Disc brake road bike
- trailgumby
Postby trailgumby » Tue Nov 29, 2016 10:09 pm
Requirements:
* Prefer carbon
* BB30 compatible, Rotor 3D+ cranks specifically
* thru-axles
* endurance geometry
The Specialized frames looked interesting but there was a question mark over whether the Q-factor of the 3D+ cranks was wide enough to prevent crank tips and/or heels from hitting on the frame.
Is there anything else out there that might fit the bill?
- RonK
Re: Disc brake road bike
Postby RonK » Wed Nov 30, 2016 7:14 am
- MichaelB
Postby MichaelB » Wed Nov 30, 2016 9:02 am
He's really happy and i'm very jealous.
Not 100% sure re the Rotor cranks though.
There are many options, just depends on budget.
Postby Calvin27 » Wed Nov 30, 2016 9:06 am
Yep the spesh standard is a real ball ache. Your issue is going to be that bb30 which limits it to mainl Spesh or Dale. An alternative to the caad is the synapse which is basically a very relaxed bike. Comes with TA and carbon with bb30.RonK wrote:Just a note of caution on Specialized. They use a proprietary thru axle design which limits wheel options to only Specialized wheels.
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
- biker jk
Postby biker jk » Wed Nov 30, 2016 10:09 am
12mm thru-axles, geometry not extreme, you can use a BB86 to BB30 adapter.
https://www.bikerumor.com/2016/09/26/eb ... -slx-disc/
http://wheelsmfg.com/bb86-to-30mm-sealed-bearing.html
Postby daft1024 » Wed Nov 30, 2016 11:39 am
The Cervelo R3 Disc fits most of the bill, but comes with bbright FSK SLK crankset not Rotor 3D+. I read somewhere that they have similar Q. I know the R-Series is marketed as a race bike, but in reality its an endurance fit. The racers run -17 stems to get low enough.
The Felt VR3 comes with Rotor 3D30 crankset in endurance geo. I'm guessing the 3D30 is not very far removed from the 3D+. I remember reading somewhere there was 1 mm difference in Q factor.
For what its worth my CX bike has normal QR axles and its hard to consistently get it lined up perfectly with the brake rotor every time. It's annoying enough for me not to want to remove the front wheel unless I really need to. The through axles on MTB's I've mucked around with don't seem to have the same issue - so I reckon you are onto something with looking for through axles.
I reckon I'd prefer through axles and as others have suggested swapping out to the preferred crankset if you can't get something that ticks all the boxes.
- baabaa
Postby baabaa » Wed Nov 30, 2016 12:24 pm
Postby hamishm » Wed Nov 30, 2016 2:37 pm
https://cyclingtips.com/2015/10/road-bi ... s-but-why/
http://forums.roadbikereview.com/bikes- ... 53406.html
For that matter, BB30. You must like squeaks
- trailgumby
Postby trailgumby » Wed Nov 30, 2016 8:51 pm
Thru axles noticeably improve steering accuracy and a sense of sure-footedness from both ends of the bike, based on my experience of it on mountain bikes. Plus, it seems to be the way the market is going. Make the trend your friend and all that.
Interesting feedback on Specialized, I have just had it passed onto me that a riding buddy has been having issues with clicking noises in his, that the LBS is having trouble resolving.
- Duck!
Postby Duck! » Wed Nov 30, 2016 9:26 pm
- silentbutdeadly
Postby silentbutdeadly » Thu Dec 01, 2016 3:05 pm
Carbon? Check
BB30? Not quite - PF30 which is SRAM's take on BB30 but with the right adapters it will take cranks that are BB30, BB386 or even 24 mm (my Niner runs a 24 mm crank thanks to a Wheels Manufacturing BB)
Thru-axles? Yep. 142x12 at the back and 15mm at the front.
Endurance geometry? Hmm...well...it is a CX bike so perhaps not. You might want to look at the RLT 9 instead? Except it's alloy with a carbon fork.
Postby matthewperk » Thu Dec 01, 2016 5:42 pm
I had initial requirements of:
Hydo disc
minimum 105 groupset
12m through axle (nice to have - but did look at some that didn't)
Carbon frame (or a really smooth ride)
Endurance geometry (again comfort was key)
Clearance for up to 32mm tyres (I wanted options).
From there i found the following:
Specialized Roubaix 2017 - I tried the 2016 but the difference in comfort is huge coming up to the new model.
Trek Domane - Really good comfort and tyre clearance, but very very pricey (even over Specialized).
Giant Defy 2017 - The 2017 got through axles. Not quite as smooth as the specialized or trek, but much cheaper. I didn't love the colour schemes though
Cannondale CAAD12 Disc - Because im riding a CAAD8 at the moment, I thought I'd see what a better alu frame rode like. It was smoother, but still not at the level of some others - similar to the defy though.
Cannondale SuperSix Evo Disc 2017 - It was in the store and so gave it a try. The ride position was great and comfort was better than the CAAD12 but not as good as the roubaix. Really liked the SuperSix though.
Cannondale Synapse - This had equal footing with the Specialized and Trek for comfort. Super smooth. The 2016 model was on sale for cheaper than the Giant, but again didn't love the colour scheme. I also found it to be a little too heads up and was recommended sizing down a frame so the front wasn't as tall and then stretch myself out further. If it hadn't been for the ride position I would have grabbed it despite the lack of through axles. But that ride position - I just wish it had been similar to the Supersix.
Cube Attain (http://www.99bikes.com.au/cube-attain-g ... h-red-2016) - this on the spec sheet had amazing value and ticked all the boxes. But one ride down the street showed me how stiff and uncompliant it was. Had it not been for the ride quality this was an absolute bargain. But i really wanted a smooth frame.
In the end I found an amazing black friday deal on a Kinesis Grandfondo Disc Ti, and have purchased a full ultegra hydo disc gearset and associated other bits for a similar price to what I would have paid for a Specialized. Hopefully it lives up to the hype of comfort to match the specialized or Synapse
Hope that helps!
Postby slowK » Thu Dec 01, 2016 8:54 pm
Thanks for the comparisons - very interesting. Will be keen to see how the Kinesis stacks up when you've built it up and ridden it.matthewperk wrote:I recently went through this search and did a lot of on bike tests. It's amazing feeling the difference in ride quality between some of them.
Hydo disc
Hope that helps!
- MichaelB
Postby MichaelB » Fri Dec 02, 2016 9:56 am
Did the Kinesis tick the boxes above ?matthewperk wrote: ....
In the end I found an amazing black friday deal on a Kinesis Grandfondo Disc Ti, ....
Hope it came with the 12mm TA rather than the 12m you specified ....
Dare I ask what the frame cost ?
- rodneycc
Postby rodneycc » Fri Dec 02, 2016 12:07 pm
Postby matthewperk » Fri Dec 02, 2016 12:12 pm
It ticked endurance geometry, 32mm clearance. All reviews report it as the most amazingly comfortable frame - but yet to confirm. Hydro brakes. Well given I could choose the gearset I was able to get full ultegra with a 11-32 casette and hydro brakes. Where everything else I was comparing had 105 or cheaped out with 105 brifters and partial ultegra.MichaelB wrote:Did the Kinesis tick the boxes above ?matthewperk wrote: ....
12mm through axle is the only thing it didn't tick. Being titanium though. If it does become the standard. I can always get it added if I really want it.
Being flat mount disc brake compatible was also a positive.
All up I'll be looking at just on $4k for a built bike with ultegra hydro disc.
Some like the Giant were good value at $3k, last year's synapse I could have got for $2700.
The Kinesis frame was $2600. $1000 for the ultegra disc gearset. Then all the sundry items like wheels, handlebars, Seat, cables etc.
Postby matthewperk » Fri Dec 02, 2016 12:15 pm
Yeh me too. My logic was even if I don't like the frame, I could on sell it pretty easily without much of a loss and build up one of the frames That I did like. But do it with ultegra rather than the 105 they would come with.rodneycc wrote:Man thats a gamble! You test rode all those amazing bikes and then settled on an untested frameset. Interesting... Hope it works out.
The other thing that sold me is I Love the look of Titanium frames... And well I'd hate to own a bike I want to hide from the living room coz of its looks.
- MichaelB
Postby MichaelB » Fri Dec 02, 2016 12:18 pm
Saw that Sigmasport in UK had it fro GBP1,000, but no idea re shipping.matthewperk wrote: ...
The Kinesis frame was $2600. ......
Should be a sweet bike
Postby matthewperk » Fri Dec 09, 2016 2:07 pm
I worked out! And looks amazing! As comfortable as the best I tried, and the geometry is perfect. Just sorting out minor elements of the fit at the moment. (saddle height, stem length and stack). Once all of that is done, I'll be laughing!rodneycc wrote:Man thats a gamble! You test rode all those amazing bikes and then settled on an untested frameset. Interesting... Hope it works out.
