what degreaser do you use when cleaning your chain and casse
Postby arand18 » Tue Jun 19, 2012 7:32 am
thanks
Re: what degreaser do you use when cleaning your chain and c
Postby Ozkaban » Tue Jun 19, 2012 8:56 am
I only use it when it's really gunky. Normally a wipe and re-lube is enough.
- Ross
Postby Ross » Tue Jun 19, 2012 9:23 am
Postby Abby » Tue Jun 19, 2012 9:49 am
I use a small bucket, take the chain off (I have a Wipperman connex link so its easy) and cassette off, pur a small amount of kero into the bucket, and wash the chain and the cassette (seperately).Ross wrote:Kerosene and rinse off with water
Give them a quick wash in soap & water after (using what I've just washed the rest of the bike with). Rinse them in water, and let them dry...
Takes a couple of minutes...
Abby
- greyhoundtom
Postby greyhoundtom » Tue Jun 19, 2012 9:58 am
Takes about 2 minutes
- gururug
Postby gururug » Tue Jun 19, 2012 10:02 am
Postby Crittski » Tue Jun 19, 2012 10:18 am
Volagi Liscio Ultegra
- il padrone
Postby il padrone » Tue Jun 19, 2012 10:38 am
In the past year I have been running the chain with the original manufacturer's lube then wiping it down and reapplying PE, then wiping off any excess. This seems to have worked very well - the chain has stayed clean and well-lubed. I've been rotating a couple of chains on the drivetrain.
- tallywhacker
Postby tallywhacker » Tue Jun 19, 2012 10:56 am
Postby igstar » Tue Jun 19, 2012 11:22 am
WD-40 is a big no-no for bike chains in my books. It will reduce the ability of the chain lubricant to properly stay on the metal whe it's applied and unless you can control where the WD-40 is sprayed, any inadvertedly affected area will also be impacted.greyhoundtom wrote:A thorough spray with WD40.......a quick hit with the hose.......a wipe with a rag and re-oil the chain.
http://bicycletutor.com/no-wd40-bike-chain/
- gururug
Postby gururug » Tue Jun 19, 2012 11:33 am
In theory that's true. In practice, better to have the gunk out than in, and impact of WD40 is minimal in the larger scheme of things. It is not the best product for the job and i'm glad you reminded us of why it may be a poorer choice for most.igstar wrote:WD-40 is a big no-no for bike chains in my books. It will reduce the ability of the chain lubricant to properly stay on the metal whe it's applied and unless you can control where the WD-40 is sprayed, any inadvertedly affected area will also be impacted.greyhoundtom wrote:A thorough spray with WD40.......a quick hit with the hose.......a wipe with a rag and re-oil the chain.
- missinglink
Postby missinglink » Tue Jun 19, 2012 12:38 pm
I put about a litre in an ice cream container and let the chain soak in it for a while. Then use an old toothbrush to scrub off the chunky bits and allow the chain to hang dry for a couple of hours or wipe down with a clean, lint free cloth to get the bulk of the fluid off.
The dirty kerosene can be poured back into a bottle and allow it to sediment out over a period of time for reuse later. If it gets to dirty for reuse I let it sit in the open container to evaporate off over a couple of weeks leaving just the gunk to scrape out once it’s all gone.
- RonK
Postby RonK » Tue Jun 19, 2012 12:44 pm
Postby so blue » Tue Jun 19, 2012 12:49 pm
- birdbrain
Postby birdbrain » Tue Jun 19, 2012 4:53 pm
Postby logancalder » Tue Jun 19, 2012 4:59 pm
- greyhoundtom
Postby greyhoundtom » Tue Jun 19, 2012 5:48 pm
I did try that stuff and accidentally sprayed a little on the rear alloy rim, and when I wiped it off it left ugly black blotches that were a pain to polish out again.logancalder wrote:Australian Export from Supercheap Auto. $2.20 a can.
- RonK
Postby RonK » Tue Jun 19, 2012 5:51 pm
- Mulger bill
Postby Mulger bill » Tue Jun 19, 2012 6:05 pm
- il padrone
Postby il padrone » Tue Jun 19, 2012 6:18 pm
You use beer ??logancalder wrote:Australian Export from Supercheap Auto. $2.20 a can.
- Aushiker
Postby Aushiker » Tue Jun 19, 2012 11:48 pm
Damn carbon tax Last lot I got was $2.00 a can.logancalder wrote:Australian Export from Supercheap Auto. $2.20 a can.
Aushiker.com
- bychosis
Postby bychosis » Wed Jun 20, 2012 6:36 am
Postby master6 » Wed Jun 20, 2012 7:52 am
GELIGNITE
Postby durilium » Thu Jun 21, 2012 5:58 am
- gorilla monsoon
Postby gorilla monsoon » Thu Jun 21, 2012 12:25 pm
Users browsing this forum: Geemol, Google [Bot]
