Wheel weight
- techsupport
Re: Wheel weight
Postby techsupport » Wed Dec 28, 2016 8:22 pm
- A_P
Re: Wheel weight
Postby A_P » Wed Dec 28, 2016 8:51 pm
http://www.this link is broken/au/e ... p-prod1289
- techsupport
Re: Wheel weight
Postby techsupport » Wed Dec 28, 2016 9:47 pm
Report this post
Quote
this is considerably cheaper
Hi A_P,
Thanks for that, $15.95 with postage perfect!
- A_P
Re: Wheel weight
Postby A_P » Wed Dec 28, 2016 10:24 pm
- techsupport
Re: Wheel weight
Postby techsupport » Thu Dec 29, 2016 8:53 am
Is there a site for torque values for the components? Seat post, handlebar stem, freewheel cassette lock ring..
- Duck!
Re: Wheel weight
Postby Duck! » Thu Dec 29, 2016 1:35 pm
Unlikely, because they're specified by the individual component manufacturers. However, as a general guide seatposts are 5-8NM, stems 6-8NM onto the steerer and 6-8NM onto the handlebar for 2-bolt face plates & 5-6NM for 4-bolt, while cassettes are 40NM.techsupport wrote: Is there a site for torque values for the components? Seat post, handlebar stem, freewheel cassette lock ring..
- Bunged Knee
Re: Wheel weight
Postby Bunged Knee » Thu Dec 29, 2016 2:25 pm
+1 to Duck`s advice.techsupport wrote: Is there a site for torque values for the components? Seat post, handlebar stem, freewheel cassette lock ring..
And do not get these torque value info like this pic below.
- techsupport
Re: Wheel weight
Postby techsupport » Thu Dec 29, 2016 2:34 pm
- trailgumby
Re: Wheel weight
Postby trailgumby » Thu Dec 29, 2016 3:23 pm
Wow. A pro bike mechanic who actually uses a torque wrench.Duck! wrote:Unlikely, because they're specified by the individual component manufacturers. However, as a general guide seatposts are 5-8NM, stems 6-8NM onto the steerer and 6-8NM onto the handlebar for 2-bolt face plates & 5-6NM for 4-bolt, while cassettes are 40NM.techsupport wrote: Is there a site for torque values for the components? Seat post, handlebar stem, freewheel cassette lock ring..
Can we tempt you to move to Sydney?
- techsupport
Re: Wheel weight
Postby techsupport » Thu Dec 29, 2016 3:43 pm
All part of the learning curve LOVE CYCLING!
- Duck!
Re: Wheel weight
Postby Duck! » Thu Dec 29, 2016 10:24 pm
You won't find much there on that front, seeing as it's only the drive components on your bike that are made by Shimano.techsupport wrote: I will look up Shimano site for the rest if required.
- Duck!
Re: Wheel weight
Postby Duck! » Thu Dec 29, 2016 10:26 pm
trailgumby wrote:Wow. A pro bike mechanic who actually uses a torque wrench.Duck! wrote:Unlikely, because they're specified by the individual component manufacturers. However, as a general guide seatposts are 5-8NM, stems 6-8NM onto the steerer and 6-8NM onto the handlebar for 2-bolt face plates & 5-6NM for 4-bolt, while cassettes are 40NM.techsupport wrote: Is there a site for torque values for the components? Seat post, handlebar stem, freewheel cassette lock ring..
TG's dig wasn't aimed at you, it was pointed my way. And no, I can't be tempted to move to Squidney.techsupport wrote:LOL! I am in Sydney south west
- trailgumby
Re: Wheel weight
Postby trailgumby » Fri Dec 30, 2016 12:04 pm
Weeelll, it wasn't so much as a dig at you as at all the FIGJAM bike mechanics who reckon they're too good to be bothered with a torque wrench. Why would manufacturers go to the trouble and cost of etching the recommended torque on the component if they didn't intend you to take it seriously?Duck! wrote:TG's dig wasn't aimed at you, it was pointed my way. And no, I can't be tempted to move to Squidney.
What was aimed at you was the compliment that you're a very rare bird, a conscientious artisan..
Bummed that you won't come to Sydney but then what cyclist in their right mind would while this current government is in power?
- mikesbytes
Re: Wheel weight
Postby mikesbytes » Fri Dec 30, 2016 2:31 pm
Duck's guide to tension is about as good as it gets. Some components have the torque spec written on them. I've only seen figures written on the components that are the same as what Duck as written as the concern is usually not the component itself but what it is being bolted to, in particular CF.Duck! wrote:Unlikely, because they're specified by the individual component manufacturers. However, as a general guide seatposts are 5-8NM, stems 6-8NM onto the steerer and 6-8NM onto the handlebar for 2-bolt face plates & 5-6NM for 4-bolt, while cassettes are 40NM.techsupport wrote: Is there a site for torque values for the components? Seat post, handlebar stem, freewheel cassette lock ring..
- techsupport
Re: Wheel weight
Postby techsupport » Wed Jan 04, 2017 6:48 pm
- techsupport
Re: Wheel weight
Postby techsupport » Sat Jan 07, 2017 11:12 am
A change from standard to lightweight aero wheels with continental ultra sport (25c) and a 11/28 cassette. I managed to beat 72 pb's on Strava from previous rides, bike rides faster and smoother, I haven't tried 110PSI yet I have been riding on 100PSI and very happy with ride and performance of bike.
- Duck!
Re: Wheel weight
Postby Duck! » Sat Jan 07, 2017 12:55 pm
- techsupport
Re: Wheel weight
Postby techsupport » Sat Jan 07, 2017 2:40 pm
Duck! wrote:It's a misconception that higher pressure = faster unless you're riding on an incredibly smooth surface. So don't even consider 110in the 25s unless you're of considerable ballast. I'd stick with 100 tops in the rear, and drop the front to about 90.
Thanks Duck!Duck! wrote:It's a misconception that higher pressure = faster unless you're riding on an incredibly smooth surface. So don't even consider 110in the 25s unless you're of considerable ballast. I'd stick with 100 tops in the rear, and drop the front to about 90.
I will try 90 at the front, and I'll stay at max 100PSI.
Oh by the way on subject of pumps, is there a floor standing model you recommend?
- Duck!
Re: Wheel weight
Postby Duck! » Sat Jan 07, 2017 3:00 pm
Users browsing this forum: Amazon [Bot]
