52/34 chainring combo
Postby MattJB » Sun Jan 01, 2017 2:17 pm
I am thinking of changing my sram gear combo from a 52/36 to a 52/34 chainring. I run a 11/28 on the back. I mainly ride on the flat but do occasionally venture into the hills where I am not as young or strong as as I used to be. I know that the manufacturer says that it should not be done however I have read that it is achievable but I think that I might need a med RD to ensure that the small/small combo works.
Has anyone else tried it? If so how did you achieve it?
Re: 52/34 chainring combo
Postby AndrewCowley » Mon Jan 02, 2017 1:26 pm
Postby madmacca » Mon Jan 02, 2017 2:15 pm
Why not just put a 30 cassette on the back - 36/30 is actually a slightly lower ratio than 34/28? Replacing a cassette is normally much cheaper than new chainrings.MattJB wrote:Hi,
Even if 52/34 can be done, shifting won't be smooth, as the ramps and pins on the chainring won't be aligned.
- Strawburger
Postby Strawburger » Mon Jan 02, 2017 8:31 pm
You have to play around with the front derailleur to get it right, but once set it works, albeit a bit noisy on 34/11
- Bentnose
Postby Bentnose » Tue Jan 03, 2017 6:20 am
Postby madmacca » Tue Jan 03, 2017 10:02 am
A 52/11 will give a top speed of 60 kph (AT) 100 rpm, while 52/12 will give 55 kph. Given the OP says they are not as young and strong as they used to be, sacrificing the 11t cog to put a 30t on the other end of the cassette seems a reasonable option?Bentnose wrote:I can't stand the 34/50 combination (I have a 36/50 with a 12/28) I think you'd find an 18 tooth jump very annoying. By the way a 12/28 has a better range of easier gears than the 11/28. I was looking at changing to the 11/28 but when I looked at the different cogs compared to my 12/28 I figured it had too many big gaps at the easy end.
- Bentnose
Postby Bentnose » Tue Jan 03, 2017 8:30 pm
I think most of us can give the 11t cog away as we get older, holding onto our youth maybe? Seriously there aren't too many occasions when an 11t is warranted, if this means you can get a better spread at the easier end, great. A 12-30t may be the way to go for the OP.madmacca wrote:A 52/11 will give a top speed of 60 kph (AT) 100 rpm, while 52/12 will give 55 kph. Given the OP says they are not as young and strong as they used to be, sacrificing the 11t cog to put a 30t on the other end of the cassette seems a reasonable option?Bentnose wrote:I can't stand the 34/50 combination (I have a 36/50 with a 12/28) I think you'd find an 18 tooth jump very annoying. By the way a 12/28 has a better range of easier gears than the 11/28. I was looking at changing to the 11/28 but when I looked at the different cogs compared to my 12/28 I figured it had too many big gaps at the easy end.
Postby eeksll » Tue Jan 03, 2017 10:58 pm
I flirted with the idea of using the shimano cassette instead, however I could not find one from shimano at their normal cheap cost. The following info is from the shimano webiste.
The only cassettes starting at 12 are 12-25, with the exception of the 12-28 from the dura ace line and they are $$$
105
11-28, 11-32, 12-25
ultegra
11-23,11-25,12-25,11-28,11-32
dura ace
11-23T, 11-25T, 11-28T, 12-25T, 12-28T
Postby AndrewCowley » Tue Jan 03, 2017 11:58 pm
The OP doesn't say whether he's running a 10 or 11 speed set up. Whilst the above is correct for an 11 speed set up, in a 10 speed set up there is a Tiagra 12-28 with 12-13-14-15-17-19-21-23-25-28 cogs.eeksll wrote:The only cassettes starting at 12 are 12-25, with the exception of the 12-28 from the dura ace line and they are $$$
105
11-28, 11-32, 12-25
ultegra
dura ace
http://www.this link is broken/Shimano-CS- ... KgodasUB-Q
Postby Nads » Wed Jan 04, 2017 8:19 am
Apparently Shimano recommend no more than 16 tooth gap, but I have had no problems.
Postby madmacca » Wed Jan 04, 2017 10:08 am
SRAM make a number of 12+ cassettes, which will work with a shimano drivetrain.eeksll wrote:The only cassettes starting at 12 are 12-25, with the exception of the 12-28 from the dura ace line and they are $$$
105
11-28, 11-32, 12-25
ultegra
dura ace
Postby eeksll » Wed Jan 04, 2017 3:58 pm
Yes! I just got one those from wiggle for my old road bike/commuter for < $30. I think thats a fairly new ratio cause I have only just "discovered" that ratio. Ideally I'd like a 13 tooth minimum cog on this bike.AndrewCowley wrote: The OP doesn't say whether he's running a 10 or 11 speed set up. Whilst the above is correct for an 11 speed set up, in a 10 speed set up there is a Tiagra 12-28 with 12-13-14-15-17-19-21-23-25-28 cogs.
according to the SRAM website they don't make any in 11 speed cassette starting at 12.madmacca wrote:SRAM make a number of 12+ cassettes, which will work with a shimano drivetrain.
Its almost like they can't figure out what new cassette tooth to add for the extra cog on the 11 speed. The way I see it, if your on 10 speed dont bother upgrading to 11 speed unless you want a 11 tooth cassette cog or are willing to stump up for the Dura ace 12-28 cassette or the campag 12-29 cassette.
Postby AndrewCowley » Wed Jan 04, 2017 7:00 pm
For my 10 speed commuter I'd like something that goes like 28-26-24 down to maybe 12 or 13.
My other bike incidentally has a dura-ace 11-28.
- Bentnose
Postby Bentnose » Wed Jan 04, 2017 7:49 pm
This is exactly the 10 speed cassette I have on my bike, much better jumps than the 11-28, might just have to stick with 10 spd for now.AndrewCowley wrote: The OP doesn't say whether he's running a 10 or 11 speed set up. Whilst the above is correct for an 11 speed set up, in a 10 speed set up there is a Tiagra 12-28 with 12-13-14-15-17-19-21-23-25-28 cogs.
Postby hamishm » Wed Jan 04, 2017 9:39 pm
Also Ultegra 12-30. http://www.this link is broken/Shimano-Ult ... e-10-SpeedAndrewCowley wrote:in a 10 speed set up there is a Tiagra 12-28 with 12-13-14-15-17-19-21-23-25-28 cogs.
- Duck!
Postby Duck! » Sat Jan 07, 2017 3:23 pm
This. SRAM front shifting is pretty ordinary at the best of times; why make it worse with misaligned ramps.madmacca wrote:
- Bentnose
Postby Bentnose » Mon Jan 09, 2017 4:39 pm
Postby CKinnard » Mon Jan 09, 2017 5:06 pm
if you are getting on in age, no doubt 50 would suffice.
Postby rkelsen » Fri Jan 27, 2017 10:03 am
The question is: Do you really need the 52 tooth chanring?MattJB wrote:I am thinking of changing my sram gear combo from a 52/36 to a 52/34 chainring. I run a 11/28 on the back. I mainly ride on the flat but do occasionally venture into the hills where I am not as young or strong as as I used to be.
- Bentnose
Postby Bentnose » Mon Jan 30, 2017 12:10 pm
I was running a 48/11 big gear for years and never had an issue, my current 50/12 is a smaller gear and is very rarely an issue.rkelsen wrote:The question is: Do you really need the 52 tooth chanring?MattJB wrote:I am thinking of changing my sram gear combo from a 52/36 to a 52/34 chainring. I run a 11/28 on the back. I mainly ride on the flat but do occasionally venture into the hills where I am not as young or strong as as I used to be.
- Duck!
Postby Duck! » Mon Jan 30, 2017 2:00 pm
