Shimano Alfine-11... Huh?
- hartleymartin
Postby hartleymartin » Tue Jun 22, 2010 1:30 am
$552 for the hub, $81 for the shifter... I can't see the sprocket on there anywhere yet, but that sort of pricing is in line with the projected prices from a few months back. Wiggle are selling the 8-speed hub for $265 and $46 for the shifter.
With this sort of pricing, it really does look like a viable alternative to the Rohloff for touring, although selection of gears might need some thought into chain-wheel/sprocket ratios to give a useful range of gears.
- Nate
Re: Shimano Alfine-11... Huh?
Postby Nate » Tue Jun 22, 2010 7:33 am
I've gotta swap the cranks out (170-39t - 175-49t) as the first few gears are next to useless, but no real need for more gears
Postby zero » Tue Jun 22, 2010 6:59 pm
Postby Nobody » Tue Jun 22, 2010 8:49 pm
- hartleymartin
Postby hartleymartin » Tue Jun 22, 2010 10:54 pm
Well, it seems that the Alfine range is targeted at the MTB market. And 5mm isn't much when it comes to steel frames. Just spring it apart. Carbon Fibre and aluminium on the other hand...Nobody wrote:135mm OLD spacing only. Obviously they don't think a 130mm road spacing is worth doing for this market.
Steel is real.
- trailgumby
Postby trailgumby » Tue Jun 22, 2010 11:15 pm
Fixedhartleymartin wrote:Steel is real heavy.
Postby Nobody » Tue Jun 22, 2010 11:18 pm
Fixed again.hartleymartin wrote:Steel is really durable.
Just ask all those people using them for rain bikes.
- hartleymartin
Postby hartleymartin » Tue Jun 22, 2010 11:30 pm
Postby Nobody » Tue Jun 22, 2010 11:31 pm
If you're worried about ~1.7% total weight difference (frame and fork).trailgumby wrote:Fixedhartleymartin wrote:Steel is real heavy.
Maybe have another look at Busted Carbon if you think steel is real heavy. It's updated regularly. No shortage of new material.
- Abacus
Postby Abacus » Wed Jun 23, 2010 12:55 am
The 11 Speed hub on Wiggle is a disc brake version.
IIRC there are going to be a number of different variants of this hub, disc/no disc/chain drive/belt drive. Perhaps the OLD will change between different variants of the hub.
I had an Avanti Blade 8 with the 8 speed hub. The OLD on that bike was only 126mm. Other variants were 135mm.
This is the first sighting of this hub in the wild. Perhaps there is more to come....
...at least, I hope so.
- hartleymartin
Postby hartleymartin » Mon Jun 28, 2010 6:41 pm
Gears 10 and 11 are rather high at 189% and 215% of direct drive. This would necessitate a rather small chainring on your MTB and a rather large sprocket in order to get useful gears for MTB riding, something in the order of 40/23 or 40/24. A combination of 46/20 or 44/20 would be useful on 20"-wheeled bicycles (good hub for a Raleigh Twenty tourer?) or 48/18 for a 16"-wheeled bicycle.According to this post at Vélotaf (a French site), the gear range is 409% (more precisely, 408.54%), but the gear steps aren’t eight of 13% and two of 17%. The reported gear ratios at Vélotaf are
1st 0.527
2nd 0.681
3rd 0.770
4th 0.878
5th 0.995
6th 1.134
7th 1.292
8th 1.462
9th 1.667
10th 1.888
11th 2.153
which would make one step of 29.22% (1st to 2nd) and nine near-even steps varying between 13.07% (2nd to 3rd) and 14.04% (10th to 11th). Karl’s guess was correct — 5th gear would act as direct drive.
Among the other details in the article there are that the hub has an OLD of 135 mm, and that the oil in the hub should be changed every 3000 km (1860 mi) or two years, whichever comes first.
Postby Mobe1969 » Sun Aug 01, 2010 8:27 am
Postby triode » Sun Aug 01, 2010 8:42 am
Is it hard to fix puncture with Nexus/Alfine hub? (I would imagine it's harder than quick release wheel)
Can anybody share their experience in fixing puncture on internal hub? Nate maybe?
TIA
- Biffidus
Postby Biffidus » Sun Aug 01, 2010 9:53 am
There are a few, such as the Merida S-Presso i8-D, but they aren't common. RRP from around $1,800.Mobe1969 wrote:What's the chance we'll be seeing bikes with these over here? I mean the Alfines aren't generally available in the models (eg, Giant still use Nexus, Appollo still use Nexus). I can't see any main manufacturers here that supply a model with the Alfine.
You need to unhook the gear selector, which is a little fiddly, and a spanner. I've done it on a Nexus and getting the gear cable back on was annoying (but I imagine that would get easier with practice).triode wrote:My only concern with internal hub is when we get puncture.
- philip
Postby philip » Sun Aug 01, 2010 11:13 am
My commuter has a Nexus hub and it's not that hard, you just need to remember to carry a spanner with you. You can do it without undoing the cable, all you need to do is loosen the nuts so you can slide the wheel out of the dropouts just enough to get the tube through, which isn't much. You can easily do that without mucking around with the cable, which can be quite a hassle.Biffidus wrote:You need to unhook the gear selector, which is a little fiddly, and a spanner. I've done it on a Nexus and getting the gear cable back on was annoying (but I imagine that would get easier with practice).triode wrote:My only concern with internal hub is when we get puncture.
Postby fhbh » Sat Apr 23, 2011 8:11 pm
Got my commuter set up and going now
Pretty happy though still getting some slipping in the hub on changes as I'm still getting the shifter working smoothly
The versa shifters rely in hub for tension so cable routing must be very smooth. I'm have to reroute over the bottom bracket at the moment to get a more direct feed to the alfine hub which takes the cable above the chain stays
Grant
Postby gannet » Mon Apr 25, 2011 10:41 am
Nice!! Keen to hear how you go with the slipping and carbon belt.fhbh wrote:http://www.gelliecustombikeframes.com.a ... -Frame.htm
Got my commuter set up and going now ....
Grant
BTW, changing gears, do you back pedal like on the old SA 3 speeds, no pedalling, or pedal with reduced / no load?
Postby fhbh » Mon Apr 25, 2011 1:56 pm
Belt is fine
Just need to reduce load a little to get it to change and sometimes that is not necessary either, will have a better appreciation once I get the shifters working better.
I've got abbotsford cycles rerouting the cable at the moment will let you know how it goes
Grant
- landscapecadmonkey
Postby landscapecadmonkey » Mon Apr 25, 2011 2:16 pm
That is just a great bike Grant. I was all set to order an alfine 11 for a roadbike build, but after seeing your setup , im rethinking a road/29er cross breedfhbh wrote:Slipping is only the hub not th belt
Belt is fine
Grant
Just had a question though; do you swap between the flat and drop bar set up regularly, and is that fairly pain free.
again - just a beautiful build. will be interested to hear an update on how the cable adjustments go.
andrew
Postby fhbh » Mon Apr 25, 2011 9:17 pm
Having said that I haven't bothered since I put the drop bars on
Grant
- trailgumby
Postby trailgumby » Mon Apr 25, 2011 10:30 pm
Postby Baalzamon » Tue Apr 26, 2011 12:07 am
+1trailgumby wrote:I'd be changing cable brands if they break that often
Postby fhbh » Tue Apr 26, 2011 1:30 pm
http://t3.gstatic.com/images?q=tbn:ANd9 ... bcZ8in5-Fw
Postby fhbh » Sun May 01, 2011 12:33 pm
Grant
Postby Mobe1969 » Fri May 27, 2011 7:36 am
The cube hooper pro should also be available, but that idiot distributors here for cube are new and have no idea what they are doing.
On_One in the uk also have some that are pretty customisable. Their frames however are steel. Which is so... 80's...
And regarding the above posted Merida S-Presso i8-D - that is an alfine 8. They don't seem to have an 11
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
Users browsing this forum: Amazon [Bot], Mr Purple
- All times are UTC+11:00
