I just received some valve cores as suggested in this thread, but it seems my front tyre has finally got the message and is holding 80psi. I have only had one ride all year though due to some sutures in my quad. Hoping to get out tomorrow and see how the tubeless tyres hold up.warthog1 wrote: ↑Mon Jan 15, 2024 2:30 pmI have some of that tape.
Seems to be largely advocated by "tobinhatesyou".
Pretty thin and not as stiff as tape that is designed for the purpose it seemed to me.
Not impressed on my wheels and ordered some from the wheel manufacturer.
Possibly my fumble fingered application had something to do with it, but the purpose designed stuff went on ok.
These are handy for tubeless tyre use. Inevitably the valve core seems to clog over time.
Whip it out and replace it solves that.
https://www.ebay.com.au/itm/12625576976 ... media=COPY
Tubeless roadbike tyres
Re: Tubeless roadbike tyres
Postby kilroy » Tue Jan 16, 2024 6:18 pm
Postby Mr Purple » Sat Feb 24, 2024 12:00 pm
Given I've been getting 800km or so out of my Vittoria Corsa NEXT TLR ($75) it's time to do the sums and consider whether it's worth spending the extra on the $109 GP5000TRs. And it probably is - that would have been at 960km or so.
It'll be interesting to see how much longer this one lasts. And I've been even more particularly brutal on it than normal - it's seen a fair few 700W+ vertical KOMs.
Postby Mr Purple » Wed Feb 28, 2024 2:00 pm
I've literally never seen them last more than a few hundred kilometres. Definitely seems worth the extra investment no matter how much it hurts paying $109 for tyres!
Postby blizzard » Wed Feb 28, 2024 2:06 pm
I have over 9000km on my GP5000TL, rear tyre is squared off but the wear markers are intact. I don't put out anywhere the watts you do, and do a lot of flat bike path KMs.
Postby Mr Purple » Wed Feb 28, 2024 2:25 pm
It'll be interesting to see how long they last. Given I've never tried anything other than the Vittoria NEXT TLR tubeless on the road I suspect they weren't the right choice for longevity. Running 60PSI I'm not getting anything like the 'skipping' sensation I'd get on tubed at 80PSI which should be a lot better for the tyres.
Postby Arbuckle23 » Wed Feb 28, 2024 2:57 pm
The Vittoria NEXT TLR rode very comfy in 28 mm. The payback for that was the very soft sidewalls attracted a few punctures.
Each did seal up though so no problem there.
But the tread material started to breakup around 4000 km, causing me to change out.
Running some 28 mm Pirelli Cinturato Velo's now, will see how they go.
They do blow up to a big diameter on the Giant SLR wheels though. Not much seat tube clearance on my TCR!
Ride is firmer as well.
Postby Mr Purple » Thu Feb 29, 2024 12:15 pm
I have very tight clearances on an older disc frame but can allegedly run 28mm. I tried in once with a NEXT TLR and made it all of 20km before blowing out a sidewall - I suspect a rock was caught between the frame and tyre. Annoyingly the only puncture I've had in 4000km on NEXT TLR was in the same spot the day before on a 25mm tyre so no idea what happened there.Arbuckle23 wrote: ↑Wed Feb 28, 2024 2:57 pmI am not a heavy tyre consumer, normally get around up to 6000 km out of my tyres.
The Vittoria NEXT TLR rode very comfy in 28 mm. The payback for that was the very soft sidewalls attracted a few punctures. Ride is firmer as well.
That's the problem with tyres. They may be excellent but if you hit the wrong rock too early in their lifespan you'll never buy them again.
Postby Mr Purple » Sun Mar 17, 2024 2:13 pm
It didn't particularly need it, either. What I thought was a patch of tread missing was just a stone mark. Wear markers were completely gone though, and the sealant on the front needed to be changed anyway so I thought I'd put a new pair with the Tour de Brisbane in a few weeks.
Put new 5000TRs on there - $109 each. They were so much easier to fit than the Vittoria Corsa TLR NEXT as well, instantly on and instantly beaded. Given I got an extra 600km compared to the Vittoria it's pretty much a no brainer. So Continental are expensive but you seem to get what you pay for.
- twizzle
Postby twizzle » Mon Mar 18, 2024 10:30 am
I ended up putting a latex tube in on the side of the road and have set the front up tubed for now, until I have a better idea of how to make it last. This might end up being just for long events. Then again, a mate somewhat binned his time trial bike on the weekend when the front butyl punctured and deflated during a corner. And I've had a similar incident but kept the bike upright. Sealant is nice... when it works.
Postby kilroy » Mon Mar 18, 2024 7:02 pm
I’m officially a convert. I’m almost at the 3 month mark and need to top up the sealant soon. I’ve done around 1k km on some 32mm Gravelkings and despite some people saying they are puncture magnets, I haven’t had one yet touch wood.
- foo on patrol
Postby foo on patrol » Sat Apr 06, 2024 12:31 am
Goal 6000km
Postby warthog1 » Sat Apr 06, 2024 9:11 am
Give us a precis? Not signed up for instagram so see nothing.foo on patrol wrote: ↑Sat Apr 06, 2024 12:31 amHow the Pro mechanics do it.
https://www.instagram.com/reel/C5S4KnDN ... _copy_link
Foo
- foo on patrol
Postby foo on patrol » Sat Apr 06, 2024 12:53 pm
warthog1 wrote: ↑Sat Apr 06, 2024 9:11 amGive us a precis? Not signed up for instagram so see nothing.foo on patrol wrote: ↑Sat Apr 06, 2024 12:31 amHow the Pro mechanics do it.
Foo
I could see posts from Insta when I wasn't on it, just the same as that other platform that muskstick owns and I'm not singed up to it.
Foo
Goal 6000km
Postby warthog1 » Sat Apr 06, 2024 2:45 pm
I get some text about "our team mechanic preparing 32mm gp5k" but that's it.foo on patrol wrote: ↑Sat Apr 06, 2024 12:53 pmI could see posts from Insta when I wasn't on it, just the same as that other platform that muskstick owns and I'm not singed up to it.warthog1 wrote: ↑Sat Apr 06, 2024 9:11 amGive us a precis? Not signed up for instagram so see nothing.foo on patrol wrote: ↑Sat Apr 06, 2024 12:31 amHow the Pro mechanics do it.
Foo
Foo
- foo on patrol
Postby foo on patrol » Sat Apr 06, 2024 5:09 pm
warthog1 wrote: ↑Sat Apr 06, 2024 2:45 pmI get some text about "our team mechanic preparing 32mm gp5k" but that's it.foo on patrol wrote: ↑Sat Apr 06, 2024 12:53 pmI could see posts from Insta when I wasn't on it, just the same as that other platform that muskstick owns and I'm not singed up to it.
Foo
There's a vid that follows, maybe someone smarter than me can solve the problem?
Foo
Goal 6000km
- foo on patrol
Postby foo on patrol » Sun Apr 21, 2024 9:07 am
I did know the family really well in my younger years and Marks father started the business over 40yrs ago.
https://www.ebay.com.au/str/redcliffecycles
Foo
Goal 6000km
Postby warthog1 » Sun Apr 21, 2024 10:34 am
Have a 30mm Schwalbe pro one addix on my rear WR50 hookless at the moment.
Going well.
A bit stupid but w t h, on seating on the hookless rim, I pumped it to 120psi and let it sit for a while. No probs
Should be fine at the 60psi I run it at.
Measured up well. 32 mm wide on the 32 mm ext width rim (25 int)
- foo on patrol
Postby foo on patrol » Sun Apr 21, 2024 4:52 pm
warthog1 wrote: ↑Sun Apr 21, 2024 10:34 amNo Dunlop tyres at all on here; https://www.bicyclerollingresistance.co ... ke-reviews
Going well.
Oops, Goodyear.
Foo
Goal 6000km
Postby kilroy » Mon Apr 22, 2024 9:15 am
I’d be pretty disappointed if I only got 1500km out of a set of tyres. I haven’t tried the tubeless version of the 5000’s but I’ve generally get at least 2500-5000km out of my tyres. I run on sealed roads with maybe a little bit of dirt here and there. I’m guessing my training is a little lighter than yours lol. I have 1800km on a set of 32mm Panaracer Gravelkings and they look barely worn.
Postby Mr Purple » Mon Apr 22, 2024 10:11 am
Just lots of climbing and what we'll euphemistically call 'intervals' which really is taking sub 60 seconds climbing KOMs.
Doesn't apply to my gravel tyres at all - I have 3000km+ on my current set with no major wear. I assume because traction is the limiting factor when climbing on gravel.
Postby warthog1 » Mon Apr 22, 2024 10:15 am
Postby Mr Purple » Mon Apr 22, 2024 10:49 am
100%. I've run out of climbs nearby within my range which may also explain why they're now lasting longer.
- foo on patrol
Postby foo on patrol » Mon Apr 22, 2024 11:20 am
I still think it's weight distribution.
Foo
Goal 6000km
- twizzle
Postby twizzle » Wed May 08, 2024 8:38 pm
