change chainring or cassette
- panosk
Postby panosk » Sun Dec 04, 2016 2:46 pm
The problem is that at the crank length i want, only 53/39 is widely available.
My current set up is 52/36 with 11-28 cassette.
With that, i can go up donna buang without much trouble and use 28 cog at the most difficult parts of the climb.
So my dilemma is:
Should i change chain ring from 39 to 36, or change the cassette to 11-32 ?
- Tim
Re: change chainring or cassette
Postby Tim » Sun Dec 04, 2016 3:19 pm
I tried combining a 52 and 39. It didn't work very well, the chain hung between the two rings and wouldn't change smoothly.
Apparently some other miss-matched combinations do work but I don't know which.
Postby BJL » Sun Dec 04, 2016 7:57 pm
Interesting. There's only a 13 tooth gap between 52/39 but a 16 tooth gap between 50/34 & 52/36. Initially, I would have thought that the smaller difference might improve shifting.Tim wrote:The 9000 range of chainrings are designed to work as matched pairs ie. 50/34, 52/36, 52/38(is this new?) and 53/39.
I wonder if the angle of travel of the front derailleur is too steep for a 52/39 combo. IE - Derailleur ends up at a 'non-optimal' distance from one of the chainrings depending on position and tuning? I take it the 52/38 would be marginal but acceptable if this was the case.
- Tim
Postby Tim » Sun Dec 04, 2016 9:00 pm
It's more to do with the conical profile/shape of the ramping on the large ring.BJL wrote:I wonder if the angle of travel of the front derailleur is too steep for a 52/39 combo.
With a 52T large ring the bottom of the ramp is designed to drop the chain straight onto the top of a 36 or 38 small ring.
The 39T small ring teeth sit just too high above the bottom of the ramp causing the chain to hang in between the two rings. The side of the chain slides on the edge of the (turning) 39 ring.
Until today I'd not heard of the DA38T small rings paired with a 52T large ring. Might be worth a try one day.
- panosk
Postby panosk » Sun Dec 04, 2016 9:57 pm
- Derny Driver
Postby Derny Driver » Sun Dec 04, 2016 10:13 pm
36-28 is pretty close to 39-30
You could put an Ultegra 12-30. Cheapest and best option.
The ramping is different on those front rings. 36-53 will work but not real well.
- panosk
Postby panosk » Mon Dec 05, 2016 12:24 am
12-30 would be ideal but i am afraid there is no 11s cassette with that ratio.Derny Driver wrote:You wouldnt need a 32.
The closest i have found is 11-30 from sram and shimano 9100, at near 9000 crankset prices.
Postby dalai47 » Mon Dec 05, 2016 10:39 am
- Tim
Postby Tim » Mon Dec 05, 2016 10:43 am
110mm.dalai47 wrote:What is the BCD of the 9000 crankset? Will it even take a 36?
The new stuff fits everything from a 34 up to 55.
Postby dalai47 » Mon Dec 05, 2016 10:46 am
- jules21
Postby jules21 » Tue Dec 06, 2016 10:56 am
- Duck!
Postby Duck! » Tue Dec 06, 2016 1:49 pm
The 52T for pairing with 36T is a different ring to the 52T for 38T.Tim wrote: It's more to do with the conical profile/shape of the ramping on the large ring.
- Tim
Postby Tim » Tue Dec 06, 2016 4:30 pm
I was wondering about that.Duck! wrote:The 52T for pairing with 36T is a different ring to the 52T for 38T.
As I couldn't get a 52/39 pairing to work I wasn't sure how a small ring only one tooth smaller was going to work any better.
So the large ring ramping is different on the 52/36 compared to the 52/38 combination?
Bugger, that means if I wanted to try out a (cheapish) 38 ring I'd have to also buy an horribly expensive different 52 big ring.
Nope.
- Duck!
Postby Duck! » Tue Dec 06, 2016 7:01 pm
