Bike wheels
Bike wheels
Postby pontrumlee » Thu Dec 06, 2018 2:03 am
I am thinking of buying new wheels for my Merida ride 91 I way 100kg and ride about 200 k per week...my question is how much advantage would there be in me swapping my Alex 24 rims for something a bit lighter..any help would be appreciated
Re: Bike wheels
Postby Neddysmith » Thu Dec 06, 2018 9:05 am
- Paddles
Re: Bike wheels
Postby Paddles » Thu Dec 06, 2018 9:09 am
Re: Bike wheels
Postby Ivanerrol » Thu Dec 06, 2018 9:33 am
After the last visit to the LBS to get some wheels trued, I was advised to get off those 622.14 wheels with 24mm tyres and onto wider wheels and tyres.
The subject of lighter wheels came up. The advise was to stick with 32 spoke wheels with a minimum inside width of 17mm and 28mm tyres.
My body weight vs minor wheel weight reduction was subjective.
Alex Rims being generally the bottom of the rung wheels installed on new bikes to keep the costs down.
I'd be more concerned with these less expensive wheels going out of true more often.
Not necessarily lighter wheels but better quality, sturdier wheels.
When I retook up cycling I weighed 115 kilos. I managed to get down to 95 kilos in six months. A layoff for a few months meant the weight crept up to 102 kilos. I'm now back to 100 and going down slowly. My hill climbing ability is directly proportional to each kilo I take off.
- find_bruce
- Moderator
Re: Bike wheels
Postby find_bruce » Thu Dec 06, 2018 9:50 am
Sure if you want to buy bling then whatever makes you happy, just don't fool yourself that there will be a significant performance gain
Re: Bike wheels
Postby Deus_Ex_Machina » Fri Dec 07, 2018 11:14 pm
Re: Bike wheels
Postby madmacca » Sat Dec 08, 2018 2:29 pm
https://www.sheldonbrown.com/tire-sizing.html#width
Many of the lighter wheels have a weight limit of 85-90 kg. Unless the width is limited, I'd save your cash at the moment.
Re: Bike wheels
Postby NASHIE » Sat Dec 08, 2018 6:10 pm
Re: Bike wheels
Postby paule11 » Sat Dec 08, 2018 8:22 pm
- biker jk
Re: Bike wheels
Postby biker jk » Sat Dec 08, 2018 8:59 pm
The op is close to the weight limit for Campagnolo wheels of 109kg so not a great suggestion. 16 spokes on the front and 21 on the rear for a 100kg rider is asking for trouble. Just curious to know what makes those wheels fast?paule11 wrote:Get Campagnolo Zondas stiff strong light and fast
- rodneycc
Re: Bike wheels
Postby rodneycc » Sun Dec 09, 2018 9:27 am
Zondas are great. I hover between 100kg and 105kg and I've had Zondas for years (the 2013 old 15mm wide so even narrower than the current ones). 109kg weight limit I would say is fairly generous guide with a bit of leadway like most of the Campy/Fulcrum range which are just brilliant (and Ive tried most).biker jk wrote:The op is close to the weight limit for Campagnolo wheels of 109kg so not a great suggestion. 16 spokes on the front and 21 on the rear for a 100kg rider is asking for trouble. Just curious to know what makes those wheels fast?paule11 wrote:Get Campagnolo Zondas stiff strong light and fast
I bought my Zondas secondhand, did a few thousand kms and have sold them onto a work collegue who loves them as well replacing his stock wheels on a Trek Domane ( which he buckled one on a crash). I advised him not to run 28mm tyres on them (being 15mm) at the time but he did anyway and said they run great without a problem on his commutes. The current Zondas would be great with 28mm tyres and ideal for fast tarmac commutes.
Maybe 120kgs I'd be worried (so 100kg plus a lot of packing). But at 100kg like me with min packing then not a problem. Not many people would take an airline suitcase worth of weight with them on the bike!
https://intheknowcycling.com/2017/04/25 ... -squirrel/
- rodneycc
Re: Bike wheels
Postby rodneycc » Sun Dec 09, 2018 9:41 am
Now Zondas are much much better than the Aksiums.
I do agree with the others about losing body weight and fitness being the best bet but at the same time think a modest wheel upgrade is well worth it as well ( I am a sucker for the rotational weight theory of good wheels opposed to carbon bidon cages for instance or a few grams off the weight of a saddle).
- foo on patrol
Re: Bike wheels
Postby foo on patrol » Sun Dec 09, 2018 12:21 pm
Foo
Goal 6000km
- biker jk
Re: Bike wheels
Postby biker jk » Sun Dec 09, 2018 1:03 pm
Your opinion is well and good but here's what Campagnolo states:rodneycc wrote:Zondas are great. I hover between 100kg and 105kg and I've had Zondas for years (the 2013 old 15mm wide so even narrower than the current ones). 109kg weight limit I would say is fairly generous guide with a bit of leadway like most of the Campy/Fulcrum range which are just brilliant (and Ive tried most).biker jk wrote:The op is close to the weight limit for Campagnolo wheels of 109kg so not a great suggestion. 16 spokes on the front and 21 on the rear for a 100kg rider is asking for trouble. Just curious to know what makes those wheels fast?paule11 wrote:Get Campagnolo Zondas stiff strong light and fast
All Campagnolo wheels are constructed to meet the highest standards of resistance and durability. If you weigh over 109 kg/240 lbs we advise you not to use this product. Non compliance with this warning can damage the product irreversibly. If you weigh 82 kg/180 lbs or more, you must be especially vigilant and have your bicycle inspected more frequently (than someone weighing less than 82 kg/180 lbs). Check with your mechanic to discuss whether the wheels you selected are suitable for your use, and to determine the frequency of inspections. Using tires with a larger diameter and a frame that respects the standards will help to increase the lifetime of the wheels.
The suggestion that even riders weighing 82kg or more need to be careful suggestions that there isn't much leeway around 109kg.
- biker jk
Re: Bike wheels
Postby biker jk » Sun Dec 09, 2018 1:09 pm
You can ride them but the facts are that spoke breakages are more likely at that rider weight with low spoke count wheels. I can mention anecdotal experience as well. My wife hit a half brick with a 32 spoke wheel I built. Result was a front and rear pinch flat but the wheel wasn't even out of true. But when she hit a pot hole with a Shimano C24 (16 spokes front, 20 spokes rear) the wheelset was cactus.foo on patrol wrote:I find it strange the comment about 100-110kg riders not being able to ride low spoke count wheels, as I've ridden on them for ages and even on the Track, I race with a 16sp front and I'm 108-110kgs. Perhaps you should say.........cheap low spoke count wheels?
Foo
- foo on patrol
Re: Bike wheels
Postby foo on patrol » Sun Dec 09, 2018 1:16 pm
Strange how the only wheels that I have broken spokes in, are the higher spoke count. I still say it has a lot to do with how you ride. That's my experience with low spoke count.biker jk wrote:You can ride them but the facts are that spoke breakages are more likely at that rider weight with low spoke count wheels. I can mention anecdotal experience as well. My wife hit a half brick with a 32 spoke wheel I built. Result was a front and rear pinch flat but the wheel wasn't even out of true. But when she hit a pot hole with a Shimano C24 (16 spokes front, 20 spokes rear) the wheelset was cactus.foo on patrol wrote:I find it strange the comment about 100-110kg riders not being able to ride low spoke count wheels, as I've ridden on them for ages and even on the Track, I race with a 16sp front and I'm 108-110kgs. Perhaps you should say.........cheap low spoke count wheels?
Foo
Foo
Goal 6000km
- rodneycc
Re: Bike wheels
Postby rodneycc » Sun Dec 09, 2018 10:10 pm
But Foo is right about the way you treat them, at the end of the day don't gutter bash them and treat them with respect. You can be unlucky with any wheel if you hit something out of the ordinary, remember they are road wheels and not mtb wheels!
I can only relate what my experiences have been with a series of wheels. I rate the Zondas more robust than the 9000 series c24 but not as fast and rate Shamals and Racing zeros the best overall wheels for speed and robustness ( at a certain price point).
Seeing that Campy/Fulcrum have that same warning preamble on all their wheels from low budget to high performance tells me its more to satisfy their legal team. Therefore I stand by my experience.
Re: Bike wheels
Postby Neddysmith » Mon Dec 10, 2018 9:11 am
Yep i'd agree with this, i sit between 96-98kg, and have a few different sets of wheels i change between Campy Shamal G3, some GRP carbons and riden on a few others as well, ride both hills and fast flats and have never really had an issue with wheels going out of true or breaking spokes, so i certainly believe it comes down to how you ride, or perhaps ive just been extremely lucky.foo on patrol wrote:Strange how the only wheels that I have broken spokes in, are the higher spoke count. I still say it has a lot to do with how you ride. That's my experience with low spoke count.
Foo
And while yes body weight makes a difference when riding, having nice set of wheels will make a difference.
- foo on patrol
Re: Bike wheels
Postby foo on patrol » Fri Dec 14, 2018 7:54 am
Two of the rear wheels spoke where the spoke popped, was when I was kicking at the start of a sprint, again high spoke count wheels but training wheels, not my good race wheels.
Foo
Goal 6000km
Re: Bike wheels
Postby paule11 » Tue Dec 25, 2018 1:15 pm
They spin well hold speed well very stiff that's what makes them fast I was over 100kg when i got them at 97 kg now still runnning true surprised how much more robust they are compared to Aksiumsbiker jk wrote:The op is close to the weight limit for Campagnolo wheels of 109kg so not a great suggestion. 16 spokes on the front and 21 on the rear for a 100kg rider is asking for trouble. Just curious to know what makes those wheels fast?paule11 wrote:Get Campagnolo Zondas stiff strong light and fast
Re: Bike wheels
Postby KristianJ » Tue Apr 23, 2019 2:28 pm
My recently acquired Pinarello Opera FP has a Shimano RS100 wheelset (20 spoke front, 24 spoke rear, about 1850 grams total) and 25mm Maxxis Refuse rubber. Seller indicated that they had only been bought about 6 month's ago and little more than 1000km ride distance.
I'm 189cm, about 103kg. I have my eye on the MS Gong ride in Nov so will look to trim down for that, but for the time being I'll mainly be riding flattish roads/paths with slight climbs...no longer than 25-30km per outing.
I've ridden the bike around 20km so far on flat paved paths/roads and have had no discernible issues, however after reading some threads here I'm a little concerned that I should find a wheelset with more spokes.
I'm hoping that because of the slightly higher weight I don't have to be quite as worried, and that I can get away with just lowering the PSI a little.
Is there anyone around my weight who has experience with a wheelset of similar weight/number of spokes who would advise a particular path of action?
On the loose stuff: Merida MATTS TFS-300D
Re: Bike wheels
Postby vinski » Tue Apr 23, 2019 2:43 pm
Ive been riding my roadie with shimano RS30 wheels for the past 4-5 years with no issues and im about the 105kg mark...maybe slightly more with my backpack when i commute. My riding is a mix of road and bike paths (probably more bike paths) and the bike paths i use arent the smoothest ones - plenty of bumps etc. So id say you would be ok on what you got as long as you arent bunny hopping kerbs etc.
Thats just my experience.
Vinski
Re: Bike wheels
Postby KristianJ » Sat Apr 27, 2019 5:50 pm
Thanks for the reply...have been to at least 1 of my LBS (albeit not my usual one) and was advised the same re. bunny hopping kerbs and the like.vinski wrote:Hi
Vinski
I'll keep on going with them and if anything does go awry I'll do a bit more investigating.
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
Users browsing this forum: Andy01, recumbenteer
- All times are UTC+11:00
