I would suggest the shifters are in about the right position relative to the bike, but the bar is rotated too far up; if you draw a straight line across the bar top and the shifter hoods, the shifters "droop" off the bar, creating a hump under your hands, which may increase pressure on the nerves in the heels of your hands, causing discomfort. SRAM shifters are designed to have a basically flat transition off the bar top (Shimano & Campag are slightly dipped), so you need to rotate the bar down so the top is basically flat or very slightly up, and then slide the shifters up the bar to get them back into the same airspace.Defy The Odds wrote:I've tightened all bolts now and all seems nice and tight like before, no play.
In terms of the fit, it was done by the shop. When I first got the bike, being my first road bike the stem angled down was too aggressive for me as I was quite overweight and inflexible at the time. I went to the shop and asked to flip the stem and tilt the bars to something more comfortable which it has been that way ever since.
That was about a year or so ago but hadn't had many km since then. Only started riding regularly and seriously in the last 2-3 months aND have lost alot of weight, therefore now am looking for something more aggressive in terms of positioning as my body tells me it can handle it.
Try this: Move the shifters on the bar to get that flat transistion, you should be able to do it without needing to undo the bar tape( but it might need a bit of masaging to keep a snug wrap), sit on the bike in a trainer if you have one, or leaning against a wall or bench to support yourself then loosen the stem faceplate bolts just enough to allow you to move the bar, but not so loose that it falls away under a little bit of weighting. Grip the bar by the hoods how you normally would when riding with your elbows slightly bent, and rotate to an angle where your wrists are at a comfortable angle, close to straight. If the bar is rotated too high, straightening your wrists to a comfortable angle causes you to excessively bend your elbows, which can cause discomfort elsewhere. It's also very difficult to reach the brake levers & shift paddles from the drops. If the bar is too low it can also cause wrist strain, and pull your elbows fully straight, where they then can't absorb road bumps.
