Q: Advice on roadie shoes please
Postby enduro2 » Tue Nov 29, 2016 1:34 am
Tonight I bought a set of these:
Shimano Ultegra 6800 SPD-SL Pedals
Can anyone provide and advise on shoes or what I should be looking for?
I'm it Perth WA and do about 70km over thre days right now but hope to raise that in the short term..
Re: Q: Advice on roadie does please
Postby mmel » Tue Nov 29, 2016 9:15 am
Depends what your goals are but unless you are racing with support I would always consider MTB-style or shoes you can walk on over ballerina glass slippers.
Postby stoogey » Tue Nov 29, 2016 9:25 am
the 2 bolt hole pattern ones are for SPD pedals (mountain bike)
have fun learning to clip in and walk :p
- jules21
Re: Q: Advice on roadie shoes please
Postby jules21 » Tue Nov 29, 2016 11:02 am
Postby enduro2 » Tue Nov 29, 2016 11:19 am
I clip in and walk fine with those but clearly road shoes are stiffer and apparently have prouder cleats and little heel.
- g-boaf
Postby g-boaf » Tue Nov 29, 2016 11:27 am
http://www.koolkovers.us/products.html
I use those. The shoes I use have little pads on the back of the soles that you can replace, those make walking a bit easier, but going down stairs is pretty dodgy. Edit: Hmm, Shimano does those covers too: http://www.this link is broken.au/shimano-spd-sl ... at-covers/
As for cleats, I'm using the Shimano blue cleats.
Postby hamishm » Tue Nov 29, 2016 11:42 am
I've never bothered with shoe covers for SPD-SL cleats. You can walk in them fine without covers.
- Derny Driver
Postby Derny Driver » Tue Nov 29, 2016 12:37 pm
- g-boaf
Postby g-boaf » Tue Nov 29, 2016 12:47 pm
You can, but it tends to mess up the cleats if you do it too often. Otherwise, love the S-Works shoes I have, they are great. Don't have to walk in them too much, unless of course the elevators break down, which seems to be more and more now. Thank heavens I'm on a lower floor and don't have too many flights of stairs to use.hamishm wrote:Flexible soles leads to sore arches on long rides. You want as stiff as you can afford.
- Duck!
Postby Duck! » Tue Nov 29, 2016 2:32 pm
The coloured bits are designed to be walked on - you don't start wearing out the critical engagement bits of the cleats until after the coloured pads are worn off.hamishm wrote: I've never bothered with shoe covers for SPD-SL cleats. You can walk in them fine without covers.
- AUbicycles
- Site Admin
Postby AUbicycles » Wed Nov 30, 2016 8:05 am
Try on different shoes at bike shops to find one in your price range which fits - comfort is crucial. The price differences between different models for one brand of shoe are often reflected in the material for sole of the shoe (Nylon - Nylon Composite - Carbon) fastening systems, material for the upper and design.
On bicycles.net.au I have a few cycle shoe reviews which generally try and cover the important factors, so are a good reference to know what is important for you and what to look out for.
Christopher
Postby owly » Wed Nov 30, 2016 12:09 pm
Don't let someone sell you shoes you're not quite sure of.
You may also want to go down the road of purchasing/swapping out the insole, for one which fits your foot/arch best. Getting that right helps a lot with ride comfort also.
If you have a narrow-width foot, or a wide/flat foot shape, I could suggest some stores in Perth which carry brands suitable.
Postby enduro2 » Wed Dec 21, 2016 2:22 am
I ended up purchasing Shimano RP5 shoes (link below) which I am very happy with. The fit is excellent the sole well stiff enough for my ride and I couldn't fault them after a few weeks riding up to 50km on warm 25C mornings.
Walking in them is actually a bit easier that in my Lake SPD fited MTB shoes which is contrary to what some might believe. You wouldn't want to walk home in them, but walking isn't difficult. I've worn high heels before (for fancy dress) and that was bloody hard.
http://www.shimano-lifestylegear.com/gl ... /index.php
Postby Jawa » Wed Dec 21, 2016 8:41 am
- Tim
Postby Tim » Wed Dec 21, 2016 9:17 am
I've just 'updated' to $65.00 Shimano RO78, plastic sole, synthetic upper, 3 strap shoes, very similar to the old ones and expect them to last as well.
The soles on both shoes barely flex, admittedly not as stiff as carbon soles, but who cares about a couple of Watts power loss, not me.
They fit firmly, are comfortable and I hope to match the earlier shoe's mileage of 10-12,000km's per year.
- MattyK
Postby MattyK » Wed Dec 21, 2016 9:46 am
- Tim
Postby Tim » Wed Dec 21, 2016 10:03 am
Certainly doesn't make any difference to my performance.MattyK wrote:Has anyone actually (scientifically) demonstrated whether shoe stiffness makes any difference to performance?
I'd be slower in flashy shoes, admiring my own feet with each rotation.
I'd probably ride into a tree.
Postby hamishm » Thu Dec 22, 2016 10:16 am
Dunno about performance, but flexy shoes make my arches ache on a long ride.MattyK wrote:Has anyone actually (scientifically) demonstrated whether shoe stiffness makes any difference to performance?
Logically, any energy you put into flexing the soles is energy that isn't going in to the pedals.
- MattyK
Postby MattyK » Thu Dec 22, 2016 10:35 am
I just don't see how that applies when the pedal spindle is (more or less) under the ball of your foot, and your foot is hinged at the ankle. Maybe I'm simplifying the model of a foot to a two-point contact (ball and heel) and if you ride with a mid-foot cleat then you'd be bending the sole of the shoe around those two contact points, with some losses occurring through flex.
The only scientific study google found quickly for me was about how stiffer shoes increase the contact pressure under your foot, with potential negative consequences if you have foot problems...
As far as I can tell, as long as the "patch" of sole that roughly corresponds to the area of the ball of your foot is stiff/supportive, then you shouldn't need any support at the heel at all, because you're not going to bend that part of the shoe anyway. (I'm ignoring pulling up/back through the shoe that a stiff heel cup might help with when sprinting/climbing
I dunno, maybe I'm wrong, and the pros can push down hard with their toes, causing bending through the length of the sole? If the hard data existed, I'm sure the shoe manufacturers would be telling us how many watts their shoes saved... But they don't. Suspicious.
I just suspect it is one of these perception myths that is going to be busted soon, like how higher tyre pressure or super stiff frames make you faster...
Not that perception and "feel" is a bad thing, cycling should be about the enjoyment, and comfort should be a pretty high priority for everyone.
Postby hamishm » Thu Dec 22, 2016 12:58 pm
Are you arguing that stiff or less stiff soles are more comfortable?MattyK wrote:Not that perception and "feel" is a bad thing, cycling should be about the enjoyment, and comfort should be a pretty high priority for everyone.
- MattyK
Postby MattyK » Thu Dec 22, 2016 1:05 pm
Postby Jawa » Thu Dec 22, 2016 1:27 pm
Interesting .. to be specific mine were a pair of Shimano R065's. Maybe I had a dud pair, the heal part though was more self imposed.Tim wrote:^^Good advise above but, I've been wearing a pair of plastic soled Shimano, 3 velcro strap shoes for well over 5 years with no problems whatsoever.
With regards to the plastic vs carbon sole debate, wattage wise I think its one of those marginal gain sort of things. Though carbon does have dampening properties which does benefit
