Comedian wrote:Duck! wrote:Given the points of contact, it is entirely plausible that similar damage would be inflicted with a rim-braked wheel. So you can't blame the disc brake for this either.
A shifter between a rim brake and a wheel? Really?
Spokes & frame. I can't recall whether it was this thread or the other one, but I pointed out that the outer edge of a disc rotor is 70 or 80mm from the centre of the axle, depending on whether it's a 140 or 160mm disc. That's not very far out. Next, the rotor is little more than a single finger thickness clear of the spokes; let's call it around 15mm, maybe a touch more. That's not a huge margin either. So if anything is getting that close in to the wheel and frame in a chaotic manner such as a crash, the presence of a brake rotor does not meaningfully alter the probability of something getting caught between the wheel and the frame, because without a rotor it's highly probable the invading object will end up in the spokes instead. And quite possibly do greater damage in the process. Plus there's the expanse of wheel beyond the edge of the rotor for Stuff to get caught in as well. And less face it, on a non-disc wheel the spokes are actually closer to the frame, and more likely to scissor an intrusion because of the different hub flange offset.
