Suntour/Shimano top mount shifter boss adapter
- familyguy
Postby familyguy » Tue Jun 12, 2018 3:04 pm
This is the lever boss location:
- 10speedsemiracer
Re: Suntour/Shimano top mount shifter boss adapter
Postby 10speedsemiracer » Tue Jun 12, 2018 3:22 pm
I have seen something similar by Shimano in the same era, think it was in the Touring line, however don't know whether the thread is the same.
The shifters (friction) are floating around on eBay via a couple of different European sellers.
- familyguy
Postby familyguy » Tue Jun 12, 2018 3:36 pm
I may end up machining one yet.
- 10speedsemiracer
Postby 10speedsemiracer » Tue Jun 12, 2018 3:40 pm
- familyguy
Postby familyguy » Tue Jun 12, 2018 3:46 pm
- 10speedsemiracer
Postby 10speedsemiracer » Tue Jun 12, 2018 4:00 pm
Some LBS stock Origin8 or can grab it off the eBay.
- Thoglette
Postby Thoglette » Tue Jun 12, 2018 4:02 pm
Hmm, Shimano had something similar. See this Ricardo Elite (c. 1983). I've probably still got one at home.familyguy wrote: Short of designing and 3D printing an alternative, is there a readily available unit or device
Or look on ebay
- familyguy
Postby familyguy » Tue Jun 12, 2018 4:28 pm
Yep, jut saw those. Rather inelegant, though would work for a while until I machined something up. I won't be pulling fittings off the frame, rather not go to that extent and have to repaint it.10speedsemiracer wrote:This is the shifter boss adaptor I was thinking of :
- Thoglette
Postby Thoglette » Tue Jun 12, 2018 4:37 pm
I'd be finding a length of alloy and cutting a groove across it to mount on the frame boss (bolt hole also needed) & then drill/tap holes for adjustable cable stops at either end. A prototype in wood might be a good idea...familyguy wrote:The question is...how to adapt the Suntour or Shimano unit to become simply a cable stop. I won't be running levers.
- Clydesdale Scot
Postby Clydesdale Scot » Tue Jun 12, 2018 5:29 pm
Gofamilyguy wrote:3D printed metal? Now that'd be nice...
https://www.shapeways.com/materials/steel and the data sheet
Postby LG » Tue Jun 12, 2018 5:31 pm
- find_bruce
- Moderator
Postby find_bruce » Tue Jun 12, 2018 6:09 pm
It is possible, but you will need to butcher the mount to get thisfamilyguy wrote:The question is...how to adapt the Suntour or Shimano unit to become simply a cable stop. I won't be running levers.
an account of the butchery here
What you want is this
which I understand is left behind by rocking horses
- familyguy
Postby familyguy » Tue Jun 12, 2018 6:10 pm
- gm6046
Postby gm6046 » Thu Jun 14, 2018 10:35 pm
- familyguy
Postby familyguy » Fri Jun 15, 2018 8:50 am
- find_bruce
- Moderator
Postby find_bruce » Fri Jun 15, 2018 2:52 pm
Are you copying the design for top mount round tubes (like Jim's) or aero tubes ?gm6046 wrote:I'm going to do a run of new rocking horse poo replacement ones shortly. CNC machined. Just waiting to get some dimensions from someone who is measuring one up.
- 10speedsemiracer
Postby 10speedsemiracer » Fri Jun 15, 2018 3:02 pm
Looking at the top example, I'm not sure that would result in the ideal cable route, but the lower example is properly clever and would keep everything running and even looking almost OE. That is very cool.find_bruce wrote:It is possible, but you will need to butcher the mount to get thisfamilyguy wrote:The question is...how to adapt the Suntour or Shimano unit to become simply a cable stop. I won't be running levers.
- gm6046
Postby gm6046 » Fri Jun 15, 2018 5:23 pm
It will be for the Aero tubes, but it wouldn't be hard to machine up something for round tubes if there was interest.find_bruce wrote:Are you copying the design for top mount round tubes (like Jim's) or aero tubes ?gm6046 wrote:I'm going to do a run of new rocking horse poo replacement ones shortly. CNC machined. Just waiting to get some dimensions from someone who is measuring one up.
- find_bruce
- Moderator
Postby find_bruce » Fri Jun 15, 2018 9:55 pm
I will stick my hand up for an aero version. I don't need it for my frame, but if I ever do, its now or spend years searchinggm6046 wrote:It will be for the Aero tubes, but it wouldn't be hard to machine up something for round tubes if there was interest.
- familyguy
Postby familyguy » Sun Jun 17, 2018 9:50 am
- gm6046
Postby gm6046 » Wed Jun 20, 2018 4:04 pm
I'm not sure if all the Aero tubes are the same or are close enough to interchange. I'll post up some pics and dimensions shortly. Either way, I'm happy to machine them up to match specific tubes profiles if someone has an oddball size.familyguy wrote:Would be interested in the round tube version, as above. Which aero tubes are you getting thrm done for? Are they all somewhat similar?
Postby baybiker » Sat Sep 08, 2018 3:55 am
Hi, I just found this through a google search. I am interested in a round-tube version as well for a 1982 Univega, which has a 28.6mm diameter downtube. Have you moved forward with machining this part? Thank you...gm6046 wrote:I'm not sure if all the Aero tubes are the same or are close enough to interchange. I'll post up some pics and dimensions shortly. Either way, I'm happy to machine them up to match specific tubes profiles if someone has an oddball size.familyguy wrote:Would be interested in the round tube version, as above. Which aero tubes are you getting thrm done for? Are they all somewhat similar?
- gm6046
Postby gm6046 » Sat Sep 08, 2018 6:22 pm
I think there may be some variation in the depth of the square boss that the mount locates on, but that can be machined to suit if needed.
Here are a few pics. I don't have an aero frame on hand, so I have just sat it on another frame to give everyone an idea of what it looks like.
- Clydesdale Scot
Postby Clydesdale Scot » Wed Sep 12, 2018 5:47 pm
Postby Stevensb » Wed Jan 15, 2020 10:44 am
Cheers.
Brad
