MTB rear brake chronic squealing - I've run out of solutions........
- open roader
Postby open roader » Sat Oct 20, 2018 6:12 pm
Several weeks ago built up MTB with new XTR M9000 brake calipers / new Shimano Ice Tech disks / new pads
Front brake worked fine from the start - rear had chronic squeal from the beginning.
Just toughed it out for the first week - say 60km but that is enough bedding I figured and just replaced pads in the 2nd week.
Noise even worse with new pads - truly loud and horrid.
Have tried the following :-
Checked rotor for straightness- perfect from new.
Checked rotor bolt torques
Checked rear axle tension
Loosened off the caliper mounts / held brake lever on then re-tensioned caliper mounts.
Cleaned rotor and caliper pistons with brake cleaner - then cleaned rotor with acetone (have done this twice now)
More bedding in riding (over 50km) still horrid
Today I tried de-glazing the pads on emery paper and a block
After 6-7 weeks the brakes are still truly horrid- hugely loud - mega decibels like I've never experienced before with a shocking shudder if I pull to much lever on in frustration (carbon frame might make this sound worse as it's my first carbon MTB)
Aside from replacing the entire caliper I'm all out of ideas as the front brake works a treat straight out of the box..........
Help please! Can't ride it - feel like killing it! Very disappointing for someone who can usually nail down these sorts of things.....
Re: MTB rear brake chronic squealing - I've run out of solutions........
Postby Tamiya » Sat Oct 20, 2018 7:59 pm
No idea if that's in today's SOP mechanics manual, YMMV, but that was BiTD & we've tried even dumber things before...
- open roader
Postby open roader » Sat Oct 20, 2018 8:24 pm
I recently completed another MTB build a few months ago - will switch the rotor (solid type ie not floating) and try it out too.
Postby Tamiya » Sat Oct 20, 2018 9:40 pm
Did u actually spray brakecleaner onto the new pads after installing? ( I assume aerosol brakecleaner from autoparts store) Some swear by it but I find it's too harsh & doesn't really "degrease" all that fully... or maybe it's actually pulling out some component in the brake pad itself, who knows...? Could be like brakepads that have overheated once too often - they're always more squeaky & fade faster after being overcooked. These days in garage I don't use it on "new" brakes anymore, only to clean everything down before starting work.
Acetone don't do much for me either, I mainly use it for cleaning off paint & dissolving dried grease. Have isopropyl alcohol but leaves water moisture behind. Shellite/zippoFluid probably degreases better.
For pushbike degreasing I've moved onto Electrical Contact Cleaner spray, buy it from Repco/Supercheap etc ... seems to dry faster, no residue & less harsh on paintwork/skin. After working on discs & everything is bolted back, I flush the whole works with that spray - let it drip off, never wipe. Then go test ride, no need to wait for it to dry.
Whenever that can is empty I grab trigger bottle of Windex does fair job degreasing too.
- open roader
Postby open roader » Sat Oct 20, 2018 10:28 pm
I used Bendix Brake Cleaner Spray on the inside of the caliper only (piston interfaces) The pads are untouched, no hand contact, no acetone, no brake cleaner.
I'll get some electrical contact cleaner and leave the acetone for other things.
There is so much contradictory advice to be read about this elsewhere online - BNA is the only place I ask questions and take advice seriously.
Tomorrow I swap out the rotor for a solid billet lightly worn unit and see if that makes any difference...........
- trailgumby
Postby trailgumby » Sat Oct 20, 2018 11:17 pm
And why resin? They disappear in wet weather like a box of chocolate Paddle Pops on a hot day. Metallic are the go.
Sometimes it's just the rotor. Have you thought of switching it out and seeing what happens?
Postby Tamiya » Sun Oct 21, 2018 12:39 am
it's not a "balance" issue, if that's what you're thinking. IMHO pushbike wheel don't go fast enough for balancing to matter muchopen roader wrote:Ok, I get the lead tape tip now- use as counter ballast.
dunno if the added weight changes the harmonic buzzing outside of squealing range or if the added mass acts like a damper instead
If you've got blutac try that first it'll do same, just doesn't hang on as well
I buy Wilson Lead Tape from proshop (I'm a racquet tuning geek in another life). Comes 2 strips of 50cm per pack, each strip is 20g worth. Self adhesive, snip with scissors... strangely useful in many non tennis situations.
- open roader
Postby open roader » Sun Oct 21, 2018 11:03 am
Exactly this. I have a steep, straight bitumen road leading into town (10% gradient average all the way down a 1000m section) I have ridden the new pads 8 times down this hill incl. 5 down and striaght back up on the same day - tried all sorts of modulation applications. I feel can't test my brakes down there anymore as the noise is horrendous and it's 100% residential......... and I like to stay in the local's good books..........trailgumby wrote:How are you bedding in your pads?
This morning I switched out the rotor for the rotor on the previous build which is whisper quiet - zero difference. Very dissappointing too. My previous build uses XT brakes and Avid rotors, this has to be the best disk brake set up I've ridden (and I've tried a few on mate's and hires bikes etc)
To keep my 'fix' in house the only thing left is to switch the caliper over for the XT model I have on the previous build. A complete pain in the arse to re-bleed everything, however, this is the very last variable yet to be tested (and maybe fit the XTR caliper to the previuos build to see what happens.
I just can't see how a bike shop mechanic is going to find anything more than I have using a straight method of elimination. Did I just get uber lucky with the previous build - fitting 100% new everything and getting a perfect result from the first turn of the wheel?
- Mububban
Postby Mububban » Sun Oct 21, 2018 12:34 pm
OP obviously knows his stuff as well as you, but I just recently got my first disc brake MTB and followed your advice above (and in the Park Tool video below) and my new baby brakes nice and quietly nowtrailgumby wrote:How are you bedding in your pads? I find it takes at least a dozen good hard-braking downhill passes at speed (and rolling out of the brakes before coming to a complete stop) before you start to get consistent bite and no squealing.
This video was very helpful for a noob like me (start 1:25 in).
I've also got discs on my road bike, I didn't do any "official" bedding in or maybe it wasn't necessary as it was a test bike so had been ridden before I got on it. But man, they do shriek in the wet
- open roader
Postby open roader » Sun Oct 21, 2018 2:52 pm
This is pretty much what I have tried. My hill is considerably steeper so I don't need to pedal to get back up to speed for another hit.Mububban wrote:This video was very helpful
I have not tried using clean water on the disk/pad interface whilst braking - I need to find a quiet hill out of town and give it a go.
Might also gladly fork out for metal sintered pads - anything to get a rideable bike! I was under the impression that metal pads squealed worse then resin...........? You simply can't believe everything you read online............
- trailgumby
Postby trailgumby » Sun Oct 21, 2018 9:33 pm
I am having it at the moment though. It's an old bike I've ridden little in the last 2 years and suspect the rotors got contaminated with spray lube while hanging in the garage, which then transferred to the pads. If so, the pads will need to be chucked and the rotors cleaned before they are replaced. That'll have to be done this week. The bike is on eBay with a scheduled close date of next Sunday.
- open roader
Postby open roader » Mon Oct 22, 2018 8:20 pm
I have a pair of solid steel rotors on the way too.
One change up at a time.
Also think I need to double or triple my bedding in repetitions.......... and not clean the rotor again.......... I was rolling at 8-12km/hr down the hill for each of the bedding runs - no real speed involved as I know heat is the enemy, esp at the beginning.
Watch this space..........
- Duck!
Postby Duck! » Mon Oct 22, 2018 8:46 pm
- open roader
Postby open roader » Mon Oct 22, 2018 9:12 pm
Cheers Duck. I can hang off the back of the saddle a fair bit on this bike (get some weight back onto the rear end)Duck! wrote:Rears are often a bit more temperamental because they do so little proper braking and tend to unload the wheel and just lock under hard application.
I'm going to get a bad rep for disturbing the peace down that hill..........
- Duck!
Postby Duck! » Mon Oct 22, 2018 9:42 pm
My understanding was that the 02 resin compound used from the M9000 series onward was a bit more user-friendly (aka less prone to glazing) than the previous 01 compound, which I'd found needed scuffing off after almost every ride. Metal pads are so much better. They don't have as much instant bite as resin, being harder, but have much better overall power, vastly superior modulation and better heat tolerance. I get the odd groan when they're really doing a heap of work, and under normal use generate a bit more scraping noise than resin, but that's a tiny trade-off for the performance benefit.
Leave the Ice Tech rotors, especially if heat will come into play on the trails. They work. If you're only doing light trail stuff there's no real difference between Ice Tech and solid stainless steel (the braking surfaces are the same, the difference is that with Ice Tech it's a thin veneer on each side of an aluminium core), but if you're working the brakes harder, they do run cooler and keep the brakes from fading.
- boyracer
Postby boyracer » Wed Oct 24, 2018 4:40 pm
- open roader
Postby open roader » Sun Dec 23, 2018 2:43 pm
Alas I've had precisely zero progress from previous postings.
So far I have done the following :-
Tried both used and brand new resin pads x 13 consecutive bedding in runs (nearly 50 braking actuations)
Tried both used and brand new metal pads x 11 consecutive bedding in runs (40 braking actuations)
Lightly abraided all 4 pairs of pads with fine wet and dry paper after the initial 5 bedding runs of each pad type
Ditched the Ice Tech rotors and purchased a new pair of solid steel rotors and repeated the above with 10+ runs each combo
Replaced the caliper frame mount bolts
Pulled the caliper off and cleaned the piston to pad backing interface
Bled out the entire oil reservoir and line and replaced with fresh mineral oil - bled out overnight
Re-tensioned the rotor mounting bolts to the recommended torquing level
Gave up in disgust and left it with the LBS for 2+ weeks - it came back on Friday with no change and no helpful suggestions........... (and no charge either)
My rear caliper is still howling at mega decibels - none of the above had any effect. I've put in so much work, ridden up the friggin hill so many times and spent so many afternoons raising the ire of some of the local residents with my noisy downhill bedding runs.......... I'm just about a local pariah now!
The brake is actually working fine - it pulls the bike up well but the noise is horrendous right from the initial lever pull.
Am I justified in thinking the caliper is malfunctioning in some way and it terminal as the front caliper has coped with the change of pads and change of rotors with no ill effects at all - which is what I expected from a brand new XTR caliper?
Anyone care to make a decision for me because I'm just so !! BAN ME NOW FOR SWEARING !! off with the entire thing - I don't know what to think anymore.......
- Duck!
Postby Duck! » Sun Dec 23, 2018 11:59 pm
- open roader
Postby open roader » Tue Dec 25, 2018 11:17 am
Finally I have a properly operating rear brake. All I did was place a 0.6mm thick washer in between the caliper and the frame to lift the caliper a tad higher on the rotor and instantly I have silent running brakes!
I looked at the track mark on the front rotor and saw the track mark on the rear rotor was just a tad closer to the centre of the rotor. I had the washers in my box of spares all this time - just 0.6mm makes all the difference. I can't believe the fix for this has been under my nose the whole time!
Now I have a new bike (build) to ride right in time for Christmas!
Yeti SB6c Dec-2018 by Matthew Brennan, on Flickr
Postby davehirst » Wed Dec 26, 2018 9:57 am
- RonK
Postby RonK » Wed Dec 26, 2018 10:07 am
- open roader
Postby open roader » Wed Dec 26, 2018 11:13 am
Yeah, there is that. I've lost my fear of riding up the 15% kicker section at the top end nowRonK wrote:And think how much fitter you are after doing multiple reps of that test hill.
- Mububban
Postby Mububban » Thu Dec 27, 2018 10:23 pm
- find_bruce
- Moderator
Postby find_bruce » Sun Feb 03, 2019 12:29 pm
I was having exactly the same problem except on the front. New 180mm disc (old one was just 1.2mm thin), new resin pads & they suddenly started squealing. went through the same process as you. After re-reading this thread I looked at the disc this morning - no wear marks on the outer 1.5mm of the disc, wear marks 1.5mm past the inside of the discs, down the "spokes". I have 1.5mm washers so have spaced the caliper out & will see if that has fixed it.
- Duck!
Postby Duck! » Sun Feb 03, 2019 7:51 pm
Users browsing this forum: MattyK
