Lower Back Pain between 15klm-20klm
Postby Deus_Ex_Machina » Thu Aug 09, 2018 8:18 pm
So I have not done much road riding in my time but am starting to train for a Triathlon and find I get very sore in the lower back (top of the iliac crest) almost without fail between 15-20 klms. I did a Sprint tri last summer 26klm (on very little training as I was intending to do a 1/2 mara instead but long story) and was quite painful by the time I got off the bike, onset was about the same point at 15klm. I have only done 2-3X 10klm-15klm rides the last couple of weeks, did a 20klm Sunday and another 20klm today. By the time I hit 20 it's quite distracting and affecting how I ride alot. Once I'm off and stretch it out for a bit there isn't a whole bunch of residual discomfort.
I have had my bike fit checked at a local shop and feel the guy was very thorough (didn't change much from what I had set up) and also had a friend who has done a lot of Tri's/Ironman over the years who felt it looked OK.
I'm fairly fit, swim 2-3klms twice a week, some speed and longer run work and get a basic strength set in, I would have thought the bod would take the bike no probs but maybe just needs time to adapt to such a flexed position on the drops? Everything I read on sore lower back says you might be too stretched out, if anything as it gets sore I kinda feel like moving my arse back a notch.
Is it odd for someone fairly fit to struggle with 20klm at a 30klmish pace or am I ramping too quickly?
P.S. My Bike is a CAAD8, I'm 38, 179cm, 73kg, pretty average proportions, if anything longer limbed.
Any advice would be helpful as not sure whether to keep grinding at lower klms and wait for adaptation or if it sounds like I'm still set up wrong.
- ValleyForge
Re: Lower Back Pain between 15klm-20klm
Postby ValleyForge » Thu Aug 09, 2018 9:16 pm
The are not muscles heavily used outside cycling and weight-lifting. They are incredibly important for posture and stability, but being in a TT/aero position makes them work proportionately harder than say your quads or glutes. If you have a second bike with a more classic position you are likely to find you get sore quads & glutes before your back. Also getting out of the saddle and doing "bike-yoga" helps; but it's not aero.
I note from your last line about "grinding" that you might be keeping a low cadence which will make the soreness worse.
Postby Deus_Ex_Machina » Fri Aug 10, 2018 9:38 am
Morning after the soreness def feels like it's at the top of the glutes/insertion area as opposed to true lower back (QL for example). Actual muscle bellies of the glutes (and quads) have zero anything as was overall a cruisey pace. Hip flexors don't feel too bad but I hear what you are saying and the heavy hip flexing in the drop position may pull the pelvis down into an anterior tilt which is not comfy for the lower back, tries to further elongate glutes.
Wondering if I might shift seat forward and down slightly and see if it tips the balance of quad to glute work?
RE grinding thats a good pickup. I have been deliberately riding higher cadence lower gear as yes grinding away on high makes it come on faster.
Postby Calvin27 » Fri Aug 10, 2018 12:00 pm
- Riding and then sitting - this causes the hams to freeze up hard and over time causes lower back pain that tends to surface at about the 20km mark for me.
- Generally core strength is lacking imo. You may be fit, as you're probably aware not all fitness is the same. I've had to do a crapload of core stuff to be able to ride 100km comfortably. I used to literally get off the bike and stretch which helped but hardly useful for most ride where you are on the bike for long periods of time. If you've done a bike fit, they should be able to make a call on this one by looking at the pressure you put on the handlebars - should be like playing a piano apparently.
- I have moved some fitting stuff around to shift the load but generally I've gone back to the bike fit spec. Not sure about the science, but I prefer to load the glutes slightly more than the quads - prior to the fit my quads were getting burnt up really fast and I had some issues with glute activation after some time off a bike.
- This one is an easy one - try so some off saddle grinds. Great for lactic threshold conditioning and changes the position up a bit. I see a lot of tdf guys do this - must be good haha!
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
- ValleyForge
Postby ValleyForge » Fri Aug 10, 2018 12:15 pm
If you have a good bike fit and a good aero position, don't change it - change the way you ride, either with another bike or just not riding in the tuck all the time.Deus_Ex_Machina wrote:Hip flexors don't feel too bad but I hear what you are saying and the heavy hip flexing in the drop position may pull the pelvis down into an anterior tilt which is not comfy for the lower back, tries to further elongate glutes.
I don't think the pelvic angle is an issue - it doesn't sound like a mechanical pain due to axial skeleton positioning. If that was the case the pain doesn't "stretch" out; it has a slower, less definite onset and lasts for a few days.
Postby RhapsodyX » Fri Aug 10, 2018 12:26 pm
I'm "sort of" back riding (almost eight months since surgery), but since working on fixing the underlying issues it's interesting to note my lower back doesn't "click" when I dismount, and the core is so much more stable when riding.
Postby Deus_Ex_Machina » Fri Aug 10, 2018 1:24 pm
I am a touch achey and sore today after a sleep.
Going to add in some specific lumbar work like Jefferson curls, I already regularly do a pall off press which is not dissimilar to a side plank as far as muscles worked.
Once the a aches are gone I'll try the new position and check back. Thanks for all the advice, its much appreciated.
Postby Deus_Ex_Machina » Fri Aug 10, 2018 2:41 pm
- Derny Driver
Postby Derny Driver » Fri Aug 10, 2018 7:29 pm
So you had a PROFESSIONAL bike fit and they tilt your handlebars up like that? Wow.Deus_Ex_Machina wrote:
Im not talking about the stem. The hoods need to be flat.
Rotate the whole bars so the hoods are lower and the bottom of the drops are about 10 degrees, not 30
- mikesbytes
Postby mikesbytes » Fri Aug 10, 2018 9:02 pm
I'm not a fan of Jefferson Curl's but its your body so you decide. I'd suggest that you get more cycling in to improve the strength there in the position that you are riding in. Could you perhaps add a couple of bike commutes in (I know it depends on if you need to carry equipment etc sometimes) or grab a ride in the gaps? I'm thinking of rides just a tad short of where you get the discomfort in addition to your current rides.
- trailgumby
Postby trailgumby » Sat Aug 11, 2018 2:13 pm
Be prepared to suspend judgement, some of the testing they do is pretty out-there. This testing will help identify where your pain issues are sourced in ways that simply dropping you on a bike will never bring to light. If you are getting pain in such short distances, it suggests something is wrong either biomechanically or with muscle recruitment. I had both. Bike fit alone was not enough for me - some physiotherapy and a maintenance training regimen was also required.
In my 3-hour fit session, only the last half hour was spent on the bike. Previously I used to get a lot of pain in my sacro-illiac joint and knees. Now I am planning longer and longer rides. 90km today. Hopefully a full metric century next week. The goal is an imperial century sometime later this year.
Message me if you want details. One is in Sydney, the other Canberra.
- foo on patrol
Postby foo on patrol » Sat Aug 11, 2018 3:19 pm
Derny Driver wrote:So you had a PROFESSIONAL bike fit and they tilt your handlebars up like that? Wow.Deus_Ex_Machina wrote:
Yeah, that's just plan wrong like that!
Foo
Goal 6000km
Postby jaythefordman » Mon Aug 13, 2018 1:29 am
Those aren't weird, you're looking at them wrong. aside from the kick up at the hood ends they are close to flat, and that the drops are not meant to be 'parallel', but a shallow curve up. Works well with a longer stem. his is how my bars/hoods are set and I can tell you that to drop the hoods down further will result in all sorts of pain. Sure, you can run a shorter stem and slam it so you are on top of the bars, then what you say makes sense.Derny Driver wrote:So you had a PROFESSIONAL bike fit and they tilt your handlebars up like that? Wow.Deus_Ex_Machina wrote:
- Derny Driver
Postby Derny Driver » Mon Aug 13, 2018 9:12 am
Brickwork must be crooked then if you think the hoods are 'flat'.jaythefordman wrote:Those aren't weird, you're looking at them wrong. aside from the kick up at the hood ends they are close to flat, and that the drops are not meant to be 'parallel', but a shallow curve up. Works well with a longer stem. his is how my bars/hoods are set and I can tell you that to drop the hoods down further will result in all sorts of pain. Sure, you can run a shorter stem and slam it so you are on top of the bars, then what you say makes sense.Derny Driver wrote:So you had a PROFESSIONAL bike fit and they tilt your handlebars up like that? Wow.Deus_Ex_Machina wrote:
The 'shallow curve up' on the drops should be just that, shallow. 10 degrees, not 30.
The bars dont need slamming, they just need to be correctly fitted.
Postby jaythefordman » Mon Aug 13, 2018 5:38 pm
I wasn't looking at the brickwork as for all we know the front wheel could be raised a bit thus creating the appearance of a large tilt up.Derny Driver wrote:Brickwork must be crooked then if you think the hoods are 'flat'.jaythefordman wrote:Those aren't weird, you're looking at them wrong. aside from the kick up at the hood ends they are close to flat, and that the drops are not meant to be 'parallel', but a shallow curve up. Works well with a longer stem. his is how my bars/hoods are set and I can tell you that to drop the hoods down further will result in all sorts of pain. Sure, you can run a shorter stem and slam it so you are on top of the bars, then what you say makes sense.Derny Driver wrote: So you had a PROFESSIONAL bike fit and they tilt your handlebars up like that? Wow.
I just looked at the hoods and angle to the stem/top tube, and while I agree the hoods could drop a touch, from looking at it I certainly don't think its as extreme as you see
Postby RhapsodyX » Mon Aug 13, 2018 7:49 pm
Well.. if you look at the FIRST photo (of the whole bike), maybe you will see what the rest of us are all seeing. The bars are rotated upwards - there's no need to move the brifters on the bars.jaythefordman wrote: ...
Postby lone rider » Tue Aug 14, 2018 11:43 am
- Derny Driver
Postby Derny Driver » Wed Aug 15, 2018 4:59 pm
I agree mate. I have no idea about the pain but for a bike fitter to have the seat slid right back on the rails and the bars like that ... its horrible. A good start would be to set the bike up properly.lone rider wrote:Without seeing somebody on the bike, I dont think the bars rotated should make a difference, it looks like its been done to avoid changing the stem. I think the problem is at the saddle, looks like a setback post with saddle too far back and the saddle angle is gonna result in a very upright position which most newbies will ride like. The resulting hip and knee angle's in riding like that would be causing strain in all the wrong areas.
- mikesbytes
Postby mikesbytes » Wed Aug 15, 2018 8:34 pm
As others have said, without a photo of him on the bike we can only guess at the issues and that seat position is suggesting there is something fundamentally wrong. I'm going to take a straight guess that the bike isn't long enough, which of course could be fixed with a longer stem.
More importantly I'm also thinking that seat position is increasing the severity of the curvature of spine immediately above the pelvis which in turn could be increasing the issue being faced
Postby Deus_Ex_Machina » Mon Oct 01, 2018 9:32 am
