, when I undid the quick release the wheel virtually jumped off the bike. I've since added a 2nd quicklink and more links.
- Derny Driver
Postby Derny Driver » Fri Jan 08, 2016 7:58 pm
You're a good bloke Duck. So lucky to have you on this forum.Duck! wrote: EDIT: A dig through Shimano product specs tells me that you do indeed need a 68x126mm ES-series BB.
How many people have you bailed out over the years...
Postby Espresso_ » Fri Jan 08, 2016 9:14 pm
Yep - got a new chain lying around, but the cassette hasn't seen enough use since the last change for me to worry.Bentnose wrote:You may also need a new chain and cassette if your bike has had a bit of use, you'd notice it most on the small chainring.
E
- Thoglette
Postby Thoglette » Sat Jan 09, 2016 1:17 pm
Derny and I don't always agree but on this I'm 100% with him. Your posts are always worth reading.Derny Driver wrote:You're a good bloke Duck. So lucky to have you on this forum.
So let me also say "Thanks" - it's most appreciated.
- Duck!
Postby Duck! » Sat Jan 09, 2016 9:24 pm
One or two....Derny Driver wrote: How many people have you bailed out over the years...
Postby Espresso_ » Sun Feb 07, 2016 7:44 am
Ok all sorted, finally, and with much thanks to Duck!Duck! wrote:The box the crankset came in should tell you what length bottom bracket is needed. Any Shimano ES-series Octalink BB in the appropriate length will work.
After the bottom bracket incident, I found that the front derailleur wouldn't push the chain out enough to reliably engage the big ring. Nor would it shift reliably from the big to the middle ring.
So in another case of the women that swallowed a fly I bought a new Acera front derailleur, installed it and it works perfectly. And given these things cost $15, it was well worth it.
Low, low range achieved.
Thanks Duck
E
