Compatibility between Tigra 4600 and Ultegra 6700
- marty_one
Postby marty_one » Wed Dec 07, 2016 11:06 am
I have my rear derailleur shifter break on me this morning riding into work. Fortunately I was less than 2km from the office when it happened. So I thought well if its broken just go and buy the Ultegra STI shifters (6700) to replace my current tiagra ones (4600).
The guy that I rang at a bike shop in Prahran victoria (yes that one) told me that the Ultegra shifters would not be compatibly with the tiagra derailleur's. That kinda got me thinking as the way I understand the derailleurs that they operate on a spring type mechanism and the indexing is all done in the shifters. Is this correct, was the bike shop talking out their proverbial *******?
EDIT: Correction I put the wrong model number of tiagra shifter, its actually a 4600. SO I guess that bike shop was correct.
Just Riding - Used to be called "My Journey to Triathlon"
- jules21
Re: Compatibility between Tigra 4700 and Ultegra 6700
Postby jules21 » Wed Dec 07, 2016 11:13 am
I assume you're staying with 10spd shifters. if there is any change in gear numbers (9/10/11) then the derailleur still isn't affected, but obviously you'd need to change the cassette and chain to match.
- biker jk
Postby biker jk » Wed Dec 07, 2016 11:21 am
Sorry but I'm confused, despite having my morning coffee. Why do you need new shifters if you broke your rear derailleur?marty_one wrote:Hi All,
I have my rear derailleur break on me this morning riding into work. Fortunately I was less than 2km from the office when it happened. So I thought well if its broken just go and buy the Ultegra STI shifters (6700) to replace my current tiagra ones (4700).
- marty_one
Postby marty_one » Wed Dec 07, 2016 11:33 am
Sorry fixed up the missing word!biker jk wrote:Sorry but I'm confused, despite having my morning coffee. Why do you need new shifters if you broke your rear derailleur?
Yes it is my rear derailleur shifter that broke.
- marty_one
Postby marty_one » Wed Dec 07, 2016 11:38 am
That's kinda what I thought. Yes will be sticking with 10 speed for the time being as I just put a brand new chain and cassette on my bike recently.jules21 wrote:I don't think that's right. the derailleur is just a 'slave' and obeys the shifters. it's compability is based on the pull ratio - how much cable pull at the shifters translates to derailleur movement. I think the Dura Ace ones have a slightly different pull ratio and can't be combined, but other Shimano shifters/derailleurs are all compatible.
Postby koshari » Wed Dec 07, 2016 1:27 pm
if thats the case i believe you wont be able to replace the tiagra 4700 with ultergra 6700 as tiagra 4700 on a 10 speed setup because tiagra 4700 shifters actually have the same pull ratio as 11 speed. this could suggest however you "MAY" be able to replace the shifters with ultegra 6800 and just lockout the 11th position for 10 speeds providing your tiagra 4700 RD is working still.
https://en.wikibooks.org/wiki/Bicycles/ ... Dimensions
Postby jasonc » Wed Dec 07, 2016 1:37 pm
- Duck!
Postby Duck! » Wed Dec 07, 2016 1:37 pm
Yes and no.koshari wrote:so you broke the tiagra 4700 shifter?
The information given by the shop is correct. 4700 Tiagra uses a different cable pull ratio to the other 10-sp. systems (and is the same as 11-sp.), which means the shifter pulls a different amount of cable to get the derailleur to move the required distance. 6700 shifters will not work with 4700 derailleurs.
Similarly, it is not possible to use 11-sp. shifters and tune out the extra gear; 11-sp. has tighter sprocket spacing than 10-sp, thus slightly shorter cable pull between index points, so won't tune properly.
Short version: you must use 4700 shifters with 4700 derailleurs.
- Duck!
Postby Duck! » Wed Dec 07, 2016 1:41 pm
As I said above. Although still 10-sp. 4700 shares its shifter and derailleur architecture with the 11-sp. family, which is not compatible with other 10-sp. shifters & derailleurs. The change in leverage ratio means the 4700 derailleur needs a longer cable pull to move the required distance than provided by older 10-sp. shifters.jules21 wrote:I don't think that's right. the derailleur is just a 'slave' and obeys the shifters. it's compability is based on the pull ratio - how much cable pull at the shifters translates to derailleur movement. I think the Dura Ace ones have a slightly different pull ratio and can't be combined, but other Shimano shifters/derailleurs are all compatible.
- MattyK
Postby MattyK » Wed Dec 07, 2016 2:20 pm
- marty_one
Postby marty_one » Wed Dec 07, 2016 2:22 pm
jasonc wrote:check the shimano compatibility document
Thanks for the link. Also, there is a correction here, my groupset is actually the 4600. The upside to this according to the compatibility matrix from the link above. The Ultegra shifter will probably work with my rear derailleur.
- cyclotaur
Postby cyclotaur » Wed Dec 07, 2016 2:52 pm
Can't see how you run 10 speed with 4600 shifters.marty_one wrote:...Also, there is a correction here, my groupset is actually the 4600. The upside to this according to the compatibility matrix from the link above. The Ultegra shifter will probably work with my rear derailleur.
Ditch the lot and get a full 4700 groupset - you won't know yourself.
My old blog - A bit of fun
- Duck!
Postby Duck! » Wed Dec 07, 2016 2:58 pm
- Duck!
Postby Duck! » Wed Dec 07, 2016 3:00 pm
4600 is 10-sp. The shifters are rebadged 7800 Dura-Ace.cyclotaur wrote:Can't see how you run 10 speed with 4600 shifters.marty_one wrote:...Also, there is a correction here, my groupset is actually the 4600. The upside to this according to the compatibility matrix from the link above. The Ultegra shifter will probably work with my rear derailleur.
- cyclotaur
Postby cyclotaur » Wed Dec 07, 2016 3:14 pm
Well I'm confused now !!Duck! wrote:4600 is 10-sp. The shifters are rebadged 7800 Dura-Ace.cyclotaur wrote:Can't see how you run 10 speed with 4600 shifters.marty_one wrote:...Also, there is a correction here, my groupset is actually the 4600. The upside to this according to the compatibility matrix from the link above. The Ultegra shifter will probably work with my rear derailleur.
So 4600 and 4700 are both 10 speed, but incompatible due to pull ratios.
....and my old Tiagra 9-speed - was that 4500 then ?
Better check that Shimano compatibility link....
- Duck!
Postby Duck! » Wed Dec 07, 2016 3:26 pm
Postby koshari » Wed Dec 07, 2016 4:47 pm
indeedcyclotaur wrote: Well I'm confused now !!
Code: Select all
group speeds cable pull RD ratio cassette pitch
4500 9 2.5 1.7 4.35
4600 10 2.3 1.7 3.95
4700 10 2.8 1.4 3.95
- marty_one
Re: Compatibility between Tigra 4600 and Ultegra 6700
Postby marty_one » Wed Dec 07, 2016 8:23 pm
Postby eeksll » Wed Dec 07, 2016 8:57 pm
Haven't had to look for shifters, but 10 speed cassettes and chains are cheap as chips. Just got some for my older road bike.
- Mulger bill
Postby Mulger bill » Wed Dec 07, 2016 9:08 pm
And they are amazing! Thanks for the heads up while I was speccing that buildDuck! wrote:4600 is 10-sp. The shifters are rebadged 7800 Dura-Ace.
- Duck!
Postby Duck! » Thu Dec 08, 2016 1:19 am
Correct, and in that regard the upgrade path is no different to the 8 -> 9 -> not-4700-10-sp. progression where all that's needed to gain the extra gear are chain, cassette & shifters, because the derailleurs talk the same pull ratio.eeksll wrote:guessing you can pair the 4700 with 11 speed 105/ultegra/.. shifters, so thats not quite a dead end there?
The only setup where 4700 is truly orphaned is TT/Tri conversion, as the rear derailleur won't play nicely with existing 10-sp. bar-end shifters, and although the 11-sp version uses the right pull ratio the index spacing is too close for use on 10-sp, and like 2nd-gen. 10-sp. can't be switched to friction mode.
- Duck!
Postby Duck! » Thu Dec 08, 2016 11:53 pm
What the charts don't show is the relationship between 7/8/9/10-sp, and road/MTB stuff.cyclotaur wrote: Better check that Shimano compatibility link....
Basically, ALL Shimano stuff road and MTB up to 9-sp, plus road 10-sp except 4700 Tiagra work on a common pull ratio of 1.7:1, meaning the rear derailleur moves 1.7mm for every 1mm of cable pulled, so all you need to match is the shifter and chain to the number of gears in the cassette, because any derailleur will work. Road 11-sp. & 4700 work on a 1.4: 1 ratio, which means more cable pull to achieve the required derailleur travel. At 1.2 & 1.1 respectively, MTB 10 & 11-sp. are their own families that don't play well with others.
Postby koshari » Fri Dec 09, 2016 9:01 am
Interestingly there is likely scope for using a set of tiagra 4700 shifters as a partial upgrade item with an 8 speed setup given that they share the cable pull per shift (AT) 2.8mm.Duck! wrote:What the charts don't show is the relationship between 7/8/9/10-sp, and road/MTB stuff.cyclotaur wrote: Better check that Shimano compatibility link....
- Mulger bill
Postby Mulger bill » Fri Dec 09, 2016 8:39 pm
So if I read this right, I can replace the dinged, straightened and almost flogged out 4500 long cage rear mech with a 4600 unit and just tune it to 9x with the limit screws?Duck! wrote:What the charts don't show is the relationship between 7/8/9/10-sp, and road/MTB stuff.cyclotaur wrote: Better check that Shimano compatibility link....
- Duck!
Postby Duck! » Fri Dec 09, 2016 9:23 pm
