Yep, it fits fine. Forget I ever mentioned it. #facepalmhamishm wrote:And if I'm not mistaken my 10 speed SRAM equipped mountain bike has the same spacing so I should be able to check it there.
road disc brakes
Re: road disc brakes
Postby hamishm » Tue Sep 20, 2016 11:35 am
Postby hamishm » Thu Sep 29, 2016 3:46 pm
Postby hamishm » Tue Oct 04, 2016 10:13 pm
80 pages of dealer manual for the brake setup though?! Be careful of the olives?! That's definitely going to the shop for professional assembly.
- MichaelB
Postby MichaelB » Wed Oct 05, 2016 9:26 am
It's not really that hard.hamishm wrote:.....
Have a read of the manual, look at the bits, have a play (without tightening), ask some questions, and then do it.
There are a couple of tools that may be useful, but not essential (like a proper hose cutter).
It's pretty easy really .....
Been there and done that, several times (different systems on different bikes)
- Duck!
Postby Duck! » Wed Oct 05, 2016 2:10 pm
Just make sure the end of the hose is properly located in the connector (Shimano's road hydro brake levers have a short permanently fitted hose with a connector at the end, rather than the normal hose going all the way from caliper to lever) before tightening the compression nut to crimp the olive on. You do need to get a bit brutal on the nut; there is a fair bit of resistance when tightening it, because it needs to compress the olive. Don't just tighten the nut until it feels firm; work through the resistance until it actually stops.
Postby hamishm » Tue Feb 28, 2017 1:58 pm
Now I need a rear wheel. Can't get the Crosslight separately. Should I just get a Shimano RX31, one of the few available individually?
- Duck!
Postby Duck! » Tue Feb 28, 2017 2:30 pm
Postby hamishm » Tue Feb 28, 2017 2:41 pm
It's the rear from these factory wheels: http://www.kinesisbikes.co.uk/Catalogue ... lincher-V4Duck! wrote:Is it not possible to lace a new rim on? Mavic usually aren'r bad with spares. Or is it too badly gone?
I have no idea what the hub is. It was only a $400-$450ish pair of wheels, do you think it would be cost effective?
- MichaelB
Postby MichaelB » Tue Feb 28, 2017 3:46 pm
Even delivered in 4 working days !!
Postby hamishm » Tue Feb 28, 2017 5:07 pm
I see both R 23 and R 32 listed, but both out of stock and both thru-axle. I need 135mm QR and it's not very clear from the descriptions whether you get the appropriate bits and pieces to convert it. Thanks though.MichaelB wrote:I got a DT Swiss one separate from wiggle at a good price.
- MichaelB
Postby hamishm » Tue Feb 28, 2017 5:33 pm
Which one did you get ?MichaelB wrote:Yep, all the end caps came with it
- MichaelB
Postby MichaelB » Wed Mar 01, 2017 9:33 am
Postby hamishm » Wed Mar 01, 2017 9:50 am
Given that the driver destroyed the rear of my $440 Crosslight pair, I think I'm owed more than $150-$180 for a replacement (which is the typical price of an R24 or an RX31).
Postby ball bearing » Wed Mar 01, 2017 10:09 am
- MichaelB
Postby MichaelB » Wed Mar 01, 2017 12:54 pm
The diff from R24 to the R32 is rim depth only from what I can remember. The decals came off easilyhamishm wrote:Nice. Wiggle out of stock unfortunately although bike24 has them. I can't really tell the difference between the R23, R24 and R32 from the DT Swiss web site, apart from money and a reduced weight limit on some.
I rode with the alloy shimano ones (RX31) on a Polygon bike, and whilst heaver than the DT, they were rock solid for the time I rode the bike.
Postby hamishm » Thu Mar 16, 2017 12:43 pm
