Bag for cycling to work
- Tgitarri
Postby Tgitarri » Wed Oct 07, 2020 12:47 am
I live around 25 miles away, so I will be going full kit and can shower when I’m at work. Obviously the less bulky the better, because of the 50 miles. Thanks for your help.
- AUbicycles
- Site Admin
Re: Bag for cycling to work
Postby AUbicycles » Wed Oct 07, 2020 1:00 am
Best commuting backpacks - specifically designed for cycling and genuinely waterproof, comfortable and useful are from Ortlieb and Vaude. The problem is, for a good quality bag that will be comfortable and last, they cost money.
Cheap bags will have problems with comfort (e.g sweaty back and straps that degrade), failing zips, failing waterproof capability and even have the manufacturing issues such as cheap labour and non-sustainable manufacturing and materials.
So if you go for something cheap, the chances are you will have a short lifespan and then end up having to replace the bag regularly and be frustrated. A quality bag should be a considered purchase so make sure the details (size / features) match and at the end it generally pays off.
If you are overseas, the chances are that you will get Ortlieb bags for a more reasonable price (they are pretty expensive in Australia).
Postby piledhigher » Wed Oct 07, 2020 1:03 am
Can narrow that further to Libya, Myanmar or America...AUbicycles wrote: ↑Wed Oct 07, 2020 1:00 amIn Australia we typically use kilometers so I assume you are overseas.
- 10speedsemiracer
Postby 10speedsemiracer » Wed Oct 07, 2020 1:09 am
piledhigher wrote: ↑Wed Oct 07, 2020 1:03 amCan narrow that further to Libya, Myanmar or America...AUbicycles wrote: ↑Wed Oct 07, 2020 1:00 amIn Australia we typically use kilometers so I assume you are overseas.
Libya or Liberia ?
Although the Brexits still use MPH on roads I think as well..
edit:spelling
Postby piledhigher » Wed Oct 07, 2020 1:11 am
Yes, Liberia..10speedsemiracer wrote: ↑Wed Oct 07, 2020 1:09 ampiledhigher wrote: ↑Wed Oct 07, 2020 1:03 amCan narrow that further to Libya, Myanmar or America...AUbicycles wrote: ↑Wed Oct 07, 2020 1:00 amIn Australia we typically use kilometers so I assume you are overseas.
Libya or Liberia ?
Also you should see the conniptions in an American forum when someone mentions weight in Stones!
Postby RobertL » Wed Oct 07, 2020 1:34 pm
My general rule for smaller backpacks - the size that you are after, about 20-30 litres - is to buy something relatively cheap. Not complete "dollar shop" bottom of the range stuff, but something pretty basic. I make sure that it is comfortable, but that's not too hard when you're only carrying a few kilos.
It will last a surprisingly long time.
Also, every backpack is waterproof if you use a rain cover. They are pretty basic - like a shower cap that stretches over your pack - but are very useful.
- Mububban
Postby Mububban » Wed Oct 07, 2020 2:22 pm
I bought a High Sierra backpack with a laptop slot and heaps of space for everything I need to carry. Well under $100, came with a waterproof hi-viz cover and wide comfy straps.
Something like this as a rough guide:
https://www.bagworld.com.au/shop/detail ... laptop-tn/
- Thoglette
Postby Thoglette » Wed Oct 07, 2020 3:24 pm
But as others have said, for 25 miles on road I’ll go for racks (with crap centrally & behind me on top the rack) over any other method. Excess/wet weather gear goes in the handle bar bag
Postby Prydey » Wed Oct 07, 2020 7:09 pm
They have an air back system so the bag doesn't actually rest on your back. Straps are very comfy with chest and waist straps and zipped compartments in the waist straps.
Built in rain cover zips in to a pocket in the base however it doesn't work great in heavy rain but the bag material is also water resistant so the insides still stay dry.
My commute is 27km each way and the bag is fine.
Postby Warnesy » Wed Oct 07, 2020 7:16 pm
https://www.macpac.com.au/clearance/equ ... RANCE.html
I find it light and comfortable.
- BillParkinson
Postby BillParkinson » Wed Oct 21, 2020 12:34 am
Postby AndrewCowley » Fri Oct 23, 2020 2:12 pm
Postby Prydey » Fri Oct 23, 2020 7:01 pm
https://images.snowys.com.au/content/im ... kpack.jpeg
As mentioned a couple of posts up, I use this bag and the bag stays dry regardless of body sweat. My commute is an hour each way.
- nickobec
Postby nickobec » Sat Oct 24, 2020 12:25 am
The less weight you need to carry on you or the bike each ride the better.
Can you leave your trainers at work? (I used to leave a couple of pairs)
What about your jeans? (again a couple of pairs)? (can always take a fresh pair in with your shirts see below)
T shirts any reason you need to take a fresh one every day (I would take 5 business shirts, 5 socks and jocks) once a week in a Henty Wingman and take the dirty stuff home that day.
In these days of cloud computing do you really need to take a laptop to and from work every day? If you do really need it, I would suggest the laptop carrier by Lawrence Carpenter at 2 minutes 40 seconds
Even a handlebar bar costs you an extra 5% of energy to push you bike through the wind. So instead of a 90 minute it is 96 minute commute. So you lose an hour a week, to carry stuff you don't really need to.
- cancan64
Postby cancan64 » Tue Oct 27, 2020 12:21 pm
https://www.amazon.com.au/OverBoard-Cla ... 5602&psc=1
Postby Mofra » Tue Dec 01, 2020 9:06 am
Has been comfortable to ride in plus with just magnets on the main flap it's easy to open and close mid-commute (to grab or put away a jacket).
I did get a rack and panniers when I recently upgraded my bike though, it is more comfortable.
Postby Zippy7 » Thu Feb 25, 2021 10:34 pm
Anyway, just get a comfy backpack to carry your gear in - a sternum (chest) strap and waist strap would help with stability. Otherwise, get a pannier rack and an appropriate bag(s). Ride on...
Postby Mofra » Tue Mar 02, 2021 9:52 am
I used a Hershel that was gifted to me, was waterproof even though it didn't look it.
Now on the Ortlieb pannier bandwagon - some surprisingly good deals on ebay for the old-school backrollers
Postby henno » Tue Mar 02, 2021 2:19 pm
https://www.bikebug.com/ortlieb-front-r ... 49881.html
I'll not go back to my backpack.
Postby Stepr » Fri Jun 11, 2021 7:50 pm
seriously consider what configuration of pockets you may need - I like a few external pockets and one with an organiser. I find those bags with a pocket on the hip belt great for the security pass.
None or limited external pockets is just plain anoying if you need quick access to keys or bike locks and security passes without having to open the single opening in your bag like in those ortlieb ones ( that I will never be buying).
- BritniPepper
Postby BritniPepper » Sat Jun 12, 2021 9:28 am
I have a couple of backpacks. If I were using one for cycling it would be my Osprey Talon 11. I had a bit of fun writing up a review here and for cycling purposes the fact that it has a mesh to keep an air pocket between sweaty back and backpack, the several carefully-designed pockets and storage compartments, the low profile, and the hydration bladder all make for a good choice.
I can have a couple of little things within easy reach as well as the mouthpiece for the water bladder. Even a built-in whistle that might help when sneaking up on some unwary pedestrian.
Britni
Postby wongaga » Sun Jun 13, 2021 8:14 pm
Cheers, Graeme
- DavidS
Postby DavidS » Tue Jun 15, 2021 12:57 am
As for spare tube, mini tool etc they go in the saddle bag, a Brooks on one bike and an Ortlieb on the other.
I commute and carry clothes in on the bike and have shoes at work.
If I had a laptop I would probably want to put that in some sort of cover in the pannier as it will get shaken up a bit on a bike. But laptops just need to be able to handle this presumably.
For me a pannier is the way to go, let the bike carry the weight, I don't want to.
DS
Postby Damo380 » Wed Dec 08, 2021 9:29 pm
N+1 is a 2019 Defy which I hope to do a few overnights on, and once again it fits well and has more than enough carrying capacity.
Return to “Bike & Gear Reviews”
Users browsing this forum: blizzard
