A good Bike Bag
A good Bike Bag
Postby kokoman » Sat Jul 22, 2017 9:45 am
Best would be one which requires the least amount of removal and re-assembly of the bike.
- Duck!
Re: A good Bike Bag
Postby Duck! » Sat Jul 22, 2017 3:39 pm
All you do is take the wheels off & put those in the side pouches, mount the bike to the bag frame, strap it in and away you go.
- MichaelB
Re: A good Bike Bag
Postby MichaelB » Sat Jul 22, 2017 6:10 pm
Was brilliant and very easy to use. Just did a trip with a hard case, and it worked, but was a pain. They are not cheap, but well worth the money.
Used on trip to Italy & France last year
- g-boaf
Re: A good Bike Bag
Postby g-boaf » Sat Jul 22, 2017 7:35 pm
I think I remember you know Giant pretty well, so can I ask how are these bags with the older TCRs with the ISP? I'm using one of these bags for when I go over to Europe. 54cm frame.Duck! wrote:Scicons are good; bag has an adjustable-length frame (to suit different sized bikes) in the base which the bike mounts to on the dropouts, and is wide enough to not require doing anything to the handlebar seteup.
- Duck!
Re: A good Bike Bag
Postby Duck! » Sat Jul 22, 2017 7:43 pm
The only - rare - times I've needed to do more than that is with a TT/tri bike (Scicon do a different bag to suit those bikes with a bit more room in the upper front corner), where larger bikes sometimes need the aero bars tucked back a little bit, and while they fit, I generally remove bottle cages from saddle-mounted carriers to reduce risk of damage.
- g-boaf
Re: A good Bike Bag
Postby g-boaf » Sat Jul 22, 2017 8:07 pm
Duck! wrote:They're fine; tall enough to not need to do any disassembly beyond removing the wheels.
Thank you.
- Ross
Re: A good Bike Bag
Postby Ross » Sun Jul 23, 2017 7:51 am
Re: A good Bike Bag
Postby tez001 » Sun Jul 23, 2017 11:51 am
The only complaint others have about these style of bags is the brifters can get knocked about. So either loosen them up, angle them in, or get some pvc tubing or similar to put across the shifters.
I've also used the hard shell type and it was just more time spend removing things off the bike and reinstalling them
Re: A good Bike Bag
Postby battler2 » Sun Jul 23, 2017 4:41 pm
but obviously more for touring than anything.
have a hard case. still good but it'll break one day. but it weighs a ton on its own, so limited weight you can carry in addition. say, 10kg for the case, 10kg bike + extras you are cutting it fine within 23kg limit for airlines. some allow 30kg, then its no problem.
downsides to cardboard is use only once or twice, hassle of finding a bike shop with one (that is also big enough) to give away (sometimes hard eg. cambodia. sometimes the bsterds charge you (eg. malaysia, 15rmb, thailand 100baht). if it gets wet enroute from plane to cargo, it could fall apart on the taxiway.
scicon pricey, but i question the padding effectiveness. seen plenty of failure reports online (ie. once or twice used, then damaged).
think ill keep my hard case for road bike adventures, then cardboard for touring (which is more fun anyway), but you need more time to do it.
- Derny Driver
Re: A good Bike Bag
Postby Derny Driver » Sun Jul 23, 2017 5:12 pm
They are good but you have to take the seat out, front wheel out, remove the handlebars and tuck them sideways. Plus pedals off, rear derailleur off... bit of work but there are advantages. You can put a track pump in there, linen, towels, tools ...lots of stuff.battler2 wrote:the best kind of bag is a cardboard bike box. throwaway and easily replaceable from a bike shop on your final destination.
I have a SciCon and I remove the pedals if Im flying. Takes 2 minutes.
Re: A good Bike Bag
Postby mikgit » Sun Jul 23, 2017 6:10 pm
So from that it seems a cardboard box is in fact not even close to the best, seems to be a right pain...cheap yes.
Used a cardboard box before, right pain at airports with other luggage and not something i'd really want if it rained on the trip, $10K bike in a soggy box...I'f I ever need to travel with a bike again i'd be going bike bag of some description
Re: A good Bike Bag
Postby battler2 » Sun Jul 23, 2017 7:45 pm
honestly soggy box has never happened to me and probably never will. but it has happened when i left it somewhere i thought was properly covered for a few days but wasn't. i just got another box
don't pay for them, unless you absolutely have to. check the garbage and just don't ask anyone inside the store and you won't pay. but i've had a scenario in a city where bikes are nearly impossible where it was hard to find a box, so i had to pay (KL).
it is the most frugal option yes, but suitable if you're not packing up every few days and hopping on a train or plane to go somewhere else.
ill just say i got my hard case from cyclingdeal, and it was $219. https://www.cyclingdeal.com.au/buy/abs- ... /XXF-A1601 it's ok. i can squeeze a lot of extra crap inside the hard case, but it takes hours to pack and repack all those clothes etc. when changing destinations.
you'd have the same problem with a scion, and quite frankly, i'd be weary of keeping much more than a helmet inside as well. think there's not a lot of room, so you'll need to checkin an additional suitcase which is very expensive in economy and sometimes not permitted (unless south america is your destination). the weight allowance is also COMBINED.
bottom line, it's so hard to say what the most appropriate option is until you look at what kind of trip you're taking, and for how long.
- Ross
Re: A good Bike Bag
Postby Ross » Mon Jul 24, 2017 7:46 am
The OP did ask which bag takes the least amount of bike dissassembly. A Scicon style bag ticks this box way ahead of carboard boxes or hard cases. Each bag or box has their own merits or drawbacks, there is no perfect solution except to not travel with a bike.battler2 wrote:yes and no. haha. most airlines are absolutely fine with the box. usually their policy specifically says: "must be packed in a box". i'd say you can have more issues with a hard case than anything else, cos they can sometimes breach the dimension limit, and of course, blow your excess baggage allowance.
Re: A good Bike Bag
Postby tez001 » Mon Jul 24, 2017 9:03 am
Re: A good Bike Bag
Postby kokoman » Mon Jul 24, 2017 9:13 am
Checking now if I can get 3 Scicon bags into the back of a Commie Sportswagon??
- MichaelB
Re: A good Bike Bag
Postby MichaelB » Mon Jul 24, 2017 9:14 am
That's a good price. Is it capable to dealing with TA's ?Ross wrote:I have one of these, about half the price of Scicon bag and seems to be identical (I previously had a Scicon bag) - http://www.prospeedracing.com.au/produc ... g-bag.html
Re: A good Bike Bag
Postby Hergest » Mon Jul 24, 2017 10:35 am
That might be a squeeze. I've got the Scicon mentioned in other posts and have done 2 trips to the UK so far with Singapore air with no problem whatsoever. The bag is surprisingly large though. Mine fitted with no problem in the back of our Saab 9-5 wagon with the seats down, 2 would be tight, 3 would be very hard in the Saab and that's got a good size cargo area. Maybe if the Commodore is tall enough to allow one bag to sit on top of the other you would manage it.kokoman wrote:for Amy's fondo.
Re: A good Bike Bag
Postby Hergest » Mon Jul 24, 2017 10:38 am
Chris, my 57 cm Lynskey fits nicely into my Scicon bag, I can't see you having any issues with a 54 cm.g-boaf wrote:I think I remember you know Giant pretty well, so can I ask how are these bags with the older TCRs with the ISP? I'm using one of these bags for when I go over to Europe. 54cm frame.Duck! wrote:Scicons are good; bag has an adjustable-length frame (to suit different sized bikes) in the base which the bike mounts to on the dropouts, and is wide enough to not require doing anything to the handlebar seteup.
- g-boaf
Re: A good Bike Bag
Postby kokoman » Mon Jul 24, 2017 12:00 pm
3 bags in a Commie Sportswagon.
- MichaelB
Re: A good Bike Bag
Postby MichaelB » Mon Jul 24, 2017 1:25 pm
Depends on what else you want to take. May actually be easier without the bags. Remove both wheels and a couple of blankets, and all sweet.kokoman wrote:I'm thinking 2 in the back with half of the rear seats down and one more between the front and rear seats... might that work?
Despite how well the bikes pack into the bags, they take up a LOT of room.
- Thoglette
Rinko?
Postby Thoglette » Mon Jul 24, 2017 1:56 pm
If you need to get you bike and bag small (which is not what OP asked for) then "Rinko" is the way to go. Remove handlebars and fork (leave front wheel in fork) and you get it all into a much smaller bag. Those who do it regularly say "3 minutes". YMMVHergest wrote:The bag is surprisingly large though.
See this thread for more.
Re: A good Bike Bag
Postby Hergest » Mon Jul 24, 2017 3:56 pm
This is very true. The good thing for me about the size is that I only take the Scicon bag away with me as once the bike is in I place clothes and anything else in plastic bags around the bike and weigh it with each addition to keep under the baggage allowance.MichaelB wrote:
One word of warning for anyone ever going to London Paddington with it. Avoid the rear entrance as it's got some lovely heritage cobbles for a hundred metres or so but the wheels of the bag refuse to go over them so you have to shoulder the 30 kg baggage all the way to the station concourse.
- ValleyForge
Re: A good Bike Bag
Postby ValleyForge » Mon Jul 24, 2017 6:16 pm
viewtopic.php?f=44&t=51898
As a matter of record, It won't fit in a normal stationwagon except lying down, and even then it is usually a struggle.
My suggestion is the less disassembly, the more space they take up. If you have the time (and I seldom did) an extra 30 mins reassembling is fine.
Re: A good Bike Bag
Postby Hergest » Mon Jul 24, 2017 7:41 pm
When I went to the UK the bike bag fitted in the back of this Hyundai i30 with the seats down quite easily from Heathrow and all the way up to Scotland. Lying it down is no issue so I'm curious as to what normal station wagon you found it a struggle to lie down the bag in? The following year I got in in the back of an Astra hatchback.ValleyForge wrote:My review of my SciCon.
Users browsing this forum: Duck!, Majestic-12 [Bot]
