Distribution of Scicon Aerocomfort 2.0
Postby billy70 » Wed Jun 29, 2016 5:54 am
Discounting sales can often then be reduced. For example, PBK are running a price in the low $500's but I'm wondering if that's now reasonable?
Any advice?
- MichaelB
Re: Distribution of Scicon Aerocomfort 2.0
Postby MichaelB » Wed Jun 29, 2016 12:32 pm
The bag is top quality and even comes with a bag full of bits like padding rolls (for where the straps hold the bike down), skewers to hold the bike in the frame, a spare castor and a mini-pump for re-inflating the tyres.
Even when unboxing the bag, packing the bike for the 1st time and taking pics, it took me about 15 min. Still even had the winter fenders on the bike !!!!
For me (my mate coming with me is using a hard case supplied by a fellow BNMA mamber as a loaner), the HUGE benefit is that all that has to be removed is the wheels. I can even leave my Garmin on ! This will yield huge benefits at the other end by being able to rinding within 5 min of arriving. It will take longer to change into riding gear. My mate will have to remove pedals, bars from stem, and remove RD - none of that with the Aerocomfort.
Another huge advantage is that it then folds down to a smaller package for when you do internal travel by car. The Aerocomfort can probably even be packed inside the other hardcase !!
Quality is also there.
For a laugh, and a show of how quick it can be done, here a loo at the Scicon World Bike Packing Championships
Michael B
Postby dalai47 » Wed Jun 29, 2016 5:21 pm
Regardless what the manufacturer suggests, remove the derailleur AND buy a spare hanger now! Would be nothing worse than getting there and not being able to ride. Being smug at the minimal disassembly not could backfire drastically on arrival... Baggage handlers are very adept at breaking the unbreakable!MichaelB wrote:My mate will have to remove pedals, bars from stem, and remove RD - none of that with the Aerocomfort.
- biker jk
Postby biker jk » Wed Jun 29, 2016 5:26 pm
I have the Aerocomfort 1.0 version and it came with a steel derailleur protector. There's no need to remove the derailleur. The weak point in the bag is that the shifters can be bumped. I use a section of PVC pipe across the top of the bag at the front, along with some padding, which prevents the shifters from being knocked.dalai47 wrote:Regardless what the manufacturer suggests, remove the derailleur AND buy a spare hanger now! Would be nothing worse than getting there and not being able to ride. Being smug at the minimal disassembly not could backfire drastically on arrival... Baggage handlers are very adept at breaking the unbreakable!MichaelB wrote:My mate will have to remove pedals, bars from stem, and remove RD - none of that with the Aerocomfort.
Postby dalai47 » Wed Jun 29, 2016 9:39 pm
Having sat enough times in the window seat watching the baggage handlers practising for the next highland games, I still take it off regardless...biker jk wrote:I have the Aerocomfort 1.0 version and it came with a steel derailleur protector. There's no need to remove the derailleur..
- Ross
Postby Ross » Thu Jun 30, 2016 6:43 am
- MichaelB
Postby MichaelB » Thu Jun 30, 2016 9:34 am
I have a spare hanger, and will take that with me, great idea.
There is a very substantial metal frame that goes over the RD, and there is also the frame there, so will probably not remove RD.
The tip re the PVC pipe between the shifters is also good - have plenty of suitable pipe at home as well. Will do. Thanks biker jk
re the metal frame inside - it is just the base that is metal, and the metal extension for the fork mount is removable. Doesn't fold down to nothing, but is almost medium duffle bag size.
Postby billy70 » Thu Jun 30, 2016 11:22 am
Postby dalai47 » Thu Jun 30, 2016 11:38 am
- queequeg
Postby queequeg » Thu Jun 30, 2016 2:48 pm
This is what is looked like after it arrived:-
https://www.facebook.com/photo.php?fbid ... =3&theater
- MichaelB
Postby MichaelB » Thu Jun 30, 2016 4:09 pm
What does it look like and end result ?
Postby dalai47 » Thu Jun 30, 2016 6:39 pm
He was lucky. Only bag torn and handlebar snapped on the drops one side.MichaelB wrote:Can't see as i can't access farcebook from work.
Which is why I went with the Polaris EVA bike pod. Close to the weight of a soft bag, close to the protection of a hard case... Been in the holds of dozens of planes with only one issue so far*. And that includes being rummaged through and poorly repacked by TSA officials on entering the US.
*Sending coil inside my SRM cranks were damaged on the return from the States! Must have taken quite a drop to do that and the case plus the rest of the contents were fine.
Postby Patt0 » Thu Jun 30, 2016 9:50 pm
https://imgur.com/a/g3sKY
- MichaelB
Postby MichaelB » Fri Jul 01, 2016 8:55 am
100% correct. That's what you have insurance for.Patt0 wrote:Nothing is invincible....
- biker jk
Postby biker jk » Fri Jul 01, 2016 9:22 am
Postby dalai47 » Fri Jul 01, 2016 11:44 am
- queequeg
Postby queequeg » Fri Jul 01, 2016 11:46 am
I can grab the photo, but since Tapatalk is gone I have nowhere to host my photosMichaelB wrote:Can't see as i can't access farcebook from work.
Basically his carbon bars got stomped on, but the damage was hidden under the bar tape and he didn't find out until riding it. Needed a new set of $300 bars and has indicated he will using a hard case from now on.
I'm heading to Europe next year so I am looking at bike boxes too. I'm not keen on the soft case ones as I have seen first hand how baggage handlers work.
Postby Patt0 » Sat Jul 02, 2016 10:27 pm
Here it is after car travel https://i.imgur.com/eau2aT2.jpg
All the bubble wrap is used for plane travel.
Basically just the bike sack, 5mm corflute sides and a pvc pipe base to mount the frame. 7kg including 1kg bubble wrap. I didn't have time to put on wheels, but have a donor pram that has some nice ones.
- MichaelB
Postby MichaelB » Sun Jul 03, 2016 10:38 am
I'm wondering whether to bother or just put the discs on the inside of the bag.
A bent disc will be a PITA to fix
Postby Patt0 » Sun Jul 03, 2016 5:08 pm
- Ross
Postby Ross » Mon Jul 04, 2016 7:01 am
http://www.probikekit.com.au/brands/scicon.list
Torpedo7 also do their own version, considerably cheaper than genuine Scicon
http://www.torpedo7.com.au/products/T7B ... o-bike-bag
Actually $100 cheaper if you buy it through eBay if you aren't a club member
http://www.ebay.com.au/itm/TORPEDO7-Jet ... Swx-9Ww9C8
- MichaelB
Postby MichaelB » Tue Jul 05, 2016 9:23 am
All up weighed in at 18.8kg
3 more sleeps
Postby Rex » Fri Jul 15, 2016 1:58 pm
Weighed bang on 30kg
Shifters got bumped in on both legs.
And the plastic disc on the side of the bag got ripped off when coming home :/
Took the rear mech and chain off for both legs also.
Bought it $380 2nd hand, sold it for $350 when I got back
Postby hooman » Fri Jul 15, 2016 8:56 pm
It's in Kensington, Sydney.
Regards, Hooman
- AUbicycles
- Site Admin
Postby AUbicycles » Fri Jul 15, 2016 11:47 pm
A technique for increasing strength is rolling cardboard into tubes for lateral bracing.
Scicon are selling directly to Australia with free shipping and currently have a discount.
