Postural blood pressure problem
Postby uad782 » Fri Dec 07, 2018 9:59 pm
The other night I sat on the bed and leaned forward to tie shoe laces. I got a loud sound in one ear and felt really dizzy. This probably lasted for about a minute. Raced to local ED who did bloods and diagnosed it as probably postural hypotension. I had had a dizzy spell the week before too just before going to sleep but nothing very serious. They were also concerned as my heart rate was 46. I am around 50 yo.
I have been dieting and cycling around 10 hrs, 2 x 3.5 hours sessions and a 2.5 hour session ,per week of very hilly courses. Lost around 8kg in 2 months. I don’t use any supplements and just drink water for cycling.
Went and saw my GP the next day and he said not to worry about it and see if it happens again.
I have two opinions from two doctors, should I get a third?
Re: Postural blood pressure problem
Postby Baalzamon » Fri Dec 07, 2018 11:27 pm
Postby Baalzamon » Fri Dec 07, 2018 11:28 pm
- cyclotaur
Postby cyclotaur » Fri Dec 07, 2018 11:46 pm
If you’ve lost 8 kgs you have less on-board reserves, and are probably riding better (read harder) than before as well. You need to keep your energy and fluid levels up though.
**This is just my experience under similar scenario.
My old blog - A bit of fun
Postby RhapsodyX » Sat Dec 08, 2018 9:14 am
... taken from...Hypotension or orthostatic hypotension.
Bradycardia or tachycardia.
Wikpedia - anorexia nervosa
Not saying you have anorexia. But you might want to eat more given your body is (to a degree) shutting down. Been there, done that...
Postby Baalzamon » Sat Dec 08, 2018 11:49 am
Next time you see you doc, ask them to check your blood electrolytes.
Postby RhapsodyX » Sat Dec 08, 2018 12:03 pm
Except, as per first post, they did that at ED - they would have picked up any gross electrolyte issues. Not saying that some salts in the drinks isn't a bad idea, depending on input/output... but it's fairly hard to cause issues *unless* you are drinking stupid amounts of fluid - and that would have shown up in the blood tests (I hope!).Baalzamon wrote:Because you only are drinking water, you are flushing out electrolytes. ie potassium, magnesium and sodium.
At a rough guess... to lose 8Kg in two months means a calorie deficit of around 900kCal a day. Of course, a stack of that could be glycogen & associated water, heck I've had at least two periods where I've dropped 6 - 8Kg in a month! But given the OP is doing 3.5h rides on hilly terrain... sounds "trained", and probably just losing weight too quickly and the body is retaliating.
Postby uad782 » Sat Dec 08, 2018 12:06 pm
Postby RhapsodyX » Sat Dec 08, 2018 12:18 pm
BTW - over the years, I've had EXACTLY the same symptoms (tinnitus, postural), usually when losing weight and it goes away when I'm putting weight back on (damn it!). Discussed with doctors... no real outcomes.uad782 wrote:Thanks everyone. I will let you know the results
You know you are over-doing it (calorie deficit) when you start nodding off when sitting down because the HR drops off. I have a sit-stand desk at work - hard to fall asleep standing, and the standing brings the HR up by around 10 BPM. But meetings are a real struggle.
- nickobec
Postby nickobec » Sat Dec 08, 2018 4:51 pm
That was over 30 years ago, naturally low blood pressure and being sick at the time.
Since then, learnt the signs and move more slowly when I am sick or the body is recovering (from sickness or riding).
Never had the ear thing.
- nickobec
Postby nickobec » Sat Dec 08, 2018 11:01 pm
Postby Ivanerrol » Sat Dec 08, 2018 11:37 pm
Postby JPB » Sun Dec 09, 2018 12:03 am
Yes. Plus dizzy sometimes when crouched down with my neck forward like when looking at something on a bottom shelf and then standing up.Ivanerrol wrote:Do you get night cramps?
But i have moderate high blood pressure.
Postby uad782 » Sat Dec 15, 2018 8:26 pm
- find_bruce
- Moderator
Postby find_bruce » Sat Dec 15, 2018 8:44 pm
Vaso-> relates to veinsuad782 wrote:The third doctor called it Vasovagal syncope. Thanks for everyone's replies.
Vagal-> system of nerves that regulate breathing, heart rate etc
syncope-> fainting
Ie it describes your symptoms rather than necessarily identifying an underlying cause
- ValleyForge
Postby ValleyForge » Sun Dec 16, 2018 10:41 pm
Not quite. It refers to an episode where enhanced vagal effects on the heart (negative chronotropic - slowing) causes a transient drop in cardiac output and thus a drop in blood pressure. The classic situations are soldiers on parade, standing up suddenly and also as a result of some drugs/medications.find_bruce wrote:Vaso-> relates to veinsuad782 wrote:The third doctor called it Vasovagal syncope. Thanks for everyone's replies.
syncope-> fainting
Postby Mr Purple » Wed May 31, 2023 9:46 am
Offhand I'd agree with your GP in that you likely have nothing to worry about, provided you're not on any medication that will lower your blood pressure.
The most likely cause is a combination of things - increased vagal tone (hence the low HR), decreased peripheral resistance (more arteries and veins optimised for the cycling) and potentially a little bit of dehydration on that day. The more serious would include an underlying heart rhythm issue (I'm pretty sure an ECG would have been done in ED, though they only catch it if it's happening) or the rarer endocrine causes. So vasovagal syncope is a reasonable explanation
Personally I went through a stage where I experienced mild presyncopal symptoms quite regularly. I'm 41 and 61kg with a BMI of 21 and resting heart rate somewhere around 40 so I figured it was the case as above. I just thought my system was best optimised to hammering up a hill at 200bpm and couldn't cope with a little bit of dehydration and wandering around the house at 40bpm.
This is just general advice, I don't know anything about your medical history or actual weight, but it does sound like you've consulted the appropriate people who have done appropriate things. I say these things in my experience as a 250km a week cyclist rather than anything related to my qualifications.
Users browsing this forum: warthog1
