2016 giant defy - sr-2 wheels
Postby newierider » Thu May 11, 2017 2:57 pm
wheel: 2016 giant sr-2 - hub: giant Sport Tracker Road Disc, 32h hub.
thanks guys
- jacks1071
Re: 2016 giant defy - sr-2 wheels
Postby jacks1071 » Thu May 11, 2017 3:04 pm
You could just try and install your 11sp cluster, if the lock ring won't do up, it isn't compatible.newierider wrote:hi guys, i have searched the net unable to find this information for hours, but can you tell me if the wheel below is 11 speed compatible? it is from a 2016 giant defy 2 that was running 10sp tiagra. just asking as i am helping a friend and i cant get in touch with him to see if the wheel had a spacer. nor do i have it with me to measure.
thanks guys
Postby newierider » Thu May 11, 2017 3:15 pm
Postby nickdos » Thu May 11, 2017 5:14 pm
- Duck!
Postby Duck! » Thu May 11, 2017 6:43 pm
Postby am50em » Thu May 11, 2017 7:18 pm
Discovered two days ago my 2014 P-CRX1 does have a spacer so 11 speed.
Postby newierider » Thu May 11, 2017 9:40 pm
thanks mate but thats quite an old wheel, its an old ad. i saw it too earlier and im pretty sure your crx1 has a different hub. thanks again though.am50em wrote:https://www.ashcycles.com/site/road-whe ... vfr029jfa3 says 10 speed
Postby newierider » Thu May 11, 2017 9:44 pm
Duck! wrote:Probably not. The easiest way to tell if it is 11-sp. compatible is if there is a spacer behind the cassette. If there is no spacer (the Tiagra cassette, unlike its higher-spec 10-sp. cousins, does not use a spacer at all) then it will not fit 11-sp.
sorry duck, trying to understand what you said.. i get that if theres a spacer, its most likely 11sp compatible, but what are you saying about the tiagra cassette? any 10 speed shimano cassette could be a tiagra cassette right? therefore needing a spacer..
- Duck!
Postby Duck! » Thu May 11, 2017 11:01 pm
No!. Tiagra cassettes will be labelled either CS-4600 or HG500, depending on exact vintage. These are characterised by the shallow spline used on virtually all Shimano-pattern hubs. 105, Ultegra and Dura-Ace 10-sp. cassettes (CS-5600, 5700, 6600, 6700, 7800 & 7900) have a deeper spline except on the smallest sprocket and are shorter through the centre of the cassette, designed for Shimano's short-lived 10-sp. specific freewheel body pattern, which very few other manufacturers adopted. The narrower cassette core dictates that a 1mm thick spacer is required (and supplied with) those particular cassettes when fitting on a 8/9-sp. pattern hub. Therefore, when fitting those cassettes to an 11-sp. hub, two spacers will be required. 4600/HG500 cassettes do not use the 1mm spacer.newierider wrote: sorry duck, trying to understand what you said.. i get that if theres a spacer, its most likely 11sp compatible, but what are you saying about the tiagra cassette? any 10 speed shimano cassette could be a tiagra cassette right? therefore needing a spacer..
Postby newierider » Thu May 11, 2017 11:48 pm
..wow. blown away by your response. I would say you know your stuff but thats an understatement! Thanks so much duck! Really appreciate your time. Cheers!Duck! wrote:No!. Tiagra cassettes will be labelled either CS-4600 or HG500, depending on exact vintage. These are characterised by the shallow spline used on virtually all Shimano-pattern hubs. 105, Ultegra and Dura-Ace 10-sp. cassettes (CS-5600, 5700, 6600, 6700, 7800 & 7900) have a deeper spline except on the smallest sprocket and are shorter through the centre of the cassette, designed for Shimano's short-lived 10-sp. specific freewheel body pattern, which very few other manufacturers adopted. The narrower cassette core dictates that a 1mm thick spacer is required (and supplied with) those particular cassettes when fitting on a 8/9-sp. pattern hub. Therefore, when fitting those cassettes to an 11-sp. hub, two spacers will be required. 4600/HG500 cassettes do not use the 1mm spacer.newierider wrote: sorry duck, trying to understand what you said.. i get that if theres a spacer, its most likely 11sp compatible, but what are you saying about the tiagra cassette? any 10 speed shimano cassette could be a tiagra cassette right? therefore needing a spacer..
Postby nickdos » Fri May 12, 2017 3:32 pm
- Duck!
Postby Duck! » Fri May 12, 2017 7:58 pm
To the best of my knowledge it's getting close to 10 years since anyone - Shimano included - has produced a dedicated 10-sp. hub. Since the introduction of that spline pattern in 2003 (for '04 model year), I believe even Shimano began phasing it out within five years. I possibly suspect that SRAM choosing to design their cassettes to the "regular" 8/9-sp. longer, shallow spline pattern contributed to its lack of adoption in the wider industry.nickdos wrote:It makes you wonder why any manufacturer would bother making a 10 speed only cassette body (in the last 5 years) because its it locks the buyer into 10 speed (and makes upgrading to 11 speed a PITA) and is solvable with a 1mm plastic spacer if the wheel does use a 10 speed cassette (or equivalent width cassette). Furthermore they only have to tool/manufacturer one size of cassette body (not 2).
Upgrading to 11 from dedicated 10-sp. is no less of a PITA than it is from upgrading from a 8/9/10-sp. hub - few hubs are readily convertible. And it's not a plastic spacer - such a thing would squish & shatter the first time the cassette is tightened against it.
Postby nickdos » Sat May 13, 2017 6:30 pm
I've had few plastic ones Duck and they haven't squished (Giant wheels come with them, getting back on topic). [edit: removed unnecessary jibe, sorry] - went and checked my "plastic ones" and they weren't 1mm they were more like 3mm, so I stand corrected.Duck! wrote:And it's not a plastic spacer - such a thing would squish & shatter the first time the cassette is tightened against it.
- Duck!
Postby Duck! » Sat May 13, 2017 6:39 pm
Postby newierider » Fri May 19, 2017 12:47 pm
Users browsing this forum: familyguy
