Hi All,
I need a towball mounted bike-rack that can coexist with my rear-mounted spare tyre. I have narrowed it down to the 2 below but I have a question about the difference and am hoping to get clarification from anyone who has used either of them:
1. http://www.realsmart.com.au/bicycle-bik ... ilver.html
2. http://www.crazysales.com.au/online-bic ... 00871.html
The first one says “24mm Spanner required to mount or dismount the bike carrier”. The second one doesn’t and has a different towball mounting mechanism.
If anyone has used the second one, can you please confirm that you don’t need a spanner to add/remove the carrier? Or, if you have used the first one, do you have view on whether it’s a pain to use a spanner each time you add/remove the rack?
Thanks in advance for any advice you guys can give,
Cory
Easiest towball mounted bike-rack (tray type)
- IamGroot
Re: Easiest towball mounted bike-rack (tray type)
Postby IamGroot » Sat Nov 26, 2016 4:47 am
This is the one I use, very quick and easy to mount and I've even welded the A frame rack mounting point to my tow ball tongue mount which has no effect on the towing of our camper trailer. You could do the same but I think you might need a longer tongue, is yours one of the with the square slidey setups for 4wd's. Previous to this setup I had one sort of like the ones in your attachments which were a pain in the bum. The only difference to my setup is now I've made a wiring harness so to have a set of tail lights that strap onto the rear bikes for when travelling.
Postby clee20121970 » Sat Nov 26, 2016 11:46 am
Yes I have the square hitch but the tow ball attachment is jammed in there. Been trying to get it out for a month now and have given up so can only use a tow ball mount. Plus, the tow ball is under the spare tyre. That's why Im thinking about a detachable tray-type rack.
- IamGroot
Postby IamGroot » Wed Nov 30, 2016 1:58 am
clee20121970 wrote:Yes I have the square hitch but the tow ball attachment is jammed in there. Been trying to get it out for a month now and have given up so can only use a tow ball mount. Plus, the tow ball is under the spare tyre. That's why Im thinking about a detachable tray-type rack.
Thats gotta be a pain having the hitch part stuck, an easy fix would be to remove the complete tow bar and see if an engineering type place can dislodge the hitch, you know maybe heat and a hydraulic press.
Postby clee20121970 » Wed Nov 30, 2016 10:28 am
Tell me about it. Though it has been entertaining watching the youtube videos of folk removing stuck hitches. Lots of dudes chaining their towballs up to trees and gunning it.Thats gotta be a pain having the hitch part stuck,
- IamGroot
Postby IamGroot » Sat Dec 03, 2016 12:00 pm
I'm off to YouTube that to : )
