Cycling socks - are they worth it?
Postby RobertL » Mon Dec 05, 2016 2:26 pm
I have not yet bought any "specialist" cycling socks. In my past, I have played other sports which have been a lot harder on my feet, and have learned the importance of correctly fitting shoes and socks. However, cycling seems really gentle on the feet, and I have just gotten by so far with some run of the mill sports socks.
Is it worth buying proper bike socks to replace them? What is the advantage?
- RonK
Re: Cycling socks - are they worth it?
Postby RonK » Mon Dec 05, 2016 2:51 pm
Some cyclists have even been known to cycle san socks.
Cycling shoes are generally quite a snug fit in order to maximise the transfer of power to the pedals, so socks tend to be thin, and unless you have the style sense of Lance Armstrong they are usually quite short.
Really all you need is something to prevent chafing and keep your feet cool and dry in summer and warm and dry in winter.
Postby nickdos » Mon Dec 05, 2016 4:24 pm
I do use cycling specific socks but it's more of an aesthetic issue although I do have a few pairs with bright orange stripes that I prefer for commuting in traffic as they make me feel 1% safer. I also tend to use thicker Merino cycling socks in winter as they keep my toes warmer (needed even with booties in Canberra) but I've also use merino hiking socks from Kathmandu as well.
Postby Top_Bhoy » Tue Dec 06, 2016 5:25 am
Postby Patt0 » Tue Dec 06, 2016 6:17 am
That said, for commuting, I just got some plain aldi socks for 14% of the price I paid for my cycling socks. See if the savings pan out.
- AUbicycles
- Site Admin
Postby AUbicycles » Tue Dec 06, 2016 6:40 am
Lifespan
Generally (but not always) a quality pair of socks will last longer and be better fitting. Where as a cheap pair may be cut and stitched closed at the end (tows) and have a seam which can be irritating, quality socks may not - or have better seams.
Fit / Comfort
Some of the premium socks have compression / elastic and in my case, I am not a fan of the compression effect and can't say that compression in cycling socks would even be a performance benefit - but a well fitting sock is more comfortable - particularly on long roads.
Breathability
Breathability is one area where quality socks set themself apart, with the material selection and weave it can mean for many riders the difference between sweaty feet and damp or wet socks and drier feet and dry socks.
Anti-bacterial
Another feature of many premium quality socks is the resistance to bacteria - some use nasty chemicals (which can also wash out over time) and some use material selection and yarns that are resistant. Because a wash in the washing machine may not kill all bacteria - socks that limit or kill off bacteria are a hygienic option.
Cycling Specific Socks
Good sports socks which are not cycling specific can be fine - as you go up the price ranges you will notice that there are sock constructions differences. While pedalling, your feet inside cycling shoes will move differently than if you play tennis and premium socks will introduce different sections with different elasticity, weaves and thicknesses.
Because each rider is different - has a different pedal strokes, different shoes, different requirement for comfort and performance and a different budget - if the right cycling sock for you is not cycling specific - go for it.
Cost
Premium quality cycling socks cost money and when you can get a pair of $2 kmart socks ($6 pack of three) verses $25 or $30 socks, this is a massive price difference, but so is the difference in quality.
However everyone has to decide for themselves and it is not a bad idea to test - if you celebrate Christmas, put a pair of premium socks on the list - but also try some midrange priced socks which are very easy to find at online shops.
I like premium socks and it is really the comfort I like over the cheap and nasty alternatives, plus I appreciate the longevity as cheap and nasties fall apart much faster - from a worn or even holey heel to decaying elastic. There are differences between the premium socks as well - as in the mid-range and budget segment.
And very important, I just wear the pricey cycling socks for cycling and not as general sports socks which will wear them out much faster.
Christopher
- Derny Driver
Postby Derny Driver » Tue Dec 06, 2016 10:53 am
- Derny Driver
Postby Derny Driver » Tue Dec 06, 2016 11:05 am
- RonK
Postby RonK » Tue Dec 06, 2016 11:33 am
Anymore than he wears tennis socks while cycling
Postby RobertL » Tue Dec 06, 2016 11:55 am
The "put them on the Christmas list" is pretty much exactly my plan at this stage.AUbicycles wrote:
...if you celebrate Christmas, put a pair of premium socks on the list - but also try some midrange priced socks which are very easy to find at online shops...
Christopher
Thanks for the input, one and all.
- silentC
Postby silentC » Tue Dec 06, 2016 11:56 am
- Me
- Derny Driver
Postby Derny Driver » Tue Dec 06, 2016 12:02 pm
ToucheRonK wrote:Unsurprisingly, Armstrong doesn't wear cycling socks when he is playing tennis.
Im just messing with you mate
Actually sock length decreases as people get older. My son and his mates look like they are wearing Bermuda walk socks when they kit up. In their 30's many cyclists opt for the Cav, Kittel and Boonen style. In the 40s they shrink down to the size of the ones Lance is wearing in your photo. And in the 50's and 60's, tennis sock style. Its a phenomenon known as' old age shrinkage'.
- silentC
Postby silentC » Tue Dec 06, 2016 12:11 pm
And look, you can get them with a Christmas logo:
https://www.bonds.com.au/mens-christmas ... n-01k.html
- Me
- CXCommuter
Postby CXCommuter » Tue Dec 06, 2016 12:36 pm
I find that cycling socks stay up better so have adopted longer cheap ones (i.e. when on sale) for use with my steel capped work boots after a long period of using thicker walking socks (explorer etc) which I found would not hold up and be annoying.Top_Bhoy wrote:You don't need them but probably due to the elastic element they contain, I find they hold up better and provide a better feel than my general sports socks. They're not too expensive, why not buy a pair or two and try them?
I have all lengths for days when I feel younger (longer) through to really short ones for when I feel old, naturally I have a lot of short socks for cycling.
- Comedian
Postby Comedian » Tue Dec 06, 2016 12:48 pm
http://www.theonion.com/article/cyclist ... ocks-18259Throughout the 10-minute conversation, Coseglia, who took up biking several months ago and rides an average of 6.5 miles two times per week, repeatedly drew comparisons between his special socks and regular socks, telling a politely nodding Washburn that the differences between the two are "night and day."
Postby minhyy » Tue Dec 06, 2016 1:52 pm
Postby Sparx » Tue Dec 06, 2016 2:04 pm
- P!N20
Postby P!N20 » Tue Dec 06, 2016 3:15 pm
- Duck!
Postby Duck! » Wed Dec 07, 2016 12:27 am
That doesn't distinguish "cycling" socks from any other decent quality sports socks.....P!N20 wrote:I find cycling socks 'breathe' better. Merino cycling socks are da bomb.
- rodneycc
Postby rodneycc » Wed Dec 07, 2016 9:08 am
Postby lone rider » Wed Dec 07, 2016 9:27 am
I was the same, used to just get bonds 3 for $10 or something thinking whats the difference. Then I bought a new full kit and matching socks and couldnt believe the difference. Now have draw full of cycling specific socks, they're always a good basket filler when you need $15 or something to get to free postage.rodneycc wrote:I use to be a "Socks are just Socks" person with most of my other sports and was the same when starting out cycling but since I bought some Ground Effect foot soldiers I'm a big convert to good cycling socks. The Foot soldiers are really well contoured to the foot with good compression and just a touch more thickness under the ball of the foot. The NZ merino wool is the best going around for comfort and wicking. I love them and rate as the best going around like your best quality favourite jersey. At $29 a pair plus postage not cheap but just love them.
- P!N20
Postby P!N20 » Wed Dec 07, 2016 9:48 am
Fair point, maybe I should wear my running socks cycling for comparison.Duck! wrote:That doesn't distinguish "cycling" socks from any other decent quality sports socks.....P!N20 wrote:I find cycling socks 'breathe' better. Merino cycling socks are da bomb.
Postby hamishm » Wed Dec 07, 2016 12:48 pm
Some sports socks are cotton. Can't imagine anything less comfortable once you sweat a bit.Duck! wrote:That doesn't distinguish "cycling" socks from any other decent quality sports socks.....
Postby CycloTron » Wed Dec 07, 2016 1:28 pm
Agree though that a lot of "sports" socks are actually made from cotton (e.g. ones recommended for kids' PE class, Bonds etc.) and would really suck for cycling.
- Duck!
Postby Duck! » Wed Dec 07, 2016 1:45 pm
Which makes no difference whether you're on foot or bike. Squelchy socks are squelchy socks.hamishm wrote:Some sports socks are cotton. Can't imagine anything less comfortable once you sweat a bit.Duck! wrote:That doesn't distinguish "cycling" socks from any other decent quality sports socks.....
