Is a TCR really an upgrade??
Derny Driver
Re: Is a TCR really an upgrade??
Postby Derny Driver » Sun Jan 15, 2017 8:37 pm
You can take the bottom 2 spacers out and put them on top too
Defy The Odds
Postby Defy The Odds » Sun Jan 15, 2017 8:39 pm
Derny Driver wrote:You can take the bottom 2 spacers out and put them on top too
I was thinking to do the first two (the ones currently on the top) and then the other two if I feel I am ready. Thinking maybe removing all the spacers from the bottom might be too much of a drop off the bat.
What do you reckon?
Derny Driver
Postby Derny Driver » Sun Jan 15, 2017 8:46 pm
What do you reckon?
Yeah agree, good thinking
Defy The Odds
Postby Defy The Odds » Sun Jan 15, 2017 8:50 pm
What do you reckon?
Cheers mate
A_P
Postby A_P » Sun Jan 15, 2017 9:12 pm
this is my current setup,
seat is virtually level, its a new seat and im still playing with the angle a little.
bars / hoods are level.
im slowly reducing the stack height as my flexibility allows.
best to do small changes at a time, and give yourself a few weeks to adapt to decide if its right or not.
A_P
Postby A_P » Sun Jan 15, 2017 9:17 pm
Defy The Odds wrote: I tightened the stem cap bolt bit by bit to see if it would fix the issue but its tight as and still feels like there is play. Might be my imagination
did you tighten the cap bolt before or after the stem bolts?
Defy The Odds
Postby Defy The Odds » Sun Jan 15, 2017 9:30 pm
I think before. Does it matter ?
Defy The Odds
Postby Defy The Odds » Sun Jan 15, 2017 9:32 pm
A_P wrote:this is my current setup,
Everyone has different comfort levels..I found when the seat was level I would slide forward when the bars were angled down so tilting it slightly up took the pressure off the wrists/elbows for me
Defy The Odds
Postby Defy The Odds » Sun Jan 15, 2017 9:36 pm
I just noticed your bike looks like the Specialized twin version of mine :lol:
Same tool bidon, bottle :lol:
A_P
Postby A_P » Sun Jan 15, 2017 9:49 pm
You cant preload the headset bearings with the steerer bolts done up tight.
once you have tightened the steerer bolts you could undo the cap bolt without it coming loose.
tool bottles rock, the saddle bag is only used on long rides where water is scarce :)
MattyK
Postby MattyK » Sun Jan 15, 2017 10:12 pm
DtO: if it were my bike I would be stripping back the bar tape, and adjusting the bars until the ends of the drops were close to horizontal, or wherever gives the most comfortable position with hands in the drops. Then loosening off the hoods and moving them further up on the bars until they were about 5 degrees up from horizontal, or wherever the most comfortable hoods position is for you. A_P's bar position above is a good example.
g-boaf
Postby g-boaf » Sun Jan 15, 2017 10:19 pm
rodneycc wrote:Duck beat me to it. The way I look at it is the Propel is better for avg speeds over 30kms/h to get the aero benefits
What aero benefits would that be at 30km/h+? You'd want to be going 40km/h+ to get the benefits. And then if the rider gets lower on the bike and doesn't make as much wind resistance, that helps quite a lot.
Otherwise, not wearing loose fitting jerseys that flap around in the wind will help a lot too. There are cheaper solutions than dropping a lot of money on a quite expensive Propel.
I can't say exactly how quick a Propel is versus an absolutely top specification TCR Advanced SL, but I can compare that TCR with a Cervelo P5. On a flat section where the Giant is at 38km/h, the P5 is at 48km/h with me on the aerobars. Same amount of effort, just that on the P5 I'm so much more aero on that bike. I can't see a Propel giving that much of a dramatic difference.
madmacca
Postby madmacca » Sun Jan 15, 2017 10:27 pm
From the photos, the hoods look to be 7.5-10 cm above the saddle on the Defy, and about 5 cm below the saddle on the TCR. That would be a huge jump, and even if your body was flexible enough, that dramatic a change would be pretty uncomfortable for a while.
I'd recommend progressing things more gradually by adjusting the Defy one stage at a time (removing the spacers would be the easiest 1st step), before outlaying serious coin on a new bike. This will allow your body to adjust more progressively to a new more aggressive position.
defy1
Postby defy1 » Sun Jan 15, 2017 10:33 pm
defy1 wrote:is your seat level with the ground?
Not I believe it is tilted up slightly as this felt more comfortable for me
Oh ok. are you planning to change that? Just the pic you posted in terms of what you wanted to look is like that. If you don't, you might notice additional pressure in your family jewels if you don't, given the change in your stem/handlebar.
Defy The Odds
Postby Defy The Odds » Sun Jan 15, 2017 10:36 pm
MattyK wrote:DtO: if it were my bike I would be stripping back the bar tape, and adjusting the bars until the ends of the drops were close to horizontal, or wherever gives the most comfortable position with hands in the drops. Then loosening off the hoods and moving them further up on the bars until they were about 5 degrees up from horizontal, or wherever the most comfortable hoods position is for you. A_P's bar position above is a good example.
Thanks Matty,
For now I think that by me flipping the stem and reducing stack height it is a step in the right direction and I think only a few weeks in the saddle will tell me this since doing the "mods". I am happy with the comfort levels so far (quick test ride only), but after a few weeks I might feel I can go a little harder on the stack height.
Here is how she looks now
I think the next thing that may be required is to increase stem length to 110mm (I think stock they are 100mm) and possible slightly increase saddle height
Defy The Odds
Postby Defy The Odds » Sun Jan 15, 2017 10:37 pm
Mate thanks heaps. Went out to the garage and did what you said and "hey presto!" All is nice and tight once again !
Thanks again !
Defy The Odds
Postby Defy The Odds » Sun Jan 15, 2017 10:39 pm
I wanted to change things one at time so I don't get the whole geometry and "settings" all messed up. Thought I'd start with stem angle (flipping it) and stack height. Then after a week or two in the saddle if still uncomfortable downstairs then maybe tilt saddle slightly forwards to keep it more level, if you know what I mean.
My fear is changing too many things at once and not knowing what actually worked and didn't
rodneycc
Postby rodneycc » Sun Jan 15, 2017 10:44 pm
And where exactly did I say buy a Propel ? If anything in my argument I leaned towards a TCR if anything but leant to nothing for the moment. I'd suggested 30km/h avg to see any benefit - emphasis on the average over a whole ride as, not many people I know ride at 40km/h avg ( or maybe on just a few very short Strava segments).
g-boaf
Postby g-boaf » Sun Jan 15, 2017 11:16 pm
rodneycc wrote:emphasis on the average over a whole ride
I didn't read it that way. My bad! Even at 30km/h average over a whole ride, I don't think the Propel will give you that much of an advantage. Most of my rides are around the 30-33km/h average speed range (100-145km rides).
Postby Duck! » Mon Jan 16, 2017 12:02 am
This part is correct...
A_P wrote:You cant preload the headset bearings with the steerer bolts done up tight.
... so yes, it is important to ensure the stem bolts are loosened before adjusting the top bolt.
However, this part is not....
Once you have tightened the steerer bolts you could undo the cap bolt without it coming loose.
Do NOT loosen the cap bolt after tightening the stem bolts. Even when properly torqued, road vibrations can have a slide hammer effect on the headset assembly and push the stem up the steerer, undoing the preload on the bearings. Even with the cap bolt kept at its preload tension the hammer effect can loosen it, so it's actually best once the bearing preload has been set and the stem bolts torqued to further nip the top bolt up another 1/8 turn or so to bind its threads & stop it loosening.
A_P
Postby A_P » Mon Jan 16, 2017 12:11 am
obviously i neglected to state the bleedingly obvious...my bad
defy1
Postby defy1 » Mon Jan 16, 2017 8:31 am
Nps..was your initial setup done DIY or by a bike fit?
Defy The Odds
Postby Defy The Odds » Mon Jan 16, 2017 8:37 am
I've tightened all bolts now and all seems nice and tight like before, no play.
In terms of the fit, it was done by the shop. When I first got the bike, being my first road bike the stem angled down was too aggressive for me as I was quite overweight and inflexible at the time. I went to the shop and asked to flip the stem and tilt the bars to something more comfortable which it has been that way ever since.
That was about a year or so ago but hadn't had many km since then. Only started riding regularly and seriously in the last 2-3 months aND have lost alot of weight, therefore now am looking for something more aggressive in terms of positioning as my body tells me it can handle it
kx315
Postby kx315 » Mon Jan 16, 2017 7:32 pm
I have the same 2013 Defy Advanced 0 I also have the 2016 TCR Advanced Pro 0........After getting the TCR not a big fan of the Defy anymore. TCR is way more responsive and puts the power down much better than the Defy.
2012 Giant Cross City 2
2013 Giant Defy Advanced 0
2016 Giant TCR Advanced Pro 0
Tim
Postby Tim » Mon Jan 16, 2017 8:31 pm
kx315 wrote:TCR is way more responsive and puts the power down much better than the Defy.
Phooey. :)
That's just how it feels, it isn't the reality. It's what Giant want you to think.
Fit a power meter to both bikes, pump out 40km's with identical power output and the TCR might get you to the finish about 10 seconds quicker, at a rough guess. There won't be much in it.
I own a Defy Adv Pro and a TCR Adv SL. The TCR's shorter wheelbase makes the bike's steering more snappy and the lighter frame and wheels makes it feel quicker. The TCR accelerates a little bit quicker, maybe, it feels like it.
My times and speeds at similar effort (based on HR) aren't very different.
The TCR feels much faster. It isn't. The truth is I am faster on some days, slower on others. The bikes don't change and there aint much difference performance wise between the two.
It's all about perception, marginal gains and marketing.
