I am using 11s Shimano. Just got 3 of these
https://zerofrictioncycling.com.au/prod ... asterlink/
It states compatible with campag too and lists various speed chains.
Postby warthog1 » Thu Apr 11, 2024 3:37 pm
Postby Thoglette » Thu Apr 11, 2024 8:16 pm
There's also allowance in there for: a set of cable outers and inners (I usually chew through a few RHS inners in 10K but I have a big box of them) ; most of a wheel rebuild (usually the rear ), and for proportion of the set of bearings (wheels, headset, BB).2wheels_mond wrote: ↑Wed Apr 10, 2024 6:53 am
$600 per 10,000km? On 8 speed? That seems like a lot - back of the envelope calcs seems like my costs (of consumables) are about half that using 12-speed and high-end tyres (2x M6100 chains, $40 each, 1.5 Pirelli P Zero Race TLR tyres, $100 each, 0.5 105 R7100 cassettes, $70).
Postby kilroy » Thu Apr 11, 2024 9:31 pm
Cheers, thanks for the info. Sounds like you get pretty good bang for buck.blizzard wrote: ↑Wed Apr 10, 2024 10:13 pmDepends on how dirty it gets, probably about 10000km.
For dry riding no need to use boiling water, I just give it a wipe with isopropyl alcohol or method whilst on the bike to get ride of surface dust and then pop off and wax.
It's only wet riding really needs a boiling water bath, out the chain in a tub of boiling water wait a couple minutes then agitate then dump the water, do it, 3x and then dry the chain and re-wax. I have found adding a dash of laundry liquid to the first bath sems to clean better.
Postby kilroy » Thu Apr 11, 2024 9:33 pm
Makes sense, thanks.
Postby goanna » Fri Apr 12, 2024 1:13 pm
Thanks for the link. That looks like a good option - however it only lists 8-12 speed options and the Campag Ekar is 13 speedPost by warthog1 » Thu Apr 11, 2024 3:37 pm
goanna wrote: ↑
Thu Apr 11, 2024 1:46 pm
Novice question - does anyone wax with a Campagnolo drivetrain? The quick links for an Ekar chain are marked for one use. And a replacement C link is nearly $30(!). Do people reuse the C-link?
Postby warthog1 » Fri Apr 12, 2024 1:28 pm
Bugger. No idea there sorry.goanna wrote: ↑Fri Apr 12, 2024 1:13 pmThanks for the link. That looks like a good option - however it only lists 8-12 speed options and the Campag Ekar is 13 speedPost by warthog1 » Thu Apr 11, 2024 3:37 pm
goanna wrote: ↑
Postby warthog1 » Sat Apr 13, 2024 10:46 pm
Postby Arbuckle23 » Sun Apr 14, 2024 5:31 pm
Postby warthog1 » Sun Apr 14, 2024 5:35 pm
He does I found it interesting though. No other method of lube compares from a wear perspective. He does show some drip lubes you can use with immersive waxes too, so try again
Postby warthog1 » Thu Apr 18, 2024 10:17 am
Postby warthog1 » Thu Apr 18, 2024 7:54 pm
Postby kilroy » Thu Apr 18, 2024 8:18 pm
Postby Jean » Fri Apr 19, 2024 6:59 am
I do with 12-speed and can use KMC or SRAM Eagle links. But with 13-speed Ekar I think you're out of luck.
Postby MichaelB » Fri Apr 19, 2024 10:54 am
Postby kilroy » Fri Apr 19, 2024 1:04 pm
Postby foo on patrol » Fri Apr 19, 2024 7:47 pm
Users browsing this forum: piledhigher2, thamete
