DIY paintjob Kenevans
Postby thomas_cho » Sun Feb 10, 2008 6:16 pm
I rattle can sprayed my Kenevans frame, and will very likely go for a professional job some time later. Total cost probably abt $60, and using sanding stuff I already have, done over a period of 3 mths(?), that included 1 mth of dispair where I did nothing.
I purchased the decals on Ebay, and color copied them onto a water decal transfer sheet. So I am reserving the good stuff for the final professional job.
Going to leave the frame for a couple of days before putting the parts back on.
I would not recommend a DIY paint job, unless you have a lot of patience, a dust free place to spray, and to allow the paint to dry.
- toolonglegs
Postby toolonglegs » Sun Feb 10, 2008 6:27 pm
Postby Hawkeye » Sun Feb 10, 2008 9:47 pm
I used to paint model car bodies when I was racing with a combo of airbrush for the fiddly detail bits when I didn't want to blast paint everywhere, and aerosols when I wanted wide area coverage. I won a couple of concourse trophies, and my shells were always light and long-lasting thanks to using a minimum of paint.
However, my very first one was a complete disaster. You by comparison have done an excellent job. Really well done, Thomas.
The following are general tips you might find helpful for next time you try this on another frame.
To get a good clean coverage without the paint spattering or going on three coats at a time you want the paint reasonably thin.
Warming the can in really hot water always worked brilliantly for me with the aerosols. You may need to use oven mits to hold the can. If so, you've got thje temperature about right.
Tips:
* Do the light colours first.
* Use the best quality masking tape you can afford, and press down all the edges with your thumbnail immediately prior to spraying.
* Avoid tight compound curves with the tape
* On the front where you've got the white on the headtube, it would have been OK to cut thru the tape to get the shape with a semi-sharp hobby knife while on the frame so long as you don't press too hard. The paint would fill any cuts through the primer.
* I would not do this under any curcumstances on an alloy or CF frame, or elsewhere on the bike. In these cases, run a biro over the tape around the lug line, pull it off gently and put on an artists cutting board, cut it and reapply to the frame.
* Remove masking tape by peeling back on itself 180 degrees. Lifting at 90 degrees will usually take paint off with it.
* Minor oversprays can be rubbed away with a typewriter eraser pencil or gently scraped with the edge of a sharp curve-blade hobby knife held at 90deg to the paint.
* Multiple light coats allwoed to dry in between gives a much better result than a few heavy coats.
* Finish off with clear.
Hope this is useful!
- sogood
Postby thomas_cho » Sun Feb 10, 2008 10:25 pm
Too much effort, too much time, too messy, too little patience.
Like I said .. next paint job will probably be professionally done, and would most likely be a single color, as I probably would not be willing to shell out the cost for a masking job and two color job.
BTW ... I sold the cervelo because the position was too agressive for my crooked back. Also with the acquisition of my MTB, I had to move 2 bikes into the house ... so something had to give.
... now to just allow the paint to harden and complete the build.
Will post more pictures then, probably next weekend.
- Mulger bill
Postby Mulger bill » Sun Feb 10, 2008 11:58 pm
Nice job with the decals too *jealous*
Shaun
Oh yeah, might be an idea to chase the BB threads before you instal.
Postby stevendavid75 » Mon Feb 11, 2008 11:27 am
I am the bloke who sold you that frame last year or whenever it was,
That is a brilliant job you have done, you have certainly inspired me to have a crack at mine which is pretty rough in spots.
Well Done again.
Steve
Postby thomas_cho » Mon Feb 11, 2008 12:18 pm
Thanks for the compliment, but I do not think that compliments are justifiable when you do a close up inspection.
Anyways ... I am still happy that I did buy the frame off you, and thanks for selling it!!
FWIW, when I stripped off all the paint, there was hardly any rust damage to the frame. What rust there were, was just surface rust which sanded off pretty easily.
I would encourage you to consider going to a professional to get the frame sandblasted and re-sprayed. You would probably have a better and more durable finish then rattle can spray.
Postby Hawkeye » Mon Feb 11, 2008 10:26 pm
The only thing I'd have perhaps done differently was some black "cheat lines" where the red meets the white on the down and seat tubes.
Postby thomas_cho » Mon Feb 11, 2008 10:42 pm
I have carefully put the parts back on the bike, with a honey colored brooks saddle ... however, I have discovered a problem with the wheelset, the hub needs some adjustment.
Will post some pictures once I have installed the tyres (Conti Gatorskins) and adjusted the wheels.
I have to say I am very happy with the color scheme, thanks to those who posted their pictures of the Lemond Tourmalet (?) bike. That was my inspiration.
Postby thomas_cho » Mon Feb 11, 2008 10:44 pm
My thought process with going DIY was that even if I screw it up, I can still take it to the pros to get it sandblasted and done up properly.stevendavid75 wrote:Gday Thomas,
Well Done again.
Steve
Are you going to stay with that French color scheme?
Postby stevendavid75 » Tue Feb 12, 2008 12:07 am
In terms of paint scheme for big ken, I love it as it is, I sort of thought of it as footscray or western bulldogs more than french
but I actually like pretty plain coulurs with block panels like what you have done, either way its currently on the the otherside of the country and is about 2nd or third in line for some attention.
Steve
Postby thomas_cho » Thu Feb 14, 2008 12:21 am
parts list:
Ultegra shifters, Ultegra brakeset, Centaur FD, Ultegra rear derailleur, Tiagra HTII crankset, Shimano R550 wheelset, Nitto stem and Noodle handlebars, brooks Professional saddle, Conti GP4000 tyres.
The stem is raised quite a bit, to allow for my bad back at the moment.
- Blybo
Postby thomas_cho » Wed Feb 20, 2008 1:56 pm
IT WAS the lemond picture that persuaded me to go this paint scheme. Originally I wanted a Rabobank orange, but bunnings didnt have orange. It didnt occur to me to visit Autobarn, they have a huge range.
Users browsing this forum: The Great Boffo
