'Race use only' Tyres on ToughRoad SLR1?
tgdavies
Postby tgdavies » Fri Jan 08, 2016 10:51 am
The 2016 ToughRoad comes with Maxxis Maxxlite 29x2.0" -- on Maxxis's site it says "Race use only" (http://www.maxxis.com/catalog/tire-274-maxxlite" onclick="window.open(this.href);return false;) -- what does that mean?
Re: 'Race use only' Tyres on ToughRoad SLR1?
Postby RonK » Fri Jan 08, 2016 11:15 am
It means that when used as originally intended on mountain bikes, its lightweight construction is not suitable for general MTB use.
These are not the typical surfaces where you would take a Toughroad. Should be a good choice actually - lightweight, but grippy on gravel roads.
tgdavies
Postby tgdavies » Fri Jan 08, 2016 1:54 pm
350 grams -- very light. Not a good choice if I was to use the bike as a commuter, bearing in mind punctures and knobbiness?
Postby RonK » Fri Jan 08, 2016 2:42 pm
tgdavies wrote:350 grams -- very light. Not a good choice if I was to use the bike as a commuter, bearing in mind punctures and knobbiness?
Up to you - my choice would always be for light weight at the risk of the odd puncture, but these may not roll as well with the knobs.
tgdavies
Postby tgdavies » Sat Jan 09, 2016 9:49 pm
I was thinking that the knobs would reduce grip on wet concrete, rather than thinking about rolling resistance.
Postby RonK » Sat Jan 09, 2016 10:11 pm
Perhaps, but as race tyres I'd expect a grippy compound is used.
I don't imagine they would last long for commuting.
Postby Duck! » Sun Jan 10, 2016 10:17 pm
Soft compound or not, knobs aren't great on hard surfaces.
tgdavies
Postby tgdavies » Fri Jan 15, 2016 6:35 pm
On reflection it's probably silly to think that a 'Maxxlite' on the Maxxis website is the same as the OEM tyre on a particular Giant, even though it says 'Maxxlite' on the side...
