Stoves and Cookwear
Re: Stoves and Cookwear
Postby Aushiker » Fri Dec 16, 2016 10:50 am
The picture ...
The marketing blurb ...
The newest offering from Korean outdoor company Kovea, the Hydra multi-fuel stove is compatible with both isobutane and white gasoline—and you won’t have to change nozzles to switch between fuels. Simply flick the switch and you’re ready to go. This versatile stove provides a powerful, evenly distributed flame and can boil a liter of water in about 3.5 minutes. Plus, because it’s designed to prime the fuel before it reaches the head, it makes less noise than many other stoves. The Hydra weighs [310 grams] and features stable support legs for safe, level cooking.
The crux of the "deal" ...
Massdrop have a drop on the Kovea Hydra Dual-Fuel single nozzle multi fuel stove. The price is US$119.99 + $24 postage.
tmac100
Postby tmac100 » Wed Dec 28, 2016 2:25 am
Thanks for this. It sounds like a nice alternative to other-dual fuel models (Primus, I think). However, today (Dec 27/16) the Massdrop has ended. Maybe later it will resume.
I found this critique by a Google search - with a stand for inversion of the gas canister during cold-weather use (Europe/Canada/USA).
http://sectionhiker.com/the-kovea-hydra ... ing-stove/
Postby Aushiker » Tue Jan 03, 2017 10:00 pm
Massdrop have a drop on the Snow Peak Titanium cookset. US$69.99 + $11.75 postage.
Source: Massdrop
Postby Aushiker » Mon Feb 13, 2017 4:55 pm
Aushiker wrote:Massdrop have a drop on the Snow Peak Titanium cookset. US$69.99 + $11.75 postage.
Source: Massdrop
It is back at Massdrop ... same price.
tmac100
Postby tmac100 » Tue Feb 14, 2017 3:27 am
In addition to those Ti cooking items, Massdrop has recently had a variety of cook stoves. Right now there a Primus, I believe, on offer.
I just received notice that my latest stove purchase has been shipped by Massdrop. It is a Kovea cannister stove. Fortunately, I
was able to purchase a used Kovea (like the one you indicate at the top of this page) in Canada on MEC's gear swap site. Now to eventually get it from my son in Canada...
Parker
Postby Parker » Tue Feb 14, 2017 1:38 pm
I have read the entire thread but I am still confused as to which stove and cookware to buy for two people?
Money is not really an issue in this instance, we are happy to purchase products which will be long lasting.
Postby RonK » Tue Feb 14, 2017 3:20 pm
Parker wrote:I have read the entire thread but I am still confused as to which stove and cookware to buy for two people?
The questions to answer are:
1. What kind of food/preparation will you do? Are you going to actually cook, or will you simply rehydrate dried food?
2. How will you carry your camp kitchen? Is size/weight/volume likely to be an issue?
When carrying capacity is an issue, most campers will opt for freeze-fried meals/soups/beverages that only require the boiling of water to prepare, a compact gas canister stove such as the Kovea Spider, a titanium pot and mug and perhaps a folding plate or bowl. Of these, a remote canister stove such as the Kovea Spider allows the canister to be inverted for reliable operation in cold conditions.
If carrying capacity is not an issue then you might choose shellite pressure stove such as an MSR, or a metho stove such as a Trangia. Generally both the stove and the fuel is bulkier. A point to keep in mind is that most of this type of stoves have poor simmer control.
If you actually want to cook then you will probably need heavier pots which will transfer and diffuse heat much better than titanium pots.
I have used each of these types of stoves. Regardless of cooking type, my preference is for gas canister stoves. They are compact and easy to carry, quiet, have excellent simmer control and are safe to use with no risk of flare-ups. The fuel is light and burns cleanly, with no risk of messy leaks contaminating your food and gear.
Parker
Postby Parker » Wed Feb 15, 2017 12:59 pm
We are working up to the Munda Biddi trail next year. I suspect in most cases for our current touring that there will be towns every couple of days but I would like to experiment with options to start with.
We will be carrying everything on our frames, no issues there, at the moment it's just Frame bags however experimentation is the key at this point. So by the looks of it we should consider small and mighty. I suspect for the Munda Biddi it will be a mixture of reheat and pubs.
I will consider the Kovea.
Postby RonK » Wed Feb 15, 2017 8:34 pm
Parker wrote:We are working up to the Munda Biddi trail next year. I suspect in most cases for our current touring that there will be towns every couple of days but I would like to experiment with options to start with.
So with frame bags you will definitely constrained for space. Here is my camp kitchen setup, selected specifically to fit into an Anything bag and carried on one fork leg. There is another Anything bag on the other fork leg as my tucker bag.
Here is a picture of my framebag setup on a shakedown tour at Xmas. I have another Anything bag to fit under the downtube for my tent, but in scorching temps I didn't need to carry four-seasons camping gear or clothing.
Postby Aushiker » Sat Mar 25, 2017 3:43 pm
One for Aidan :)
The Primus OmniLite Ti stove is on offer at Massdrop. Looking at AU$188 delivered which seems a lot to me but then I am not into these flame throwers :)
For something a little more gentle in the bush ... they also have the Snow Peak Litemax Titanium stove as a drop. Looking at around AU$69 delivered.
Postby Aushiker » Sat Jun 17, 2017 1:04 pm
[quote="Aushiker"]Primus OmniLite Ti is back at Massdrop ... AU$188 on your nearest stump.
rifraf
Postby rifraf » Sat Jun 17, 2017 5:30 pm
Aushiker wrote:One for Aidan :)
Primus OmniLite Ti[/url] stove is on offer at Massdrop. Looking at AU$188 delivered which seems a lot to me but then I am not into these flame throwers :)
I don't think the price per see is particularly indecent when comparing to similar units, but I would warn aficionados that the Ti version takes more preheating than other heavier built "furnaces", thus you'll use more meths preheating than some other stoves and the meths quickly adds up.
The lack of weight is definitely a bonus but all in all, this hasn't made me feel inclined to stop missing my Optimus 111T.
I did buy an adapter to use the stove in my Trangia but I think due to the weight I'd be more inclined to take one or other as opposed to both.
Info for those tempted to look at Trangia conversion can be found:
https://classiccampstoves.com/threads/p ... gia.26152/
Sorry its a page at Classic Camp Stoves whose site is currently down and to add insult to injury you will likely need to sign up to follow my link or do a search at the site.
Heres a tube page showing a conversion;
https://www.youtube.com/watch?v=1WWFyTDPueY
The conversion is achieved with one of these:
http://www.ebay.ie/itm/Trangia-Multi-Bu ... 2029151833
(Wow, I didn't pay anything like that for postage for mine :shock: )
Which is what Trangia utilised with Primus I believe to create with the Omnifuel to come up with the Trangia X2 multi fuel burner.
Surly Ogre, Extrawheel trailer.
Postby Aushiker » Sat Sep 23, 2017 4:53 pm
RonK wrote:Since I now use a Kovea Spider instead of a Pocket Rocket, I don't have to precariously balance the pot on top of a canister-mounted burner, so the small ones are just fine.
Are you still using the Kovea Spider Ron?
Postby RonK » Sat Sep 23, 2017 5:10 pm
Yes, it's a winner for mine.
It is part of a carefully considered kit for bikepacking. Note how it all fits together in this post.
Postby Aushiker » Sat Sep 23, 2017 5:31 pm
RonK wrote:Yes, it's a winner for mine.
Thanks. That was the information I was looking for earlier. BTW your mention of the carbon felt wind shield caught my eye. Did you buy this or make it up yourself?
Also good to see you are using the 220g canisters. I had assumed they would be too big, but maybe I should actually test that theory with my kit :)
Postby RonK » Sat Sep 23, 2017 5:48 pm
The carbon felt windscreen came from Tier Gear in Tassie. I don’t see it on the web site anymore but it wouldn't hurt to email them.
I use either size canister depending on need. But in my anything bag it doesn’t make much difference which size I carry.
Postby Aushiker » Mon Sep 25, 2017 10:26 am
The EZ Eco is the “canisterless” version of the Kovea Alpine Pot. The Alpine Pot is Kovea’s take on a Jetboil type stove. What this means is it has a tank which you refill.
More information in Hikin Jim's review at Section Hiker.
hartleymartin
Postby hartleymartin » Wed Oct 25, 2017 9:21 pm
rifraf wrote:Thought I'd get in before anyone else to request the knowledge of what everyones using to
get the billy boiled and dinner on the way.
I've been using my Optimus 111C since Christ played halfback for the Israelites and then some.
My latest move back to Aus has shown I've forgotten to pack my alternate fuel nipples
so I'll have to get onto that so I can once again start using metho in it.
Back in NZ Kero is the cheaper fuel of choice.
I do prefer the metho as it doesnt stink your pack out long term if theres a spill.
I have not read the whole thread. If it has not been suggested yet, I can recommend the "Soda Can Stove" instructions to make it are here: https://www.thesodacanstove.com/alcohol ... build.html
I made one a few years ago and I used it when I went camping. It weighs almost nothing, costs almost nothing to make and runs using methylated spirit. I carry a 500ml bottle of the stuff on tours. A "charge" of fuel for this stove is about 40-50ml, and sufficiently boils the billy very quickly. In fact, it burns so hot, I can use it to cook eggs in a small to medium-sized cast steel skillet. You have to move quickly as it burns so hot that you can easily burn your food onto the pan, and I have not been successful in cooking bacon rashers with it. i was able to boil a pot of water in about 90 seconds with it.
Martin Christopher Hartley
rifraf
Postby rifraf » Thu Oct 26, 2017 12:27 am
G'day Martin,
Thanks for the tip :!:
I was forced to move on from the Optimus 111 when the delightful staff at the airport decided it needed to be confiscated despite the tank being filled with water and thus a little unlikely to bring down a plane.
I've since been getting by with a MSR Pocket Rocket, a Trangia 27/8 and a Primus Omnilight.
I'm sure people coming into the thread will benefit from your link.
Its reminded me a need a new simmer-lid for my Trangia ASAP. :)
hartleymartin
Postby hartleymartin » Thu Oct 26, 2017 2:54 am
If I remember correctly, I used the lid from a large milo tin as the primer pan. I found that it gets going best when you sit the stove on the tin lid, put most of the metho into the stove then just dribble a small amount off the side of the stove and into the pan. Light the metho in the pan and the stove gets going with the stove jets within a matter of seconds.
Of course, the advantage of this stove is that since you can by metho anywhere, you need not try to fly with fuel and if they confiscate even this stove, it is something easily made from a couple of soda cans.
I even used this little stove during a couple of blackouts a few years ago. As I recall, I was able to boil some chicken thigh fillets, potatoes and had a nice, if basic, little hot meal whilst the electrickery was out.
rifraf
Postby rifraf » Thu Oct 26, 2017 12:57 pm
hartleymartin wrote:If I remember correctly, I used the lid ........
Have you yet had a peruse through the whole thread?
If memory serves its the Caldera design that appears to show one of the interesting ways forward.
There are links from I think Andrew (Aushiker).
The Caldera utilises a piece of metal that locks together into a cone shape.
The pot sits at the top of the cone.
Likely to be one of the most fuel efficient methods of cooking with Metho/Alcohol and the one that has caught many an eye in the search for lightweight cooking. :)
Postby Aushiker » Thu Oct 26, 2017 3:01 pm
Very happy with the efficiency and functionality of my caldera cone stoves which I have brought from Trail Designs. However my 12-10 stove has been better days so have now replaced it with a Zelph Stovework's modified Starlyte burner. I have received mine but have yet to test it in the field.
Initial impressions are very positive. Very light but well made. Looks like it will be hard to destroy as well which is a bonus with ultralight gear.
hartleymartin
Postby hartleymartin » Fri Oct 27, 2017 2:59 am
Caldera might be more efficient, but it is pretty hard to beat the soda-can stove for price. I literally make them out of rubbish! If I break it or loose it, it is easy enough to make a new one with a pair of sharp scissors and a map-pin.
Postby Aushiker » Fri Oct 27, 2017 12:25 pm
The Trail Designs 12-10 stove is a soda can stove; it also eventually fell apart.
The points I consider but of course YMMV are:
[1] I don't want my stove falling apart on a tour/bikepack. When I tour I am often days away from a shop and even then I don't have the gear with me to make a new one so I want something reasonably reliable. For sure my 12-10 survived a lot of nights camping (well over 60) but it failed because it was not packed properly at one point and hence coped a loading which caused it bascially fall apart;
[2] Efficiency is very important to me; you mentioned a fuel usage rate early on which is nearly double my fuel usage. That translates to having to carry twice as much fuel. On some rides I can be out seven + days without resupply. I simply don't want to have to carry more than I need to [space and weight limits], hence I will use an efficient cone in combination with a stove, either the 12-10 as I have been or the new and hopefully as, if not more efficient Starlyte. The Starlyte is also more robust, a bonus.
and this is the Starlyte ...
Source: Tramplite Gear
Either way the cone is the windshield and key part of the stove setup.
hartleymartin
Postby hartleymartin » Sun Oct 29, 2017 12:42 am
If you are travelling overseas, alcohol-fuel stoves are ideal as gas cannisters will be confiscated by airport security, and you can land yourself a nasty fine if caught with them after landing.
