Good to know. I have ordered an Anker charging block. Will sort out a short power cable later and will now order a battery.rifraf wrote:I rate the Xiaomi batteries and now own three of them though I've yet to experiment with charging them via the dyno-hub.
Hub Dynamos in Australia
- Aushiker
Re: Hub Dynamos in Australia
Postby Aushiker » Tue Dec 19, 2017 12:09 am
Aushiker.com
- RonK
Postby RonK » Wed Dec 20, 2017 2:22 pm
How could you possibly resist?rifraf wrote:Its not a good sign that I'm already imagining the possibilities of colour combinations.
I like the polished silver but like the thought of black highlights.
It's in my top tube bag along with my camera, and is connected to both the charging port and the input port on the Beacon. I only use on trips though, don't bother around townrifraf wrote:I'm looking forward to eyeballing your setup. I was trying to imagine where you might be keeping your battery amongst your varied options of "gas tank" type bag, chaff or frame bag.
rifraf wrote:Oh and where are you hosting your pics I'd given up for a while after a certain sites attempt at extortion.
Some are on Imgur, others are on Google Photos.
- rifraf
Postby rifraf » Wed Dec 20, 2017 4:19 pm
Hi RonK,RonK wrote:How could you possibly resist?rifraf wrote:Its not a good sign that I'm already imagining the possibilities of colour combinations.
thanks for the update.
They are an attractive and interesting headlight.
As for resisting, they don't actually appear to do anything different to my E-werk/Edelux combo although I like the idea of the Beacons added horsepower in the lumins department.
Currently I'm going to hold off as I'm keen to try to escape from WA's February weather to a tour locale of cooler clime and thus thinking the money better spent on air fare tickets than nice shiny toys just now.
Having just bought a new gps and watch, the pennies are in shorter supply this close to xmas.
Other justifications include my suspicion that the gorgeous Beacon might just weigh more than my current combo, which baring a need to replace a rusty usb outlet cable (now done), has given me no cause for complaint.
That justification might come to naught though when I take into account the E-werk cache battery - hmmmmmm
I make sure I'm camped well before dark whilst touring and currently don't ride after dark much where I live due to the apparent abundance of skill lacking car drivers in my neck of the woods so suspect all those wonderful lumens might be a little redundant for my use.
It sure is purdy though and has a sirens song to an old magpie like myself with it ability to mix n match colour scheme with polished metal and anodised black which would offer a nice bit of bling to my black Ogre.
The forth in from the right is an approximation of what I was referring to as "highlights", though I was thinking of the main body in polished metal and just the front ring in black.
I shall revisit the decision in the new year.
Thanks for the update on the photo hosting, I shall do some homework in this area in time.
I haven't decided yet, but currently leaning towards a gas-tank type bag the same as Andrews for my battery.
I suspect the yellow would be a decent fit with my yellow/black Ortliebs.
Postby Crawf » Fri Dec 22, 2017 3:22 pm
I must have wiped the lens when covered in dirt which scratched it to the shizer.
Only thing I can thing of is like a car headlight, sand back the surface with a very fine sandpaper and respray with UV clear paint?
- find_bruce
- Moderator
Postby find_bruce » Fri Dec 22, 2017 4:34 pm
Sounds like a If its a plastic lens - toothpaste, some cloth and time on your hands is usually enough to polish out the scratchesCrawf wrote:Any tips for getting rid of micro scratches all over the headlight lens?
- Aushiker
Postby Aushiker » Fri Dec 22, 2017 6:23 pm
Aushiker.com
- RonK
Postby RonK » Fri Dec 22, 2017 6:37 pm
I don’t remember what power cord was supplied with my Anker charger, but you can get one with a flat power plug that is light and compact.Aushiker wrote:My Anker PowerPort Speed 5 arrived to day. Intial impressions are pretty positive. Weight is good given what it is (feels lighter than my older five port charger) and the form factor is not too bad. I can see this working out okay bikepacking.
- Aushiker
Postby Aushiker » Fri Dec 22, 2017 6:50 pm
Something like this ...RonK wrote: I don’t remember what power cord was supplied with my Anker charger, but you can get one with a flat power plug that is light and compact.
This eBay seller sells a 500mm cable which should do the trick.
Aushiker.com
- RonK
Postby RonK » Fri Dec 22, 2017 7:58 pm
Postby Crawf » Sat Oct 13, 2018 6:41 pm
- rifraf
Postby rifraf » Sun Oct 14, 2018 1:48 pm
Hiya Crawf,Crawf wrote:Dynamo lovers, I'm clearing out my dynamo gear and have some good kit for sale in the FS forum.
what are you gonna try next
- singlespeedscott
Postby singlespeedscott » Mon Oct 15, 2018 11:07 am
- rifraf
Postby rifraf » Mon Oct 15, 2018 4:00 pm
What hassle is there once your set up?singlespeedscott wrote:Battery lights because there is less hassle
I consider my dynamo set up a fit and forget.
Its been on my bike since 2012 and I think all I've done is change once the position of the headlight.
- singlespeedscott
Postby singlespeedscott » Tue Oct 16, 2018 9:11 am
Electrical wires and bicycles have been a combination that I haven't had much luck with over the years.rifraf wrote:What hassle is there once your set up?singlespeedscott wrote:Battery lights because there is less hassle
- rifraf
Postby rifraf » Wed Oct 17, 2018 11:26 am
With the level of investment to get set up, I can understand your pain if the results were problematic.singlespeedscott wrote: Electrical wires and bicycles have been a combination that I haven't had much luck with over the years.
I've read of some people having difficulties when their wiring diagram utilises the frame as part of the circuit, but know its not everyone who does this that experiences the problems.
I've not had any real problems to date so can't offer any wisdom on your issues.
I did get some corrosion issues on a couple of connections which put paid to my circuitry but upon examination, was reasonably obvious what was affecting continuous current and mirroring Australian cricket representatives, some judicious application of some sandpaper saved the day.
My cache battery gave up the ghost and the replacement doesn't appear to store as much power as its predecessor but my issues have been for the most part minor irritants.
Best of luck with your battery lights.
- MichaelB
Postby MichaelB » Wed Oct 17, 2018 2:59 pm
Mind you, I never really had any real problems with my Chinese lights either.
- Aushiker
Postby Aushiker » Mon Oct 22, 2018 6:58 pm
Aushiker.com
Postby Jubas » Fri Mar 01, 2019 10:32 am
I've just ordered a shimano dynamo hub for a 650b wheelbuild that I'm putting together. It's very much on a budget, so was a toss-up between Shimano and SP. I went for the former as it was slightly cheaper and user-serviceable. It's a 12mm hub and there seemed to be some issues with the SP dynamo hubs with that configuration - and I'd rather not have to send it back to the factory if I was unlucky.
I was wondering whether anyone had any recommendations for tracking down second hand lights? There was one posted on BNA a while back, but it seems to be fairly rare. Other there other AU forums that I might track down?
- Mugglechops
Postby Mugglechops » Tue Mar 19, 2019 9:48 am
Wow is all I can say. I have been using an Exposure Revo since the end of 2016 and this is so much better, and way better than the AXA 70luxx I had fitted, which is really not suited to a completely dark commute in the country. Great light for the city though.
I am now saving to buy my own one.
- MichaelB
Postby MichaelB » Tue Mar 19, 2019 10:08 am
1300 lumens and $325. No details of battery pack, or is it dynamo run (hence in this thread ?)
Presuming the latter (as there are no details on the link), what dyno's can power it ?
- Mugglechops
Postby Mugglechops » Tue Mar 19, 2019 10:16 am
I assumed it can be powered by any of the common dyno hubs.
Postby Baalzamon » Tue Mar 19, 2019 10:33 am
Believe dynamo powered going off http://www.bikepacking.com/news/klite-bikepacker-ultra/MichaelB wrote:1300 lumens and $325. No details of battery pack, or is it dynamo run (hence in this thread ?)
Postby gsxrboy » Tue Mar 19, 2019 10:34 am
A couple of questions on the KLite
a) Is the cable exit swappable to the other side?
b) Is there a mode selector for different light outputs?
c) How flexy is the cable?
Cheers!
- Mugglechops
Postby Mugglechops » Tue Mar 19, 2019 11:12 am
b) The light is automatic. It increases brigthness with your speed.
c) The cable can be as flexy as you want as you can just build your own.
- MichaelB
Postby MichaelB » Tue Mar 19, 2019 12:44 pm
Cool !!Baalzamon wrote:MichaelB wrote:Believe dynamo powered going off http://www.bikepacking.com/news/klite-bikepacker-ultra/Mugglechops wrote:I got to try out the K-Lite Ultra MTB version on my commute today.
