Compact USB Front Flasher recommendations
- cjrich
Postby cjrich » Wed Oct 21, 2015 7:57 am
Looking to replace the Lezyne Femto on my roadie with something a little brighter and USB rechargeable for dawn / day rides. I generally ride with the flasher going even in broad daylight. Due to already crowded cockpit (Garmin and Rideye camera) I need something compact that will attach to the front of the bars. Been looking at the Knog Blinder 4 but apparently the rubber mounting straps are rubbish. The other I was looking at is the Lezyne Zecto but looks a bit chunky compared to the Knog.
Anyone used either of these lights or recommend something else?
CJ
- 2015 Cervelo R3
- 2013 Cannondale CAAD 8
- 2019 Marin Rift Zone 3
- rangersac
Re: Compact USB Front Flasher recommendations
Postby rangersac » Wed Oct 21, 2015 2:47 pm
Postby thecaptn » Wed Oct 21, 2015 3:11 pm
http://www.jensonusa.com/Niterider-Ligh ... -USB-Light" onclick="window.open(this.href);return false;
- rangersac
Postby rangersac » Wed Oct 21, 2015 3:33 pm
- Storm Boy
Postby Storm Boy » Wed Oct 21, 2015 4:39 pm
http://www.this link is broken.au/exposure-trace-front-light/" onclick="window.open(this.href);return false;
Regards,
SB
Postby caneye » Wed Oct 21, 2015 4:55 pm
+1 for Exposure Trace.Storm Boy wrote:You could use an Exposure Trace and mount it under the bars instead of on top. I bought the front/rear combination recently after owning a number of Knogs and am very happy with the Exposures.
Regards,
SB
- Small and fits easily on the front handlebar.
- tough Alu case
- USB-charging
- Derny Driver
Postby Derny Driver » Wed Oct 21, 2015 5:19 pm
You could get arrested
Postby thecaptn » Wed Oct 21, 2015 7:14 pm
http://www.merlincycles.com/niterider-l ... AtlE8P8HAQ" onclick="window.open(this.href);return false;
Postby softy » Thu Oct 22, 2015 5:19 pm
I have found bright front flashing has made a few motorists hesitate, reason why i like them.Derny Driver wrote:I don't recommend Front Flashing.
I am unaware of any code, act that makes these illegal, can you please reference. Cheers
Of course there is the chinese lights, i have had excellent use out of these, bit bigger with a seperate battery you carry on the top tube. I run 2000 lumens, 1200 lumens (medium selection) at night and flashing in the daylight.
Of course cheap.
The one i use fitted upside down on the bar.
http://m.lights-box.com/2u2-bike-light- ... dlight-set" onclick="window.open(this.href);return false;
Postby ironhanglider » Thu Oct 22, 2015 5:21 pm
You need to be in the gutter to appreciate DDs point of view.softy wrote:I have found bright front flashing has made a few motorists hesitate, reason why i like them.Derny Driver wrote:I don't recommend Front Flashing.
Cameron
Postby softy » Thu Oct 22, 2015 5:28 pm
hee hee, I thought this was a family forumironhanglider wrote:You need to be in the gutter to appreciate DDs point of view.softy wrote:I have found bright front flashing has made a few motorists hesitate, reason why i like them.Derny Driver wrote:I don't recommend Front Flashing.
Cameron
Postby Dean Learner » Thu Oct 22, 2015 7:20 pm
Anyone have experience with them?
- cjrich
Postby cjrich » Fri Oct 23, 2015 11:30 am
CJ
- 2015 Cervelo R3
- CXCommuter
Postby CXCommuter » Fri Oct 23, 2015 1:11 pm
Rear flashing could have even more unfortunate consequencesDerny Driver wrote:I don't recommend Front Flashing.
Postby carcharias » Mon Oct 26, 2015 6:36 pm
http://www.bikebug.com/cateye-volt-300- ... 29948.html" onclick="window.open(this.href);return false;
http://www.minoura.jp/english/accessory-e/sg400-e.html" onclick="window.open(this.href);return false;
Xeccon Link/Link Duo light from Cell bikes?
linkorama...
C.
Postby sir_camel » Mon Oct 26, 2015 7:39 pm
Probably not quite as much light throw as my Knog Road 3 but have had 3 or 4 straps break on that.
I really wanted a Specialized Flux but pretty sure they have increased in price by over $100 since their launch.
- cameronp
Postby cameronp » Mon Oct 26, 2015 7:57 pm
I have a Moon, is that the same thing?CXCommuter wrote:Rear flashing could have even more unfortunate consequences
Postby funkyblue » Tue Oct 27, 2015 6:25 pm
From their recommendations I purchased:
Front: Moon Mask - Which got 89% overall.
https://www.choice.com.au/products/tran ... mask-front" onclick="window.open(this.href);return false;
Back: Knog Blinder 1
https://www.choice.com.au/products/tran ... der-1-rear" onclick="window.open(this.href);return false;
Both have been excellent and changed via USB. The front is really bright great coverage. Worth taking a look.
Postby softy » Tue Oct 27, 2015 7:48 pm
Well that maybe be so, but i would recommend you don't get that moon wet. I tried heaps of this brand, great in the dry, but wet, they don't like. Run time i found not adequate either.funkyblue wrote:Choice Magazine recently reviewed 143 lights.
just my experience.
Postby funkyblue » Tue Oct 27, 2015 7:56 pm
I've had mine get a bit wet and it has lasted well over 4 hours on the highest brightness for me. I timed it over a good week
Postby softy » Tue Oct 27, 2015 8:10 pm
yes there is different models,funkyblue wrote:Really? That's interesting. Wonder if there is different models?
I tried quite a few rear and front lights, stuck with the brand and spent a fortune, had ones not working from new i had to exchange, rear light mounts breaking on there top end model. And function sequence going haywire after being in heavy rain.
Sold them all!
Now use a cheap china light, 2000 lumens, simple 3 settings, and it just is so reliable. On the back use PDW danger zone 1 watt simple three setting light, just keeps working. In all weather, that is what i like.
Postby carcharias » Sun Nov 15, 2015 2:30 pm
This test was done by (Bicycle Network) originally and Choice Magazine have made it clear that they displayed it ,but did not necessarily endorse it's findings and/or content.funkyblue wrote:Choice Magazine recently reviewed 143 lights.
I have found Moon brand OK, and the information about run-times and beam patterns to be pretty accurate.
Can't really make any claims about my Moon (or Serfas TSL-S500) in wet conditions though.
C.
Postby fat and old » Mon Nov 16, 2015 3:50 pm
Went through 2 rear moons....all 3 failed after severe rain exposure (+5 hrs) and I gave up on them too.
Light and motion front, bbb rear. Ugly, but they do what I want and have taken this year's winter. L&M has a crappy high power run time though. Flash/strobe setting is better....maybe 7 hrs? And you can't call it compact.....so I have nothing to offer
Postby paule11 » Sat Feb 27, 2016 10:38 pm
- Storm Boy
Postby Storm Boy » Mon Mar 07, 2016 11:54 am
http://www.ultimatesportsengineering.co ... ont-lights" onclick="window.open(this.href);return false;
Users browsing this forum: Google Feedfetcher
