Magellan Cyclo 505
Re: Magellan Cyclo 505
Postby defy1 » Thu Jul 20, 2017 4:48 pm
Had lots of trouble detecting my device but seems working now.
It installed OSM and Here map updates
Postby fab4272 » Sat Jul 22, 2017 9:38 am
Also, the update keeps failing. It doesn't think the Cyclo is attached, but it is. Very frustrating. How did you solve it?
Postby buckobruce » Tue Jul 25, 2017 8:24 am
Of course, there was no information about the upgrade on the MagellanCyclo web page without digging deep and finding a link to Magellan Australia/New Zealand. In trying to find information, I found this site and see a couple people that used to contribute to the defunct GPS Cyclo forum. The upgrade in CycloAgent 1.0.56.1 did not include maps or ROM version that I find mentioned in this forum.
It's nice to know they didn't totally abandon the Cyclo in the US and AUS and that there is still a forum to gather and share information on them.
Postby Machoman121 » Tue Jul 25, 2017 11:03 pm
I've had a few scares - one time i lost all my maps - everything was blank on the 505 then somehow i was able to re-install it again - and then I tried to update the updates but why does the map still have 2015-05-26 dates after the updates. Shouldn't it have 2017 on the maps?
I don't think my 505 installed the map updates successfully because Cycloagent still reports an update to the maps are available...Say What. I've tried quite a few times now and it leads back to the same thing!
Postby wicksey » Sun Aug 06, 2017 8:39 pm
Installed the agent update (I was already on 4.4.7 software.)octagonalman wrote:Seems like you can overwrite the part of the URL with the new version number:
http://download.mio.com/MioCyclo/GPST/A ... 2.13.1.zip
There seems to be a file on the other side.
Let us know how you go.
Agent updated.
Reupdated to 4.4.7
Updated base maps
Maps are still dated 2015, no point really going through the process if you are already on 4.4.7
Postby wicksey » Mon Aug 21, 2017 5:30 pm
Will re-pair my sensor and see if it resolves itself.
- RonK
Postby RonK » Mon Aug 21, 2017 8:24 pm
Postby wicksey » Tue Aug 22, 2017 12:59 pm
Have reduced my own to about 5, will see if that fixes the issue when I ride this afternoon.
- cancan64
Postby cancan64 » Wed Aug 23, 2017 10:51 am
Postby wicksey » Wed Aug 23, 2017 12:03 pm
wicksey wrote:Had 14 of my own tracks on there (plus the built in ones.)
Seems to have fixed my problem.
Postby fab4272 » Thu Aug 24, 2017 2:32 pm
- RonK
Postby RonK » Thu Aug 24, 2017 3:24 pm
It's best to backup the pre-installed tracks to your computer and delete them too if you don't use them. They can also be downloaded from the Cyclo Oz site. There are actually a lot more tracks on the site than are pre-installed.wicksey wrote:wicksey wrote:Had 14 of my own tracks on there (plus the built in ones.)
And if you are using a Mac, be sure to empty the trash can to actually remove the track files from the Cyclo.
- bane
Postby bane » Mon Aug 28, 2017 2:07 pm
Me too. Just lost a 40k ride. Anyone found a fix?cancan64 wrote:Used the roadie this morning which has the cyclo 505 on it... uploaded my ride via mobile data...1 ride sync'd... 0 rides on web site... 0 rides now on cyclo... bit of a bummer
- cancan64
Postby cancan64 » Mon Aug 28, 2017 6:06 pm
Postby bobbythebrit » Sat Sep 02, 2017 12:24 pm
My only reason for needing to connect is to upload an activity manually since the wifi sync told me it uploaded all 3 activities but only 2 have come through to Strava.
'99 Gary Fisher Aquila
'97 Corratec 3004
- bane
Postby bane » Sun Sep 03, 2017 7:13 pm
Shouldn't have bothered with the update - the segment feature is crap, and now the sync is a hassle.
Postby thomas1987 » Sun Sep 03, 2017 9:18 pm
Postby monaro318 » Sun Oct 01, 2017 6:41 pm
I have just got a 505 and it seems to work well, I have not come across the problems seen above.
I did find that when I paused the recording and then pressed continue, it did not.
But no real concerns about that.
However, after customising some fields in the pages I now find the dashboard stops after the info pages and I cannot access the rest. Which it was doing.
I cannot see how to re-enable them, from what i can determine they are not even supposed to be de-selectable.
In my settings I can see all the pages, info 1,2,3,4 map, elevation, navigation, strava, history, workout and training and can customise the fields within each page.
But when I go to the dashboard I can only scroll through info 1, 2, 3, 4 and map (which I reach by using the left arrow from info 1 page)
When I press the right arrow I can scroll through info 1, 2, 3, and 4, at this point the right arrow is grey and you cannot reach any more pages.
Can you help?
I have, in order, done the following and checked the results each time without success.
1. Reset to defaults
2. Reset to factory
3. Completed all updates via the cyclo agent to version 4.4
4. Downloaded the 3 files from mio share to update to 4.4.7 beta.
kind regards
Kevin
- bane
Postby bane » Mon Oct 02, 2017 7:10 pm
No idea how its caused, but mine does the same. Fortunately, Strava automatically fixes it.thomas1987 wrote:The elevation on my gps is always lower than my riding buddies (sometimes by a good 200m difference). Anyone know why this could be the case?
Postby octagonalman » Mon Oct 02, 2017 7:26 pm
Postby fab4272 » Tue Oct 17, 2017 5:07 pm
Postby Shelby35 » Sat Oct 21, 2017 11:07 am
Byron
- gm6046
Postby gm6046 » Sat Oct 21, 2017 4:53 pm
Have you tried another USB cable? I have a cable here that does the same.Shelby35 wrote:My Magellan will not connect to a computer at all it will charge from a computer but will not connect any help will be great.
Byron
Postby Shelby35 » Sat Oct 21, 2017 5:19 pm
No i haven't didn't even think of that will give it ago.gm6046 wrote:Have you tried another USB cable? I have a cable here that does the same.Shelby35 wrote:My Magellan will not connect to a computer at all it will charge from a computer but will not connect any help will be great.
Byron
Postby Shelby35 » Sun Oct 22, 2017 3:43 pm
Winner Winner Chicken Dinner it worked with a different cablegm6046 wrote:Have you tried another USB cable? I have a cable here that does the same.Shelby35 wrote:My Magellan will not connect to a computer at all it will charge from a computer but will not connect any help will be great.
Byron
Users browsing this forum: davehirst, Google Adsense [Bot], Google Feedfetcher, piledhigher2
