I currently have a Shimano Deore FH-M595 rear hub - 135mm old, 8-10 speed, centrelock disc. Sadly the cones are showing brinelling so time for a replacement.
I was thinking about getting an 11 speed hub in case I end up going with a long planned change to drop bars with hydraulic brakes.
Any reason I couldn't replace the hub with a Shimano FH-RS505 Disc rear hub ? Same 135mm old & centrelock disc, would need a spacer to run 8-10 speed cassette.
replacing 10 speed hub with 11 speed
- find_bruce
- Moderator
- Duck!
Re: replacing 10 speed hub with 11 speed
Postby Duck! » Thu May 11, 2017 6:56 pm
The hub would include the spacer for running 8-10-sp. cassettes. The additional 1mm spacer for fitting 10-sp. cassettes (except Tiagra & SRAM - complicated story) on 8/9-sp. hubs is still required, and supplied with cassettes that need it.
No reason why you can't swap hubs, but compare the flange spacing and diameter measurements; you may need new spokes to suit.
- find_bruce
- Moderator
Postby find_bruce » Thu May 11, 2017 9:55 pm
Cheers Duck! it seemed a straightforward swap, which always makes me wonder what I'm missing
- KGB
Postby KGB » Mon May 15, 2017 7:18 pm
Just a thought but if its just the cones that are showing brinelling, replace them. If it's the cups, then yes, replace the hub and run the spacer as suggested.
- find_bruce
- Moderator
Postby find_bruce » Mon May 15, 2017 7:45 pm
Easy enough to replace cones & ball bearings, but last time I checked the price of a couple of cones was 80% of the price of a new hub.
Happy to be corrected if you know a cheap source
Postby ironhanglider » Mon May 15, 2017 10:21 pm
I seriously doubt that the damage is brinelling. I just don't imagine Bruce doing dirt jumps. Even then it would be an impressive effort. Even headsets only really get false brinelling, although the end result is similar.
I think it is just common garden variety pitting/wear.
Play with a spoke length calculator, the hub dimensions in 3x builds make very little difference to spoke length. You'll probably be able to use the same spokes again if you are determined to do it on the cheap. I have often re-used spokes, occasionally it comes back to bite me. If I was doing a wheel for someone else I'd use new spokes.
Cameron
Cameron
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
