TT Wheels
- mikesbytes
Re: TT Wheels
Postby mikesbytes » Mon Dec 14, 2015 2:13 pm
- mikesbytes
Re: TT Wheels
Postby mikesbytes » Mon Dec 14, 2015 2:38 pm
http://www.bikebug.com/mavic-cosmic-car ... 30309.html
- JdM
Re: TT Wheels
Postby JdM » Mon Dec 14, 2015 2:44 pm
I've been eyeing these... Seem good for the price, but from what I can find they are quite dated? Would it be better putting the $999 towards a more expensive and better set?mikesbytes wrote:Another option is to buy a set for your road bike and use the front for both
- mikesbytes
Re: TT Wheels
Postby mikesbytes » Mon Dec 14, 2015 6:14 pm
Someone else would be better as to advising the wheel(s) to get
Re: TT Wheels
Postby warthog1 » Mon Dec 14, 2015 7:15 pm
Re: TT Wheels
Postby softy » Mon Dec 14, 2015 10:25 pm
I have a cervelo S5 with pre firecrest zipps 404, really good in crosswinds.warthog1 wrote:I recently got a set of fc 404 clinchers. They are very good in the wind. I hardly notice any steering input. Seriously bugger all, much, much better than my 85mm token tubulars. They take some hanging onto but you do adapt. The 404s take no adaption at all ime.
I now also have a bottecchia emme2 with reynolds mv32ul and this bike gets blown around a lot more. So depth of wheel, aero bike, doesn't always comput to more crosswind buffering.
Re: TT Wheels
Postby warthog1 » Mon Dec 14, 2015 10:50 pm
The 85mm tokens are significantly worse but not unrideable even on a windy day.
I'm 184cm 75kg so not a heavy strong bloke either.
Re: TT Wheels
Postby linds » Tue Dec 15, 2015 7:40 am
Re: TT Wheels
Postby dalai47 » Tue Dec 15, 2015 10:23 am
Is the 88mm Chinese wheel all carbon? If so consider getting an all carbon front wheel, otherwise you will need to swap brake blocks when changing wheels. I prefer the flexibility of being able to swap wheels at the last minute without necessitating a brake block swap by sticking with the same brake track material.
Re: TT Wheels
Postby linds » Tue Dec 15, 2015 8:26 pm
For the amount of braking I do either TTing or TT training on the road ( not much ) ..Does it really matter if I use the same brake pads? ( Which I currently do)
I also would not be planning to swap out the pads at the last minute.
But good point..perhaps I should go a tubular full carbon.
Thks
- mikesbytes
Re: TT Wheels
Postby mikesbytes » Tue Dec 15, 2015 9:50 pm
Re: TT Wheels
Postby linds » Tue Dec 15, 2015 10:22 pm
Carbon tubular it is
Re: TT Wheels
Postby softy » Wed Dec 16, 2015 12:56 am
Just to clarify, my zipps are all carbon tubulars, if that makes any difference.softy wrote:I have a cervelo S5 with pre firecrest zipps 404, really good in crosswinds.warthog1 wrote:I recently got a set of fc 404 clinchers. They are very good in the wind. I hardly notice any steering input. Seriously bugger all, much, much better than my 85mm token tubulars. They take some hanging onto but you do adapt. The 404s take no adaption at all ime.
- Duck!
Re: TT Wheels
Postby Duck! » Thu Dec 24, 2015 1:35 pm
Not only that, but pads for carbon don't brake as well on aluminium, and pads for aluminium tend to build up more, potentially damaging heat in carbon rims.mikesbytes wrote:The problem with using alloy wheels is that your get small quantites of alloy in the pads, then when you put your carbon rim wheels in the alloy filing can damage your carbon rim
- Duck!
Re: TT Wheels
Postby Duck! » Thu Dec 24, 2015 1:38 pm
404s have been through a few evolutions, from carbon/alloy, full carbon standard width, then Firecrest.dalai47 wrote:Don't think the pre firecrest 404s clinchers were all carbon, but rather carbon with alloy brake track.
