Hi,
I'm in the process of converting an old Repco 27inch road bike to 700c single speed. Problem is, I need a 700c front wheel which is 91mm wide. The current standard 700c front wheel is too wide. Can anyone suggest a place or anyone willing to sell one? I'm in Melbourne.
Where to buy 700c 91mm wide front wheels?
- Cisco
Re: Where to buy 700c 91mm wide front wheels?
Postby Calvin27 » Tue Feb 02, 2016 1:25 pm
Edit, never mind.
Heavy road bike
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
Cushy dirt bike
No brakes bike
Ebike
Postby koshari » Tue Feb 02, 2016 1:44 pm
might be easier to replace the fork. iam sure you could pick up a 1" threaded steerer fork for nothing.
- Thoglette
Postby Thoglette » Tue Feb 02, 2016 2:59 pm
91mm is going to be very hard to find new for sane $$. (See Sheldon on frame spacing)Cisco wrote:I'm in the process of converting an old Repco 27inch road bike to 700c single speed. Problem is, I need a 700c front wheel which is 91mm wide. The current standard 700c front wheel is too wide.
Do you need to go 700C? There's still a large number of 27 x 1 to 1 1/4 tyres out there. And you can replace the old freewheel cluster with a single gog. You may wish to repack the bearings
If the rims/spokes are cactus you can re-lace the existing hubs into newer rims/spokes (presuming you match up the necessary spoke lengths) but it's a pile of work.
- RonK
Postby RonK » Tue Feb 02, 2016 5:01 pm
Surely cold setting the fork would be the simplest solution?
- Thoglette
Postby Thoglette » Tue Feb 02, 2016 5:03 pm
Putting new tyres on the existing wheels would be the simplest solution Bruteforcing 100mm wheels in would be the second simplest. But you're looking at almost 5mm per side. You'll get some of that from thinner lock nuts and less spacers but most is going to be pretty brutalRonK wrote:Surely cold setting the fork would be the simplest solution?
Postby nezumi » Tue Feb 02, 2016 10:22 pm
Yeah - when I first read this I was thinking rim width, rather than hub spacing.
I wondered why you needed a fatbike rim for a roadie.
2014 Merida Cyclo Cross 4
2015 Merida Scultura 5000
- Cisco
Postby Cisco » Mon Feb 08, 2016 10:08 pm
Hi all,
Thanks for the ideas, I ended up buying 1inch threaded 700c forks, life is good again!
Thanks again!
Thanks again!
