It's all your fault (almost)
- Mulger bill
Postby Mulger bill » Sat Feb 10, 2007 6:50 am
I haven't thrown a leg across her yet, I'll do that on my next book off day, we'll see then if it's love or just lust
A bit of a browse gave me a retail of $1395-1430, but Tims having a sale to make room to redo his showroom, and he said he could prolly do it for me for about $800. The GLW also raised no problems
Anyhow, there's a few OCR2 peoples out there, would she make a good reintroduction to the road for a 41yo fart with a slightly dicky back who hasn't held the drops since friction shifting?
One last thing, carbon fibre, the idea of having the saddle held up by a plastic pipe is a bit scary to me, am I being silly, I don't have issues with carbon forks, but the seatpost?
- mikesbytes
Postby mikesbytes » Sat Feb 10, 2007 7:25 am
- Mr888
Postby Mr888 » Sat Feb 10, 2007 8:47 am
He over tightened the collar (non-carbon compatible type) which resulted in it cracking a bit, then whilst on a ride he bounced on the saddle. The post just ruptured and fell off. You should have seen his face and reaction when he sat down and realised the saddle wasn't there OUCH!!!
- tuco
Postby tuco » Sat Feb 10, 2007 10:43 am
I don't ride an OCR but the main issue you have seems to be the drops.
I have them and hardly use them. I've used them only when going down hill and we don't have many hills in the area. Stream lining can make a surprisingly big difference.
How could you say no to $800?
- europa
Postby europa » Sat Feb 10, 2007 10:46 am
Is the post carbon or carbon coated aluminium? (ie, the cheap pretender)
- Mulger bill
Postby Mulger bill » Sat Feb 10, 2007 6:28 pm
If it's not too personal Mike, what do you weigh? I float between 74-79 kg.
I've heard stories of carbon posts breaking and having bent an alloy post and snapped three seatpost bolts I'm just a little paranoid about a shattered post that close
FSA's site lists the SL-K post as carbon with alloy head, what sort of weight penalty is there in full alloy?
Specs from their site...
sizes XS:42, S:46.5, M:50, L:55.5, XL:58.5
colour Gloss Black
frame ALUXX alloy: butted, FluidFormed, smooth welded
fork Composite blade, 1 1/8th alloy ahead steerer
rear derailleur Shimano Tiagra 9 sp.
front derailleur Shimano Tiagra
shifters Shimano Tiagra STI 27 sp. w/reach adjust
crankset Shimano Tiagra 2 Piece 30/39/50T w/Octalink
bottom bracket Shimano Tiagra Octalink integrated, outboard
chain Shimano HG53 9 sp.
cassette SRAM PG950 9 sp. 12-26T
brakes Tektro alloy dual pivot
brake levers Shimano Tiagra w/reach adjust
Shimano R500 20/24H wheelset
tyres Vittoria Zaffiro 700 x 25c
pedals Shimano R540 SPD-SL clipless
h.bar/stem Alloy anatomic shallow drop/Giant Lite Alloy 4 bolt
seat Post FSA SL-K composite 27.2
saddle Velo w/composite base/gel/cut-out
grips Velo cork gel w/gel comfort inserts
I know nothing about road components except what I've read here, I've got a fair idea of where each group sits in the foodchain. Is there anything else on the list that would bear watching? Sooner or later the upgrade bug will bite I know the pedals will be swapped out for M505's before she leaves the shop.
I was really looking at taking my time on this lap of the ride, hunting, reading and the odd test as I got the free time, but as Tuco said How could you say no to $800? Speaking of... did you get a ride in today mate?
Thanks again all.
Shaun
- mikesbytes
Postby mikesbytes » Sat Feb 10, 2007 9:13 pm
I weighed 82kg when I brought the OCR2 in 04, since then my weight dropped to 74kg in April 06 and back to 82kg in Dec 06 and is currently 80k. I have carried super heavy back packs that weigh more than the bike and regularly bunny hop a speed hump at around 45kmh thats on my route to work. So far I have broken one rear rim.
I have a track record for breaking things, in particular frames and forkes. Never broken a seat post.
I should point out that a carbon seat post provides no weight benifit over an alloy one, this is one application where alloy seems to give little to carbon. There could be an argument for carbon seat posts on provide a small improvement in confort, as carbon tends to soak up the bumps and vibrations better than metals. However I'm not recommending that you change the seat post, as perhaps the replacement seat post wasn't designed for a sloping top tube compact frame. I've been happy with the seat post and have no intention of exchanging it.
I would assume that the shop will swap the pedals for you at no cost, as they will be able to sell those pedals.
Looking down the specs I see that the current OCR2 has lower gearing, mine came with 30/42/52 12-26, which when they wore out I swapped to 30/42/53 11-21 and when that wore out I swapped to 30/42/53 11-25. I perfer talling gearing as I'm a masher. Standard tyres are ok, no need to swap them.
Hope this helps.
- LuckyPierre
Postby LuckyPierre » Sat Feb 10, 2007 10:22 pm
- Mulger bill
Postby Mulger bill » Sat Feb 10, 2007 10:37 pm
Low geared , my first thought was, 30-26 oh well it's back to pushing up hills
Ohhhh hell, this Tiagra stuff, it isn't rapid rise is it??
- Mulger bill
Postby Mulger bill » Wed Feb 14, 2007 2:40 pm
Boy was that fffaaaaaaaaaaassssttt, I'd forgotten just how well these things handle too. It felt good, not too hard on the back and I was still able to get into a tuck Even managed to blow off a few smokeboxes Haven't those caliper brakes improved hugely over the years? I just gotta remember to unweight for the bumps, have to soak up the snotty bits without fat tyres to do it for me, oh well.
I'm gonna get me one, just one leetle problem, DAMN.
Tim quoted $800 when asked, pity he was looking at the OCR3 sheet at the time. He said $1000 with the pedal swap, bidon cage and 'puter, still a good deal? It just means waiting a while to scrounge up the other $200. I'll hit him with a deposit later.
Thanks to all who posted on this thread, and all the rest of you too of course I've learned a hell of a lot and had a great time here, now I might be able to sound (slightly) less thick discussing road lore.
Stay upright and rolling
Shaun
- tuco
Postby tuco » Wed Feb 14, 2007 3:08 pm
Don't you hate that. I spent a couple of days thinking I was paying $749 (on sale $899 down to $749) then I decided I wanted the extra chain ring for the hills. "Oh, you have to go to the next model up, that'll be $999."Mulger bill wrote:I'm gonna get me one, just one leetle problem, DAMN.
Tim quoted $800 when asked, pity he was looking at the OCR3 sheet at the time. He said $1000 . . . .
- LuckyPierre
Postby LuckyPierre » Wed Feb 14, 2007 3:28 pm
Of course it's still a good deal!Mulger bill wrote: ...... Boy was that fffaaaaaaaaaaassssttt .....
- Mulger bill
Postby Mulger bill » Wed Feb 14, 2007 4:35 pm
Yep, not fun but I'll suck it up and grin when I hit 60+ (speeding??? sorry ossifer, I was just keeping up, don't have a speedo ) *palms 'puter into the shorts*tuco wrote:Don't you hate that....
I did have a look at the 3, seeing as that was what I got quoted on, hmmm. Maybe, but not on that dishwater coloured frame, even the GLW said ugly. Superficial? I dunno, it looks to my uneducated eyes like the jump from Sora to Tiagra more than makes up the $200 diff.
Now......just who can I mug for two hundred quid
- Mulger bill
And here She is!
Postby Mulger bill » Thu Feb 22, 2007 12:01 am
Isn't she pretty? (not as pretty as Princess tho')
Am I strange? the first thing I did when she got home was put her on the stand and have a bloody good fondle I know Tim and his offsider Jake are damn good wrenches, but still.......
Coupla things, no pump or 'puter yet, forgot the pump in my mad desire to get her home where nobody could see. Tims junior sold the bloody 'puter, Grrrr.
Thinking the seat post might be a little high, felt like I was bouncing a bit on the ride, with the legs just a little too straight, maybe get the setback checked again too, I know it's what the book says, should I try getting used to it first?
Time to start working towards a century, methinks
Postby reparto corse » Thu Feb 22, 2007 12:14 am
- europa
- Mulger bill
Postby Mulger bill » Thu Feb 22, 2007 1:01 am
Give my daughter five minutes with Photoshop, we'll see about thateuropa wrote:I hate to tell you this, but the shed door isn't 'cream' coloured. Sorry, your photos don't count
Does he let you ride it? Those brake levers might be a bit complicated for blokes used to a 1x1 with no freewheeleuropa wrote:Funny, it looks just like my son's OCR2 Hope you have as much fun on her as he has on his
Fun's what it's all about
Thanks to all who've answered my stupid questions (why didn't you answer the intelligent ones?)
RIGHT! WHO SAID "WE'RE STILL WAITING FOR ONE"???
Gotta send huge kudos to the GLW too. I ummed and ahhed for a while, this bike is an indulgence after all, but she gave the OK straight away. I wish she rode
- tuco
Postby tuco » Thu Feb 22, 2007 8:12 am
I wish my wife rode too . . . then she'd understand why I have to spend money on these things.Mulger bill wrote: Gotta send huge kudos to the GLW too. I ummed and ahhed for a while, this bike is an indulgence after all, but she gave the OK straight away. I wish she rode
Maybe she's not happy I've found a hobby that'll keep me around a lot longer than she hoped.
Seriously though, she doesn't really care. Months after I bought my bike and realised I was serious about racing say said, "Maybe you should have spend a bit more and got a really good bike."
When I told her I was going to replace my old crappy, rescued from a friends tip run, bike she expected I was only going to buy from Big W. "Have you checked Big W yet?", "No, they don't sell real bikes at Big W."
She has her antique china cups and plates, I have my bike. We're both happy.
- sogood
- Mulger bill
Postby Mulger bill » Thu Feb 22, 2007 9:52 am
Gotta get the back used to crouching over the drops again. Said hello yesterday to a few muscle groups I'd forgotten existed.
- sogood
Postby sogood » Thu Feb 22, 2007 9:59 am
You are now a roadie. Doing the reverse flip is a sacrilege!Mulger bill wrote:I've actually thought of flipping the stem for a bit more height
Seriously, putting one spacer above (even just a 5mm one) is desirable as it prevents the stem from clamping the end of the steerer as well as provides maximal clamp contact. It all makes perfect mechanical sense. This issue has been said to be particularly relevant to CF steerers. IIRC, Trek or Giant has a specific recommendation on this.
- Mulger bill
Postby Mulger bill » Thu Feb 22, 2007 10:12 am
Oh no yer don't! I's a loud and proud fat tyre fanatic.sogood wrote:You are now a roadie. Doing the reverse flip is a sacrilege!
I's just got a new plaything for those "Top Gun" moments in life
Thanks for the tip there mate, I gotta admit it does make sensesogood wrote:Seriously, putting one spacer above (even just a 5mm one) is desirable as it prevents the stem from clamping the end of the steerer as well as provides maximal clamp contact. It all makes perfect mechanical sense. This issue has been said to be particularly relevant to CF steerers. IIRC, Trek or Giant has a specific recommendation on this.
Will look further into it. Anyone else heard of it?
Shaun
- mikesbytes
Postby mikesbytes » Thu Feb 22, 2007 10:30 am
- Mulger bill
Postby Mulger bill » Thu Feb 22, 2007 10:34 am
Most posts have a minimum insertion mark to give a guide. My personal preference is to have the post extend at least 40mm below the bottom of the top tube/seatstay junction as it helps strengthen the area. Knowing me, it's prolly wrong tho'
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
Users browsing this forum: Thoglette
- All times are UTC+11:00
