8 Speed for Touring
troppo
8 Speed for Touring
Postby troppo » Sat Nov 21, 2020 3:13 pm
Hi All, first post from a longtime lurker.
I’m convinced 8 speed is perfect for touring, anybody got any recommendations for a suitable rear mech?
So far I’ve come across t8000 rd which I think is compatible.
rifraf
Re: 8 Speed for Touring
Postby rifraf » Sun Nov 22, 2020 12:41 am
Welcome to the forum Troppo :)
Surly Ogre, Extrawheel trailer.
LG
Postby LG » Sun Nov 22, 2020 8:44 am
Road or mtb shifters, or do you have a planned model shifters? The shifter will need to be compatible with the cable pull of the RD.
I like using 9 speed shimano RDs (xt if I can), compatible with road shifters up to 10 speed (with a couple exceptions), including 8 speed.
LG = Low Gear
Thoglette
Postby Thoglette » Sun Nov 22, 2020 4:40 pm
Doesn’t matter for Shimano 8 speed.
Shimano 8, 9 and 10sp road all have the same pull.
The Deore T8000 is offroad 10sp and won’t work. The 9sp Deore will, if you want the modern transformer-movie look.
Personally, I want to try the SunXCD SXRD34M as most of my gear has that chrome aesthetic.
Grant Peterson has had a fair bit to say over at rivbike about the direction and type of derailleurs
LG
Postby LG » Sun Nov 22, 2020 9:58 pm
My understanding is that Tiagra 4700 10 speed uses the same cable pull as the other shimano 11 speed groupsets, and thus is the exception to the 8, 9, 10 speed compatability rule (worth mentioning just in case). Then of course the 10 speed mtb change of cable pull stuffed up the backward compatibility options. I've settled on 9 speed for our touring bikes, with mtb RDs working with mtb, road integrated and bar end shifters on different bikes.
LG = Low Gear
Thoglette
Postby Thoglette » Mon Nov 23, 2020 12:17 am
:shock: Thanks!
WheelsOfChance
Postby WheelsOfChance » Fri Apr 16, 2021 5:47 pm
I'm jumping into this thread a little late but I have set one of my bicycles up as a wide range 8 speed which I have taken on tours with a light load i.e. rear panniers only.
* 33t chainwheel on the front.
* Sunrace M680 8 Speed Bicycle Cassette 11-40T at the back.
* Shimano Altus Rd-M310 7/8-Speed Rear Derailleur. Great RD!
Grant Peterson likes it too https://www.rivbike.com/collections/der ... m310-17167).
* Rear derailleur hanger extender to get the RD to work with the 40T. Wolf Tooth Goatlink is the brand name but I bought a noname $10 one on ebay.
This gives me on my bike a gearing range of 22.5 to 82 inches. I don't mind not having a higher gear when touring.
I use friction shifting but see no reason why this wouldn't work indexed.
Tony
zebee
Postby zebee » Fri Apr 16, 2021 8:11 pm
Alfine Nexus 8 speed in hub gear? Can't tweak the ranges but with a triple on the front you are covered for just about everything.
australiantourer
Postby australiantourer » Fri Apr 16, 2021 10:45 pm
Why limit yourself to a single chain wheel? My benchmark for touring is 20-110 gear inches, easily achieved with a double or triple chainwheel set. No need then for very large rear sprockets or for hanger extenders — 32 t or maybe less will suffice at the back. You will have better chain lines too with multiple chain wheels, with an easier life for your chain. The cassettes will be cheaper and more easily found.
